I generated tensorrt inference graph from tensorflow yolo model using TF-TRT. I could not find ‘TRTEngineOp’ in the generated graph. That means tensorrt is falling back to tensorflow. Program is running without any error.
There is no ‘TensorRTOptimizer’ call in the log.
Here is the TensorRT graph generation log.
2019-09-18 11:28:03.893139: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:716] Optimization results for grappler item: tf_graph
2019-09-18 11:28:03.893229: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:718] constant folding: Graph size after: 113 nodes (0), 114 edges (0), time = 31.321ms.
2019-09-18 11:28:03.893271: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:718] layout: Graph size after: 141 nodes (28), 166 edges (52), time = 15.636ms.
2019-09-18 11:28:03.893299: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:718] constant folding: Graph size after: 141 nodes (0), 166 edges (0), time = 17.429ms.
2019-09-18 11:28:04.171328: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1640] Found device 0 with properties:
name: GeForce RTX 2080 Ti major: 7 minor: 5 memoryClockRate(GHz): 1.545
Here are my cuda stack versions.
CUDA : 10.0
cudnn : 7.6.2.24-1+cuda10.0
tensorflow : 1.14.0
tensorrt : 5.1.5-1+cuda10.0
OS : ubuntu 16.04
GPU : RTX 2080 Ti
Earlier I was able to run my models on tensorrt on GTX 1080 Ti with following configuration.
CUDA : 9.0
cudnn : 7.5.0+cuda9.0
tensorflow : 1.11.0
tensorrt : 4.0.1.6-1+cuda9.0
OS : ubuntu 16.04
GPU : GTX 1080 Ti
I upgraded to higher versions as the same configuration is not working on RTX 2080 Ti.
Please help me in generating proper inference graph using tensorrt.
