Unable to fuse Orin NX
  • Running Jetson Linux r36.3
  • Orin NX
odmfuse fails with error: Failed to get address for br bct from nv3p helper.
sudo ./odmfuse.sh --test -i 0x23 -k "pkc.pem" -S "sbk.key" -X "fuse.xml" jetson-orin-nano-devkit
Same error with any combination of with/without --test and with/without -k "pkc.pem" -S "sbk.key"
Powering the board off and on again doesn’t solve it. Rebooting the computer neither.
Last few lines of the logs:
[   0.9268 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ascento/computer-install/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   0.9270 ] MB2 Applet version 01.00.0000
[   0.9294 ] Saved platform info in /home/ascento/computer-install/Linux_for_Tegra/bootloader/cvm.bin
[   0.9628 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.9630 ] MB2 Applet version 01.00.0000
[   0.9656 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.9658 ] MB2 Applet version 01.00.0000
[   0.9681 ] Dumping customer Info
[   0.9683 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   0.9685 ] MB2 Applet version 01.00.0000
[   0.9709 ] 0000000054220302: E> NV3P_SERVER: Failed to get address for br bct from nv3p helper.
[   1.0493 ]
[   1.0493 ]
Error: Return value 2
Command tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
Reading board information failed.
Before running odmfuse.sh the command ./bootloader/tegrarcm_v2 --new_session --chip 0x23 --uid succeeds and returns the ECID. After the odmfuse.sh fails, the same command does not return anything. I guess the board ends up in a weird state.
While odmfuse.sh there are no log messages in dmesg
Any idea what is going on and how to fix it?
I solved it! I was out of ideas, so I did a simple re-flash of the board. It succeeded without problem and I booted into Ubuntu. Then i went back into recovery mode and re-tried the odmfuse. Which worked without issues. Below is the command I used to re-flash the device:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
