I am unable to successfully flash my SSD. Here are the commands I tried and the outputs of those commands. What is strange is that the QSPI flash is getting flashed just fine, but not the SSD. So, after attempting the flashing, the Jetson boots the kernel and gets to the Nvidia splash screen but then it halts.
Any ideas? I have tried multiple different SSDs.
custom_flash.sh:
UDISKS2_ACTIVE=$(sudo systemctl is-active udisks2.service)
trap cleanup 1 2 3 6
L4T_DIRECTORY="R32.6.1/Linux_for_Tegra"
cleanup()
if [[ ${UDISKS2_ACTIVE} == 'active' ]] ; then
echo "enabling usb mass storage devices"
sudo systemctl start udisks2.service
fi
exit
function flash_jetson
cd $L4T_DIRECTORY
echo "disabling usb mass storage devices"
sudo systemctl stop udisks2.service
read -p "Press enter to generate internal image..."
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash jetson-agx-xavier-devkit internal
read -p "Press enter to generate external encrypted image..."
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash \
--external-device nvme0n1p1 \
-S 8GiB -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml \
--external-only --append jetson-agx-xavier-devkit external
read -p "Press enter to flash both images..."
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only
cleanup
flash_jetson
Output of results exceeds the character limit for a post so I have to upload attachments:
custom_flash_output.txt (251.4 KB)
console_boot_attempt.txt (34.7 KB)
