Unable to get detection result or draw line on test app 2 with CSI camera
I am using DS test2 python application. I was able to draw line and detection on .h264 input video but when I update code for CSI camera i am able to open camera but not getting detection result or draw line. please help.
main function is:
def main(args):
    # Check input arguments
    # if len(args) != 2:
    #     sys.stderr.write("usage: %s <media file or uri>\n" % args[0])
    #     sys.exit(1)
    # Standard GStreamer initialization
    GObject.threads_init()
    Gst.init(None)
    # Create gstreamer elements
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    # Source element for reading from the file
    print("Creating Source \n ")
    source = Gst.ElementFactory.make("nvarguscamerasrc", "src_elem")
    if not source:
        sys.stderr.write(" Unable to create Source \n")
    caps_picamsrc = Gst.ElementFactory.make("capsfilter", "src_cap_filter")
    if not caps_picamsrc:
        sys.stderr.write(" Unable to create picamsrc capsfilter \n")
    # Video convertor
    print("Creating Video Converter \n")
    nvvidconv1 = Gst.ElementFactory.make("nvvidconv", "convertor1")
    if not nvvidconv1:
        sys.stderr.write(" Unable to create Nvvideoconvert \n")
    caps_nvvidconv1 = Gst.ElementFactory.make("capsfilter", "nvmm_caps")
    if not caps_nvvidconv1:
        sys.stderr.write(" Unable to create capsfilter \n")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    # Use nvinfer to run inferencing on decoder's output,
    # behaviour of inferencing is set through config file
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    # Use convertor to convert from NV12 to RGBA as required by nvosd
    nvvidconv2 = Gst.ElementFactory.make("nvvidconv", "converto2r")
    if not nvvidconv2:
        sys.stderr.write(" Unable to create nvvidconv \n")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    # Create OSD to draw on the converted RGBA buffer
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    # Finally render the osd output
    if is_aarch64():
        transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
    print("Creating EGLSink \n")
    sink = Gst.ElementFactory.make("nveglglessink", "sink_sub_bin_sink1")
    if not sink:
        sys.stderr.write(" Unable to create egl sink \n")
    caps_picamsrc.set_property('caps', Gst.Caps.from_string('video/x-raw(memory:NVMM), width=1280, height=720, framerate=21/1, format=NV12,flip-method=2'))
    caps_nvvidconv1.set_property('caps', Gst.Caps.from_string('video/x-raw,width=1280, height=720'))
    #print("Playing file %s " %args[1])
    #source.set_property('location', args[1])
    streammux.set_property('width', 1280)
    streammux.set_property('height', 720)
    streammux.set_property('batch-size', 1)
    streammux.set_property('batched-push-timeout', 4000000)
    #caps_nvvidconv1.set_property('flip-method', 2)
    #Set properties of pgie and sgie
    pgie.set_property('config-file-path', "Resnet_10_head.txt")
    sink.set_property('sync', False)
    #Set properties of tracker
    config = configparser.ConfigParser()
    config.read('dstest2_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config.getint('tracker', key)
            tracker.set_property('enable_batch_process', tracker_enable_batch_process)
    print("Adding elements to Pipeline \n")
    pipeline.add(source)
    pipeline.add(caps_picamsrc)
    pipeline.add(sink)
    pipeline.add(nvvidconv1)
    pipeline.add(streammux)
    pipeline.add(caps_nvvidconv1)
    pipeline.add(nvvidconv2)
    if is_aarch64():
        pipeline.add(transform)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(nvosd)
    # we link the elements together
    # file-source -> h264-parser -> nvh264-decoder ->
    # nvinfer -> nvvidconv -> nvosd -> video-renderer
    #  gst-launch-1.0 nvarguscamerasrc !
    # 'video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12'
    # ! nvvidconv flip-method=2 ! 'video/x-raw,width=960, height=616' ! nvvidconv ! nvegltransform ! nveglglessink -e
    print("Linking elements in the Pipeline \n")
    source.link(caps_picamsrc)
    caps_picamsrc.link(nvvidconv1)
    nvvidconv1.link(caps_nvvidconv1)
    caps_nvvidconv1.link(nvvidconv2)
    if is_aarch64():
        nvvidconv2.link(transform)
        transform.link(sink)
    else:
         nvvidconv2.link(sink)
    sinkpad = streammux.get_request_pad("sink_0")
    srcpad = caps_nvvidconv1.get_static_pad("src")
    srcpad.link(sinkpad)
    streammux.link(pgie)
    pgie.link(tracker)
    #tracker.link(nvvidconv2)
    tracker.link(nvosd)
    if is_aarch64():
        nvosd.link(transform)
    else:
        nvosd.link(sink)
    # create and event loop and feed gstreamer bus mesages to it
    loop = GObject.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    # Lets add probe to get informed of the meta data generated, we add probe to
    # the sink pad of the osd element, since by that time, the buffer would have
    # had got all the metadata.
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
      loop.run()
    except:
      pass
    # cleanup
    pipeline.set_state(Gst.State.NULL)
config file is :
# Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# Following properties are mandatory when engine files are not specified:
#   int8-calib-file(Only in INT8)
#   Caffemodel mandatory properties: model-file, proto-file, output-blob-names
#   UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
#   ONNX: onnx-file
# Mandatory properties for detectors:
#   num-detected-classes
# Optional properties for detectors:
#   enable-dbscan(Default=false), interval(Primary mode only, Default=0)
#   custom-lib-path,
#   parse-bbox-func-name
# Mandatory properties for classifiers:
#   classifier-threshold, is-classifier
# Optional properties for classifiers:
#   classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
#   operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
#   input-object-min-width, input-object-min-height, input-object-max-width,
#   input-object-max-height
# Following properties are always recommended:
#   batch-size(Default=1)
# Other optional properties:
#   net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
#   model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
#   mean-file, gie-unique-id(Default=0), offsets, gie-mode (Default=1 i.e. primary),
#   custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
uff-input-dims=3;720;1280;0
uff-input-blob-name=input_1
gpu-id=0
#model-engine-file=./Resnet10_head_460/resnet10_detector.trt
#tlt-model-file=./CAR_WEIGHTS/CAR_WEIGHTS.tlt
model-engine-file=./Resnet10_head_460/resnet10_detector.etlt_b8_fp16.engine
#tlt-encoded-model=./Resnet10_head_460/resnet10_detector.etlt
tlt-model-key="aWRubW10bjZsbTRyanFnZXFybjE0ZXFnMjc6MmYwYTNiOTQtYTIyOS00ZTNhLTg1ZGYtMTgxNWFiNGEzMz"
labelfile-path=./Resnet10_head_460/labels.txt
#int8-calib-file=./Resnet10_head_460/calibration.bin
batch-size=8
network-mode=1
process-mode=1
model-color-format=0
num-detected-classes=1
interval=0
gie-unique-id=1
#output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
output-blob-names=output_cov/Sigmoid;output_bbox/BiasAdd
[class-attrs-all]
threshold=0.1
eps=0.1
group-threshold=1
#roi-top-offset=20
#roi-bottom-offset=10
detected-min-w=180
detected-min-h=180
detected-max-w=300
detected-max-h=300
Did you use same model when running with .h264 input video and CSI camera?
Thanks amycao for response.
Yes my trained model was working fine with .h264 but when i am using it with CSI camera getting error like internal data stream error.
I had resolved it by changing the in file attaching below But I think it is wrong way.
There I am able to see camera streaming but it is not detecting anything and also unable to draw line on the frames. when I was running on .h264 file i was able to draw line able to detect object. :
def main(args):
    #     sys.exit(1)
    Gst.init(None)
    if not pipeline:
    if not source:
# Video convertor
    if not nvvidconv1:
    if not streammux:
    if not pgie:
    if not nvvidconv2:
    if not tracker:
    if not nvosd:
    if is_aarch64():
    if not sink:
    config.sections()
    if is_aarch64():
    pipeline.add(sink)
    pipeline.add(pgie)
    pipeline.add(nvosd)
    if is_aarch64():
    else:
    pgie.link(tracker)
    tracker.link(nvosd)
    if is_aarch64():
    else:
        nvosd.link(sink)
    if not osdsinkpad:
    try:
      loop.run()
    except:
      pass
    # cleanup
if __name__ == '__main__':
    sys.exit(main(sys.argv))
Please help me out I am stuck in this problem from long time.
Hi
Please refer to sources/apps/apps-common/src/deepstream_source_bin.c::create_camera_source_bin
where CSI camera source bin is created.
Please try the sample code in https://devtalk.nvidia.com/default/topic/1071110/deepstream-sdk/unable-to-run-inference-pipeline-using-csi-camera-source-in-deepstream-python-app/post/5435300/#5435300
