• Hardware Platform (Jetson / GPU) - GPU • DeepStream Version - 6.0 • JetPack Version (valid for Jetson only) • TensorRT Version - 8.0.1 • NVIDIA GPU Driver Version (valid for GPU only) - 515.65.01 • Issue Type( questions, new requirements, bugs) - questions
I’m trying to run inference on multiple jpg files. Attached the code for reference. I don’t see any error in the debugs, there are warnings though. The pipeline is not running. Attached the logs as well. Attached sample data in the zip. I referenced the sample app - sample_apps/deepsteam_image_decode_test for usage of inference over a single image.
Please let me know the issue with the pipeline. 00.zip (67.5 KB)
Yes. It’s related to this jpeg picture. Gstreamer origin code cannot parse your jpeg file. So you can open a topic on Gstreamer forum. https://gstreamer.freedesktop.org/
You can try to change the decode plugin to nvjpegdec instead of jpegparser+nvv4l2decoder at present.
