Hi, I have put my Xavier dev kit into recovery mode. Doing lsusb does show that it is being detected:
Bus 001 Device 006: ID 0955:7019 NVidia Corp.
However, the jetpack SDK manager keeps failing to detect the device while attempting to flash the OS. Below is a snippet from the terminal:
- 22:18:02 INFO : Flash Jetson AGX Xavier : exec_command: sudo ./flash.sh jetson-xavier mmcblk0p1
- 22:18:02 INFO : Flash Jetson AGX Xavier : ###############################################################################
- 22:18:02 INFO : Flash Jetson AGX Xavier : # L4T BSP Information:
- 22:18:02 INFO : Flash Jetson AGX Xavier : # R32 , REVISION: 3.1
- 22:18:05 INFO : Flash Jetson AGX Xavier : Error: probing the target board failed.
- 22:18:05 INFO : Flash Jetson AGX Xavier : Make sure the target board is connected through
- 22:18:05 INFO : Flash Jetson AGX Xavier : USB port and is in recovery mode.
- 22:18:05 INFO : Flash Jetson AGX Xavier : exit status 1
Anyone has an idea of whats wrong?
