Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
2.1.0
[*] other - 2.2.0.12028
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Issue Description
We have been configuring a new Nvidia AGX Orin Devkit and followed the steps in the documentation to flash the Drive OS 6.0.6.
After successfully flashing, we are not getting the EULA acceptance window.
We have tried with ‘minicom’ command as well as by putty connection. We tried with multiple monitors by connecting with Nvidia Drive AGX Orin.
I am observed a couple of errors and warnings in the log, but not sure if those are relevant to my issue. Later, I re-flash the OS again, and now I am unable to change the directory to Nvidia folder in the platform via putty connection. Please let me know the log files path as well to understand the issue deeper. Please guide me to make the system up and get the display port enabled.
Error String
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Dear @rahul.k3,
Note that, If you have already accepted EULA on target, it will not show up next time. Please confirm if EULA is accepted earlier on target.
Are you able to connect to monitor earlier since you received the board?
If you are looking to get output GUI display of applications, you can use VNC to unblock your activity. Please see Driveworks 5.14 issue with DRIVE AGX Orin - #4 by SivaRamaKrishnaNV
That means, you could not find /home/nvidia/ ?
Could you share the login screen of tegra after reflash. Did you flash using docker or sdkmanager?
Hello SivaRamaKrishnaNV,
We tried to connect to the monitor initially, but not getting anything on the display. Later, we tried to flash the OS via SDK Manager.we are unsure about which OS the device was deliverd with. We Saw that there is no screen and decided to do the flashing.This is the first time we are configuring this system, and we are also not sure if it is initialized someone before.
I have flashed it using SDK Manager.
I could see the folder inside home.
Dear @rahul.k3,
Could you please upgrade to latest release(i.e DRIVE OS 6.0.10) if there is no dependency on DRIVE OS 6.0.6 and share display monitor details , boot log, display manager status on target.
To flash DRIVE OS 6.0.10 , please follow Install DRIVE OS 6.0.10.0 for NVIDIA Developer Users | NVIDIA Docs
Hello @SivaRamaKrishnaNV
I tried to get the latest release files, but it seems to be some access/permission issue is there. Hence, I am unable to download the 6.0.10 OS. could you please suggest any other alternatives here?
Dear @rahul.k3 ,
Could you please file new topic with error details when trying to access/flash DRIVE OS 6.0.10 to avoid cluttering of the issues.
Do we have any other alternatives to get the 6.0.10 or any other workaround? Or should I create a new topic under 6.0.10 here.
Also, please let me know if any specific logs will helpful from the current 6.0.6 OS installation?
Dear @rahul.k3 ,
There is no work around to get DRIVE OS 6.0.10. We provided latest releases via docker container. Please file new topic with error details.
If the issue is due to system state/SW, it gets fixed automatically after flashing. We encourage to use latest release to get latest features and fixed if there is no dependency on old release.
Dear @SivaRamaKrishnaNV
can I flash DRIVE OS 6.0.10 directly on to the Orin hardware, or should I follow the migration steps from 6.0.6 to 6.0.10?
Dear @rahul.k3 ,
You can flash DRIVE OS 6.0.10. I expect it to work.
