Unable to Enter Force Recovery After Flashing AGX Orin UEFI mistakenly
Platform Information
  • Module: Jetson Orin NX
  • BSP: JetPack 6.2 (L4T r36.4.4)
  • Boot Storage: QSPI + NVMe
  • Carrier Board: Custom Carrier Board
Issue Description
We accidentally flashed an AGX Orin UEFI image onto a Jetson Orin NX module.
After the update, the module can no longer boot normally and also appears unable to enter Force Recovery Mode.
We would like to understand whether flashing an AGX Orin UEFI image could affect Force Recovery functionality on Orin NX and what recovery options are available.Recommended recovery procedure for restoring a Jetson Orin NX after an AGX Orin bootloader/UEFI image was mistakenly flashed.
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
The issue you are experiencing is likely due to the AGX Orin UEFI image being flashed onto a Jetson Orin NX module, which is not compatible. The AGX Orin UEFI image is specific to the AGX Orin platform and may not be compatible with the Orin NX platform.
According to the provided context, flashing an AGX Orin UEFI image onto an Orin NX module can cause issues with the module’s ability to boot normally and enter Force Recovery Mode.
To recover from this issue, you can try the following steps:
  1. Reflash the Orin NX module with the correct UEFI image for the Orin NX platform using the SDK Manager.
  2. If the module is still unable to boot normally, try entering Force Recovery Mode by pressing the Recovery button on the module while powering it on.
  3. If the module is still unable to enter Force Recovery Mode, you may need to use a third-party tool or consult with NVIDIA support for further assistance.
It is recommended to use the correct UEFI image for the Orin NX platform to avoid any compatibility issues. Additionally, it is always a good idea to back up your data and configuration before flashing a new UEFI image onto the module.
In summary, flashing an AGX Orin UEFI image onto an Orin NX module can cause issues with the module’s ability to boot normally and enter Force Recovery Mode. To recover from this issue, you can try reflashing the module with the correct UEFI image for the Orin NX platform or seeking further assistance from NVIDIA support.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Updating the UEFI will not affect recovery mode, as recovery mode is pure hardware event.
Please follow the Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation to place the device into recovery mode, then run lsusb to verify.
