Hello!
After running clara platform start, stuck on nodemonitor daemonset with ErrImagePull.
Can’t find nodemonitor image.
clara version - 0.7.3-2011.5
UPD: ngc apikey was set
Hello!
This error is displayed when trying to pull manually
$ docker pull nvcr.io/nvidia/clara/nodemonitor:0.7.3-2011.5
Error response from daemon: pull access denied for nvcr.io/nvidia/clara/nodemonitor, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
Hi cheivan,
Thanks for your interest in the latest Deploy platform. It seems there was an issue publishing the new nodemonitor asset on NGC. We are working to resolve this and will follow up once complete.
Thanks,
Kris
Hi cheivan,
This issue has been resolved. You should now be able to pull the nodemonitor container from NGC.
Please let us know if you encounter any issues.
Thanks,
Kris
