I am trying to check the maxrate on my Nvidia Jetson Thor. The directory is “cat /sys/kernel/debug/bpmp/debug/clk/nvjpg/max_rate”
pmh786
1
DaneLLL
3
Please check
Jetson AGX Thor FAQ
The rate of NVJPG is defined in nvpmodel.conf:
VIDEO MIN_FREQ 315000000
VIDEO MAX_FREQ 1557000000
Related topics
| How to adjust current nvenc max rate | 4 | 872 | October 18, 2021 | |
| Jetson THOR GPU stuck at 1.05GHz | 6 | 301 | October 8, 2025 | |
| deviceQuery shows GPU Max Clock rate: 72 MHz (0.07 GHz) | 1 | 1540 | March 11, 2016 | |
| How to change extperiph2 max_rate? | 3 | 447 | February 22, 2022 | |
| Is there a way to find out how much is decoder used | 2 | 493 | January 18, 2023 | |
| TX2, error when max out the clock frequencies: n command: -max, please try again or see --help | 5 | 1620 | October 18, 2021 | |
| Default frequency of extperiph1 | 4 | 351 | April 22, 2024 | |
| deviceQuery shows Jetson-tx1 GPU Max Clock rate: 72 MHz,Memory Clock rate: 13 Mhz | 2 | 1704 | October 18, 2021 | |
| Encoder max-perf isn't working | 5 | 128 | November 28, 2025 | |
| Devkit,120w power mode, gpu freq can reach 1.574GHZ | 10 | 271 | December 19, 2025 |
