17:08:16 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to ‘Manual Setup’ to continue.
17:08:38 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to ‘Manual Setup’ to continue.
17:09:00 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to ‘Manual Setup’ to continue.
17:09:22 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to ‘Manual Setup’ to continue.
17:09:44 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to ‘Manual Setup’ to continue.
17:10:06 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to ‘Manual Setup’ to continue.
