Unable to flash Jetson Xavier AGX with LEETOP GE Carrier BOard
Trying to flash a Jetson Xavier AGX with LEETOP carrier board using the Jetson SDK tools “flash.sh”. I’m getting an error “CPU Bootloader is not running on device.” Is this fixable?
sudo ./flash.sh jetson-agx-xavier-ind-noecc mmcblk0p1
[sudo] password for brianm:
L4T BSP Information:
R32 , REVISION: 7.1
Target Board Information:
Name: jetson-agx-xavier-ind-noecc, Board Family: t186ref, SoC: Tegra 194,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying soft_fuses(/home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
./tegraflash.py --chip 0x19 --applet “/home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0054 ] Generating RCM messages
[ 0.0081 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0104 ] Header already present for /home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0211 ]
[ 0.0256 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0258 ] Assuming zero filled SBK key
[ 0.0303 ] tegrasign_v3.py --file /home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0305 ] Assuming zero filled SBK key
[ 0.0408 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0508 ]
[ 0.0553 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0582 ]
[ 0.0622 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/brianm/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0648 ] RCM 0 is saved as rcm_0.rcm
[ 0.0761 ] RCM 1 is saved as rcm_1.rcm
[ 0.0761 ] RCM 2 is saved as rcm_2.rcm
[ 0.0761 ] List of rcm files are saved in rcm_list.xml
[ 0.0762 ]
[ 0.0762 ] Signing RCM messages
[ 0.0807 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0809 ] Assuming zero filled SBK key
[ 0.1035 ] Copying signature to RCM mesages
[ 0.1076 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1120 ]
[ 0.1122 ] Boot Rom communication
[ 0.1165 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1191 ] RCM version 0X190001
[ 0.3552 ] Boot Rom communication completed
[ 1.3719 ]
[ 2.3770 ] tegrarcm_v2 --isapplet
[ 2.3795 ] Applet version 01.00.0000
[ 2.9234 ]
[ 2.9278 ] tegrarcm_v2 --ismb2
[ 3.5588 ]
[ 3.5629 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 3.5657 ]
[ 3.5699 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 3.5724 ] adding BCH for nvtboot_applet_t194.bin
[ 3.5830 ]
[ 3.5893 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.5895 ] Assuming zero filled SBK key
[ 3.6021 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 3.6105 ]
[ 3.6147 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 3.6173 ] Applet version 01.00.0000
[ 4.5165 ] Sending mb2
[ 4.5169 ] […] 100%
[ 4.5347 ]
[ 4.5387 ] tegrarcm_v2 --boot recovery
[ 4.5410 ] Applet version 01.00.0000
[ 5.3554 ]
[ 6.3608 ] tegrarcm_v2 --isapplet
[ 1014.7662 ]
[ 1014.7710 ] tegrarcm_v2 --ismb2
[ 2030.5742 ]
[ 2030.5789 ] tegradevflash_v2 --iscpubl
[ 2030.5816 ] CPU Bootloader is not running on device.
Please contact with LeeTop for the support with the BSP version you want to reflash.
