Hi
I’m unable to flash internal sd card storage of Jetson AGX orin 64gb development kit,
I tried installing multiple time in mmc via sdk manager but it was unable install,
After trying multiple times I installed jetpack 6 in nvme drive, then it got install,
When I try to flash the internal mmc it’s showing me below error,
Hi @KevinFFF
Sorry for late reply,
Ya I tried installing in internal 64gb eMMC not SD card, Earlier i had installed Jetpack6 in eMMC, but now i cannot, but when i try in external m2 SSD it got installed
Here the output of the commands
(base) jetson@ubuntu:~/visionsentinal$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 4K 1 loop /snap/bare/5
loop1 7:1 0 164.3M 1 loop /snap/chromium/2906
loop2 7:2 0 69.2M 1 loop /snap/core22/1614
loop3 7:3 0 69.2M 1 loop /snap/core22/1624
loop4 7:4 0 61.2M 1 loop /snap/core24/493
loop5 7:5 0 65.9M 1 loop /snap/cups/1059
loop6 7:6 0 402.2M 1 loop /snap/gnome-46-2404/49
loop7 7:7 0 91.7M 1 loop /snap/gtk-common-themes/1535
loop8 7:8 0 87.3M 1 loop /snap/mesa-2404/142
loop9 7:9 0 33.7M 1 loop /snap/snapd/21761
loop10 7:10 0 16M 1 loop
mmcblk0 179:0 0 59.2G 0 disk
mmcblk0boot0 179:32 0 4M 1 disk
mmcblk0boot1 179:64 0 4M 1 disk
zram0 252:0 0 2.6G 0 disk [SWAP]
zram1 252:1 0 2.6G 0 disk [SWAP]
zram2 252:2 0 2.6G 0 disk [SWAP]
zram3 252:3 0 2.6G 0 disk [SWAP]
zram4 252:4 0 2.6G 0 disk [SWAP]
zram5 252:5 0 2.6G 0 disk [SWAP]
zram6 252:6 0 2.6G 0 disk [SWAP]
zram7 252:7 0 2.6G 0 disk [SWAP]
zram8 252:8 0 2.6G 0 disk [SWAP]
zram9 252:9 0 2.6G 0 disk [SWAP]
zram10 252:10 0 2.6G 0 disk [SWAP]
zram11 252:11 0 2.6G 0 disk [SWAP]
nvme0n1 259:0 0 238.5G 0 disk
├─nvme0n1p1 259:1 0 237G 0 part /
├─nvme0n1p2 259:2 0 128M 0 part
├─nvme0n1p3 259:3 0 768K 0 part
├─nvme0n1p4 259:4 0 31.6M 0 part
├─nvme0n1p5 259:5 0 128M 0 part
├─nvme0n1p6 259:6 0 768K 0 part
├─nvme0n1p7 259:7 0 31.6M 0 part
├─nvme0n1p8 259:8 0 80M 0 part
├─nvme0n1p9 259:9 0 512K 0 part
├─nvme0n1p10 259:10 0 64M 0 part
├─nvme0n1p11 259:11 0 80M 0 part
├─nvme0n1p12 259:12 0 512K 0 part
├─nvme0n1p13 259:13 0 64M 0 part
├─nvme0n1p14 259:14 0 400M 0 part
└─nvme0n1p15 259:15 0 479.5M 0 part
(base) jetson@ubuntu:~/visionsentinal$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/nvme0n1p1 233G 37G 184G 17% /
tmpfs 31G 170M 31G 1% /dev/shm
tmpfs 13G 35M 13G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 6.2G 148K 6.2G 1% /run/user/1000
It seems you are using NVMe SSD as rootfs.
Your internal eMMC(mmcblk0) has been formatted.
May I know what’s your use case now?
Do you want to flash internal eMMC?
If so, please simply run the following command from your host to flash internal eMMC on your devkit.
