Unable to detect second GPU Ubuntu 20.04
I have been building a custom setup for Deep Learning and my specs are as follows:
CPU: ryzen 7 3700x
GPU: RTX 2070 Super + GT 710
Motherboard: Asus Prime X570 Pro
PSU: 750 W
RAM: 2 * 32 Gb
I want to use the GT 710 for display the RTX 2070 to run deep learning models.
I installed the 440 driver.
The command sudo lspci |grep -i VGA outputs:
08:00.0 VGA compatible controller: NVIDIA Corporation TU104 [GeForce RTX 2070 SUPER] (rev a1)
09:00.0 VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 710] (rev a1)
the command nvidia-smi only detects the GT 710 card (also, the system hangs up for 5s when executing this command).
| NVIDIA-SMI 440.100 Driver Version: 440.100 CUDA Version: 10.2 |
| 0 GeForce GT 710 Off | 00000000:09:00.0 N/A | N/A |
| 54% 64C P0 N/A / N/A | 296MiB / 972MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
The sudo dmesg |grep NVRM outputs:
[ 2.212251] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 440.100 Fri May 29 08:45:51 UTC 2020
[ 14.417656] NVRM: GPU 0000:08:00.0: RmInitAdapter failed! (0x26:0x65:1227)
[ 14.417689] NVRM: GPU 0000:08:00.0: rm_init_adapter failed, device minor number 0
[ 30.601499] NVRM: GPU 0000:08:00.0: RmInitAdapter failed! (0x26:0x65:1227)
[ 30.601562] NVRM: GPU 0000:08:00.0: rm_init_adapter failed, device minor number 0
[ 40.643204] NVRM: GPU 0000:08:00.0: RmInitAdapter failed! (0x26:0x65:1227)
[ 40.643239] NVRM: GPU 0000:08:00.0: rm_init_adapter failed, device minor number 0
[ 48.905430] NVRM: GPU 0000:08:00.0: RmInitAdapter failed! (0x26:0x65:1227)
[ 48.905468] NVRM: GPU 0000:08:00.0: rm_init_adapter failed, device minor number 0
[ 57.204207] NVRM: GPU 0000:08:00.0: RmInitAdapter failed! (0x26:0x65:1227)
[ 57.204245] NVRM: GPU 0000:08:00.0: rm_init_adapter failed, device minor number 0
[ 65.472228] NVRM: GPU 0000:08:00.0: RmInitAdapter failed! (0x26:0x65:1227)
[ 65.472269] NVRM: GPU 0000:08:00.0: rm_init_adapter failed, device minor number 0
[ 73.734750] NVRM: GPU 0000:08:00.0: RmInitAdapter failed! (0x26:0x65:1227)
[ 73.734787] NVRM: GPU 0000:08:00.0: rm_init_adapter failed, device minor number 0
I ran nvidia-bug-report.sh and the result is attached.
Could anyone please help me out?
nvidia-bug-report.log.gz (346.3 KB)
if you unplug your 710, does the 2070 GPU work by itself?
It used to work properly but stopped working correctly a week ago, with some occasional freezes. Till yesterday, these freezes were rare but since this morning, I don’t manage to pass the grub with the RTX 2070 plugged to the screen. I had to plug the 710 to start the computer.
