Unable to determine the device handle for GPU 0000:00:09.0
I eventually succeed to install a ubuntu machine on k with device pass through
Cuda installed properly. After reboot nvidia driver a bound to the device
But when trying:
nvidia-smi
of course, in my case the card is not a X11 device. the boot vga adapter is the QEMU adapter.
But this is also the case when using the card on my local box without pass through.
Here the card is installed as the second card, laso without serving as a graphic device.
I don’t have a list that I can point you to. Most higher end Quadro and all Tesla adapters should work in a virtualized setting, generally speaking. Before making any purchase commitments, I would recommend you evaluate any GPU for desired behavior.
