Unable to get 7.2x working on DGX spark with cubb 26-1 and Benetel O-RU
I installed Aerial L1(26.1), OAI L2/L3(ATB1.1) on DGX Spark and using Benetel as O-RU(v1.0.4). PTP is working fine on both sides. Whenever the UE sends the RRCSetupComplete message(MSG5), "SCF_ERROR_CODE_L1_MISSING_UL_IQ" error comes, and the UE starts initiating RACH again. But we are able to see MSG4 ACK all the time. Used the same timing parameters that are used for OAI7.2x split. The RU works fine in other setups. Sometimes we are able to see LCID1 also. In RU KPI parameters, we don’t see any Uplink packets flowing continuously (only when the UE sends RACH and MSG3), and the Tx packet count is also less (count similar to 1x1). But we are running in 4x4 mode. We are not able to address the problem.
cuphycontroller_P5G_WNC_DGX_BENETEL.yaml.txt (10.3 KB)
nv-cubb_logs.txt (64.0 KB)
oai-gnb-aerial-dgx_logs.txt (103.5 KB)
RU_KPIs_
Hi @mrunaliniptn ,
Did you check my comment on DGX Spark Aerial 26.1: Only C-plane eCPRI packets transmitted, no U-plane packets on the wire - #8 by nhashimoto?
Thank you,
We tried with your suggestions. But still we are getting the same issue.
Thank you,
Ok, can you send me nvipc.pcap around the time when you see Msg4?
If possible, can you capture the FH packets as well?
I am attaching the nvipc.pcap file captured around the Msg4 ACK.
nvipc.pcap.txt (9.6 MB)
Looking at the provided pcap file, L1 was sending some CRC.indicaiton messages with TbCrcStatus: 0 (i.e., CRC pass) and corresponding RX_Data.indication messages.
UL SINR seems good in these messages. There might be no problem in the UL link.
Going back to the provided OAI log, the CN rejected the UE registration. There might be a misconfiguration at the UE or CN sides.
[10:35:09.573019] [NR_MAC] W UE ea61 RA failed at state WAIT_Msg3 (Reached msg3 max harq rounds)
[10:35:09.573023] [NR_MAC] I Remove NR rnti 0xea61
[10:35:09.660520] [NR_MAC] A 297.19 UE RA-RNTI 010b TC-RNTI 1d98: initiating RA procedure
[10:35:09.660523] [NR_MAC] I UE 1d98: Sync beam index 0
[10:35:09.662509] [NR_MAC] I UE 1d98: Msg3 scheduled at 298.14 (298.8 TDA 0) start 0 RBs 8
[10:35:09.662512] [NR_MAC] A UE 1d98: 298.8 Generating RA-Msg2 DCI, RA RNTI 0x10b, state 1, preamble_index(RAPID) 29, timing_offset = 0 (estimated distance 0.0 [m])
[10:35:09.668022] [NR_MAC] A  298.14 PUSCH with TC_RNTI 0x1d98 received correctly
[10:35:09.668026] [NR_MAC] A Received a MAC CE for C-RNTI with c297
[10:35:09.668027] [NR_MAC] I Received UL_SCH_LCID_C_RNTI with C-RNTI 0xc297, triggering RRC Reconfiguration
[10:35:09.668067] [NR_MAC] I Remove NR rnti 0x1d98
[10:35:09.668069] [NR_MAC] A  298.14 RA with C-RNTI c297 complete
[10:35:09.668075] [NR_RRC] W UE 1: UE Context Modification Required received while UE Context Setup is pending (CU UE ID 1), refusing
[10:35:09.668084] [MAC]    W Received UE Context Modification Refuse for c297, requesting release
[10:35:09.668092] [NR_RRC] I received UE Context Release Request for UE 1, forwarding to AMF
[10:35:09.668110] [RRC]    D Received message NGAP_UE_CONTEXT_RELEASE_REQ
[10:35:09.668114] [NGAP]   W Failed to find ue context associated with gNB ue ngap id: 1
We are seeing mostly zeros in TX_TOTAL on the RU side (except during RACH initiation which we are thinking). Is this also related to the misconfiguration that you are specifying.
In general, the L1 errors cannot cause the CN refusion. It should be a different issue. To succeed in the UE attach sequence, the misconfiguration must be fixed.
However, looking at the provided PCAP log again, the L1 was sending ERROR.inidcation messages with the code along with CRC/RX_Data.indication messages in most slots where UL was assigned. There might be a different configuration issue between the L1 and O-RU.
The nv-cubb.log indicates that the O-RU received the corresponding C-plane packets, and the L1 received some UL U-plane packets, but not all. Aerial has a longer Rx packet window than the window defined by the O-RAN parameters. So, I don’t think this is a timing issue.
3913 Cell 0 Order kernel sem_idx_rx 2543 last_sem_idx_rx 2494 sem_idx_order 2543 last_sem_idx_order 2494 PUSCH PRBs 0/2184 PRACH PRBs 0/0.  First packet received timeout after 1500000 ns F118S6S1 done = 0 current_time=24937038216512,last_timeout_log_time=0,total_rx_pkts=56
Does the following configuration match with O-RU’s configuration?
      eAxC_id_pusch: [0, 1, 2, 3]
Can you capture the FH packets?
Thank you.
Hi @nhashimoto ,
Here I am attaching the fronthaul captures from both the DU and RU facing ports. I am also attaching the O-RU’s config and eaxc.xml files for your reference. Except for PRACH (with eaxc ids [4, 5, 6, 7]) all other channels eaxc ids are [0, 1, 2, 3].
Thank you.
fronthaul_DU.pcap.txt (71.1 MB)
fronthaul_RU.pcap.txt (41.7 MB)
eaxc.xml.txt (2.1 KB)
ru_config.cfg.txt (1.7 KB)
The PCAP files don’t contain UL U-plane packets of sectionType 1. Can you capture the packets around Msg4 and when you observe an ERROR.indication?
To correlate the other logs, please provide the nv-cubb.log, oai-gnb log, and nvipc.pcap of the same test as well.
Please find the attached logs captured around the Msg4 ACK.
fronthaul_DU_run2.pcap.txt (83.5 MB)
nvipc.pcap.txt (14.5 MB)
oai-gnb-aerial-dgx_logs.txt (205.1 KB)
nv-cubb_logs.txt (76.4 KB)
We see the UL packets are malformed in the pcap file. If msg4 ACK is coming, then there should be corresponding U-Plane DL packets that are proper…Is our understanding correct?
I can see U-plane packets only for PRACH. Can you see other UL U-plane packets? If yes, can you point to the packet number in the PCAP file?
Yes, you can see U-plane packets. How did you capture the PCAP file?
If you are using tcpdump, please follow the way I suggested in the following thread.
Hi @nhashimoto ,
We captured packets using tcpdump to a different Linux server by mirroring the DU-facing port on the fronthaul switch. We are also seeing only the PRACH packets with ru_port_ids [4, 5, 6, 7].
From the thread you have attached here, we tried using this command “sudo tcpdump -i aerial00 -s 9000 -w traffic1.pcap” on DGX SPARK (Note: aerial00 is the same as mlx5_0). In this pcap file, we could only see the ptp packets. FYI, we did this capture around Msg4 ACK.
We have doubt regarding the flow of user-plane traffic. We see that the C-Plane is through the physical port aerial00 (in our case) which is through DPDK. How does a U-plane packet flow. For example, In OAI E2E setup, we bind both the C-Plane and U-Plane to DPDK. Here in the aerial setup, we couldn’t find how U-Plane traffic is being sent.
The port mirroring is the best way to capture packets, but it is prone to configuration errors.
According to nvipc.pcap, CRC.indication or other indication messages show the L1 received the corresponding UL U-plane packets because SNR is around 20 dB when CRC is passed. Also, there was no problem in the DL U-plane as well because the UE should have received the DL channels to reply PRACH and Msg4 to the network.
I doubt there is a misconfiguration for the port mirroring.
The command was incorrect. You have to specify mlx5_0 to capture RDMA packets. Please read the whole thread again.
Hi @nhashimoto ,
We captured the pcap file correctly. In this file, we can see the ru_port_id [1, 2, 3, 4] packets, but they are malformed. We are attaching the pcap file for your reference. The capture is around Msg4 ACK.
Thank you.
traffic3.zip.txt (53.3 MB)
I can see all the PRBs in the file.
I think this is the same as How to configure the bfp and splitting the 273 prb into multi-packet - #8 by nhashimoto. Please take a look.
There is an observation from this file.
The O-RU was not transmitting UL U-plane packets on the special slots. According to the previous nvipc.pcap, PUCCH is assigned to the special slots. Without the U-plane, the L1 causes the IQ missing error and reports DTX or low confidence to the L2. I guess this is why the higher stack doesn’t go to the next UE sequence.
Can you stop assigning any channels in the special slots as a test?
Thank you.
Hi @nhashimoto ,
Thank you for the suggestion. It worked.
The special slot cannot be all guard symbols as per the OAI config. Any non-zero value works. We replaced uplink symbols with Guard; it worked.
Hi @nhashimoto ,
Could you please point to the parameters for the number of layers, Link adaptation enable/disable, or setting MCS to a specific value?
