Unable to find Jetpack OS for Jetson Nano 2GB
So I haven’t used my Jetson Nano 2GB for two years and when I booted it up after a very long time, it failed to boot up and gave the error code -84. When I looked up solutions for this error in the forum, someone else had the same issue and reflashed their SD card with the newest Jetpack OS. I tried doing that, but the page from where I downloaded the Jetpack OS had the SDK for only the new Nvidia Orin, so I looked up an older one that supports all Jetson boards: Jetpack 4.6.1. I reflashed the SD card and booted up the system after which it was stuck in the Nvidia screen and failed to boot up. Can anyone please help me with this?
Find a ubuntu 18.04 host PC and install sdkmanager to use it to flash your board.
Hey, I was able to solve the problem but as soon as I Rebooted it and tried to power it on again the green light came on for 1 sec and then went off…I’m not getting any output from the board via HDMI. Any suggestions?
Please get the log:
This sounds like a hardware aspect issue. Are you sure the power adapter is fine? Are you using usb to provide power source or a power barrel?
I’m using a 5V 3A power adapter via USB-C since that’s the only way of powering The Jetson Nano 2GB version. I have been using that same adapter before and it worked perfectly. Can’t figure out what’s wrong…
maybe try another power source, you can refer to Power supply considerations for Jetson Nano Developer Kit - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
