Unable to flash Jetson Xavier AGX to jetpack 5.0 DP
Hi team,
I am having trouble with flashing my jetson xavier agx to upgrade the jetpack.
Jetpack version: 4.6.2
Host: using VMware Workstation with ubuntu 18.04.6
First I follow the step using the sdkm to upgrade the jetpack but it failed when flashing the jetson os.
Full log:
sdkm-2022-07-21-16-57-32.log (240.8 KB)
Then I tried to use sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1, it gives me an error 'Error: None of the bootloaders are running on device. Check the UART log. Failed flashing t186ref. ’
Full log:
log_flash2.txt (64.2 KB)
We only suggest to use the native Ubuntu 18.04 host for SDK manager/JetPack4.6.2, the VMWare is not supported, and may have some unknow issues.
Or you may refer to other developer experiences to see if can work:
Thank you, I will try to flash on a native Ubuntu host, and see if it works.
