Unable to get MIPI CSI-2 Video
We have two custom JetsonTX2 carrier board, the boards are different in design. We also have a custom camera with MIPI output stream for which we have modified the reference drivers. The camera is working on the first board, however, not in the second board. On using v4l2-ctl bypass command we are getting following error:
CHANSEL_FAULT channel:0x00 frame:232 vi_tstamp:6565381486 data:0x00720200
  1. Does this mean we are not getting Pixel SOF?
  2. How else can we debug this issue? What other things should we look for to zero out the issue.
It tell the short line that could be the output pixel doesn’t as expected.
https://elinux.org/Jetson/l4t/Camera_BringUp
Hi @ShaneCCC,
I am using the same SOM on both the custom carrier boards (these carrier boards are of different design based), on the first board I am able to acquire the video, however, on using the same SOM on the second board, I am not getting any video and the traces output is as above.
Please check if the same CHANSEL_FAULT in the working carrier board.
Below is the output of traces from the working custom carrier board, I don’t see CHANSEL_FAULT here
 vi-output, ov56-7996  [004] ....   160.063296: tegra_channel_capture_frame: sof:159.953231296
 vi-output, ov56-7996  [004] ....   160.100568: tegra_channel_capture_frame: sof:159.990497952
     kworker/4:1-733   [004] ....   160.118016: rtcpu_vinotify_event: tstamp:5275304881 tag:CHANSEL_PXL_EOF channel:0x00 frame:230 vi_tstamp:5275304247 data:0x01df0002
     kworker/4:1-733   [004] ....   160.118020: rtcpu_vinotify_event: tstamp:5275304997 tag:ATOMP_FE channel:0x00 frame:230 vi_tstamp:5275304368 data:0x00000000
     kworker/4:1-733   [004] ....   160.118020: rtcpu_vinotify_event: tstamp:5275325924 tag:ATOMP_FS channel:0x00 frame:231 vi_tstamp:5275325412 data:0x00000000
     kworker/4:1-733   [004] ....   160.118021: rtcpu_vinotify_event: tstamp:5275326038 tag:CHANSEL_PXL_SOF channel:0x00 frame:231 vi_tstamp:5275325662 data:0x00000001
     kworker/4:1-733   [004] ....   160.118021: rtcpu_vinotify_event: tstamp:5276336070 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:231 vi_tstamp:5276335730 data:0x08000000
     kworker/4:1-733   [004] ....   160.118022: rtcpu_vinotify_event: tstamp:5276469452 tag:CHANSEL_PXL_EOF channel:0x00 frame:231 vi_tstamp:5276468829 data:0x01df0002
     kworker/4:1-733   [004] ....   160.118022: rtcpu_vinotify_event: tstamp:5276469566 tag:ATOMP_FE channel:0x00 frame:231 vi_tstamp:5276468956 data:0x00000000
     kworker/4:1-733   [004] ....   160.118023: rtcpu_vinotify_event: tstamp:5276490493 tag:ATOMP_FS channel:0x00 frame:232 vi_tstamp:5276489994 data:0x00000000
     kworker/4:1-733   [004] ....   160.118023: rtcpu_vinotify_event: tstamp:5276490606 tag:CHANSEL_PXL_SOF channel:0x00 frame:232 vi_tstamp:5276490245 data:0x00000001
     kworker/4:1-733   [004] ....   160.118024: rtcpu_vinotify_event: tstamp:5276494675 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:232 vi_tstamp:5276494348 data:0x08000000
 vi-output, ov56-7996  [004] ....   160.137794: tegra_channel_capture_frame: sof:160.27764768
     kworker/4:1-733   [004] ....   160.174063: rtos_queue_peek_from_isr_failed: tstamp:5277357382 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   160.174068: rtcpu_vinotify_event: tstamp:5277634051 tag:CHANSEL_PXL_EOF channel:0x00 frame:232 vi_tstamp:5277633417 data:0x01df0002
     kworker/4:1-733   [004] ....   160.174070: rtcpu_vinotify_event: tstamp:5277634167 tag:ATOMP_FE channel:0x00 frame:232 vi_tstamp:5277633538 data:0x00000000
     kworker/4:1-733   [004] ....   160.174071: rtcpu_vinotify_event: tstamp:5277655087 tag:ATOMP_FS channel:0x00 frame:233 vi_tstamp:5277654583 data:0x00000000
     kworker/4:1-733   [004] ....   160.174073: rtcpu_vinotify_event: tstamp:5277655200 tag:CHANSEL_PXL_SOF channel:0x00 frame:233 vi_tstamp:5277654833 data:0x00000001
 vi-output, ov56-7996  [005] ....   160.212341: tegra_channel_capture_frame: sof:160.102298400
     kworker/4:1-733   [004] ....   160.230012: rtcpu_vinotify_event: tstamp:5278798639 tag:CHANSEL_PXL_EOF channel:0x00 frame:233 vi_tstamp:5278798006 data:0x01df0002
     kworker/4:1-733   [004] ....   160.230015: rtcpu_vinotify_event: tstamp:5278798756 tag:ATOMP_FE channel:0x00 frame:233 vi_tstamp:5278798126 data:0x00000000
     kworker/4:1-733   [004] ....   160.230016: rtcpu_vinotify_event: tstamp:5279984265 tag:ATOMP_FS channel:0x00 frame:235 vi_tstamp:5279983758 data:0x00000000
     kworker/4:1-733   [004] ....   160.230017: rtcpu_vinotify_event: tstamp:5279984384 tag:CHANSEL_PXL_SOF channel:0x00 frame:235 vi_tstamp:5279984009 data:0x00000001
     kworker/4:1-733   [004] ....   160.230017: rtcpu_vinotify_event: tstamp:5279987565 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:235 vi_tstamp:5279987238 data:0x08000000
 vi-output, ov56-7996  [004] ....   160.249594: tegra_channel_capture_frame: sof:160.139565216
     kworker/4:1-733   [004] ....   160.286078: rtcpu_vinotify_event: tstamp:5281127810 tag:CHANSEL_PXL_EOF channel:0x00 frame:235 vi_tstamp:5281127176 data:0x01df0002
     kworker/4:1-733   [004] ....   160.286083: rtcpu_vinotify_event: tstamp:5281127926 tag:ATOMP_FE channel:0x00 frame:235 vi_tstamp:5281127297 data:0x00000000
     kworker/4:1-733   [004] ....   160.286085: rtcpu_vinotify_event: tstamp:5281148851 tag:ATOMP_FS channel:0x00 frame:236 vi_tstamp:5281148347 data:0x00000000
     kworker/4:1-733   [004] ....   160.286087: rtcpu_vinotify_event: tstamp:5281148964 tag:CHANSEL_PXL_SOF channel:0x00 frame:236 vi_tstamp:5281148597 data:0x00000001
 vi-output, ov56-7996  [005] ....   160.324129: tegra_channel_capture_frame: sof:160.214098656
     kworker/4:1-733   [004] ....   160.341986: rtcpu_vinotify_event: tstamp:5282292386 tag:CHANSEL_PXL_EOF channel:0x00 frame:236 vi_tstamp:5282291764 data:0x01df0002
     kworker/4:1-733   [004] ....   160.341989: rtcpu_vinotify_event: tstamp:5282292503 tag:ATOMP_FE channel:0x00 frame:236 vi_tstamp:5282291884 data:0x00000000
     kworker/4:1-733   [004] ....   160.341991: rtos_queue_peek_from_isr_failed: tstamp:5282357372 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   160.341992: rtcpu_vinotify_event: tstamp:5283478024 tag:ATOMP_FS channel:0x00 frame:238 vi_tstamp:5283477517 data:0x00000000
     kworker/4:1-733   [004] ....   160.341993: rtcpu_vinotify_event: tstamp:5283478143 tag:CHANSEL_PXL_SOF channel:0x00 frame:238 vi_tstamp:5283477767 data:0x00000001
     kworker/4:1-733   [004] ....   160.341993: rtcpu_vinotify_event: tstamp:5283480922 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:238 vi_tstamp:5283480590 data:0x08000000
 vi-output, ov56-7996  [005] ....   160.361417: tegra_channel_capture_frame: sof:160.251365472
     kworker/4:1-733   [004] ....   160.398062: rtcpu_vinotify_event: tstamp:5284621570 tag:CHANSEL_PXL_EOF channel:0x00 frame:238 vi_tstamp:5284620934 data:0x01df0002
     kworker/4:1-733   [004] ....   160.398067: rtcpu_vinotify_event: tstamp:5284621718 tag:ATOMP_FE channel:0x00 frame:238 vi_tstamp:5284621054 data:0x00000000
     kworker/4:1-733   [004] ....   160.398069: rtcpu_vinotify_event: tstamp:5284642614 tag:ATOMP_FS channel:0x00 frame:239 vi_tstamp:5284642098 data:0x00000000
     kworker/4:1-733   [004] ....   160.398071: rtcpu_vinotify_event: tstamp:5284642728 tag:CHANSEL_PXL_SOF channel:0x00 frame:239 vi_tstamp:5284642355 data:0x00000001
     kworker/4:1-733   [004] ....   160.398073: rtcpu_vinotify_event: tstamp:5285786155 tag:CHANSEL_PXL_EOF channel:0x00 frame:239 vi_tstamp:5285785522 data:0x01df0002
     kworker/4:1-733   [004] ....   160.398075: rtcpu_vinotify_event: tstamp:5285786272 tag:ATOMP_FE channel:0x00 frame:239 vi_tstamp:5285785642 data:0x00000000
 vi-output, ov56-7996  [005] ....   160.435930: tegra_channel_capture_frame: sof:160.325898912
     kworker/4:1-733   [004] ....   160.458032: rtcpu_vinotify_event: tstamp:5286971782 tag:ATOMP_FS channel:0x00 frame:241 vi_tstamp:5286971275 data:0x00000000
     kworker/4:1-733   [004] ....   160.458035: rtcpu_vinotify_event: tstamp:5286971897 tag:CHANSEL_PXL_SOF channel:0x00 frame:241 vi_tstamp:5286971525 data:0x00000001
     kworker/4:1-733   [004] ....   160.458036: rtcpu_vinotify_event: tstamp:5286974680 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:241 vi_tstamp:5286974353 data:0x08000000
     kworker/4:1-733   [004] ....   160.458038: rtos_queue_peek_from_isr_failed: tstamp:5287357370 queue:0x0b4b6398
 vi-output, ov56-7996  [004] ....   160.473194: tegra_channel_capture_frame: sof:160.363165760
     kworker/4:1-733   [004] ....   160.514095: rtcpu_vinotify_event: tstamp:5288115329 tag:CHANSEL_PXL_EOF channel:0x00 frame:241 vi_tstamp:5288114692 data:0x01df0002
     kworker/4:1-733   [004] ....   160.514099: rtcpu_vinotify_event: tstamp:5288115446 tag:ATOMP_FE channel:0x00 frame:241 vi_tstamp:5288114812 data:0x00000000
     kworker/4:1-733   [004] ....   160.514102: rtcpu_vinotify_event: tstamp:5288136368 tag:ATOMP_FS channel:0x00 frame:242 vi_tstamp:5288135857 data:0x00000000
     kworker/4:1-733   [004] ....   160.514104: rtcpu_vinotify_event: tstamp:5288136481 tag:CHANSEL_PXL_SOF channel:0x00 frame:242 vi_tstamp:5288136114 data:0x00000001
     kworker/4:1-733   [004] ....   160.514106: rtcpu_vinotify_event: tstamp:5289279913 tag:CHANSEL_PXL_EOF channel:0x00 frame:242 vi_tstamp:5289279280 data:0x01df0002
     kworker/4:1-733   [004] ....   160.514108: rtcpu_vinotify_event: tstamp:5289280030 tag:ATOMP_FE channel:0x00 frame:242 vi_tstamp:5289279401 data:0x00000000
 vi-output, ov56-7996  [000] ....   160.547748: tegra_channel_capture_frame: sof:160.437699200
     kworker/4:1-733   [004] ....   160.570011: rtcpu_vinotify_event: tstamp:5290465538 tag:ATOMP_FS channel:0x00 frame:243 vi_tstamp:5290465033 data:0x00000000
     kworker/4:1-733   [004] ....   160.570015: rtcpu_vinotify_event: tstamp:5290465656 tag:CHANSEL_PXL_SOF channel:0x00 frame:243 vi_tstamp:5290465284 data:0x00000001
     kworker/4:1-733   [004] ....   160.570017: rtcpu_vinotify_event: tstamp:5290469034 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:243 vi_tstamp:5290468706 data:0x08000000
 vi-output, ov56-7996  [004] ....   160.584991: tegra_channel_capture_frame: sof:160.474965792
     kworker/4:1-733   [004] ....   160.626067: rtcpu_vinotify_event: tstamp:5291609078 tag:CHANSEL_PXL_EOF channel:0x00 frame:243 vi_tstamp:5291608444 data:0x01df0002
     kworker/4:1-733   [004] ....   160.626072: rtcpu_vinotify_event: tstamp:5291609193 tag:ATOMP_FE channel:0x00 frame:243 vi_tstamp:5291608565 data:0x00000000
     kworker/4:1-733   [004] ....   160.626074: rtcpu_vinotify_event: tstamp:5291630109 tag:ATOMP_FS channel:0x00 frame:244 vi_tstamp:5291629615 data:0x00000000
     kworker/4:1-733   [004] ....   160.626076: rtcpu_vinotify_event: tstamp:5291630222 tag:CHANSEL_PXL_SOF channel:0x00 frame:244 vi_tstamp:5291629865 data:0x00000001
     kworker/4:1-733   [004] ....   160.626081: rtos_queue_peek_from_isr_failed: tstamp:5292357365 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   160.626083: rtcpu_vinotify_event: tstamp:5292773656 tag:CHANSEL_PXL_EOF channel:0x00 frame:244 vi_tstamp:5292773026 data:0x01df0002
     kworker/4:1-733   [004] ....   160.626085: rtcpu_vinotify_event: tstamp:5292773773 tag:ATOMP_FE channel:0x00 frame:244 vi_tstamp:5292773153 data:0x00000000
 vi-output, ov56-7996  [005] ....   160.659533: tegra_channel_capture_frame: sof:160.549499264
     kworker/4:1-733   [004] ....   160.682019: rtcpu_vinotify_event: tstamp:5293959293 tag:ATOMP_FS channel:0x00 frame:246 vi_tstamp:5293958785 data:0x00000000
     kworker/4:1-733   [004] ....   160.682023: rtcpu_vinotify_event: tstamp:5293959412 tag:CHANSEL_PXL_SOF channel:0x00 frame:246 vi_tstamp:5293959036 data:0x00000001
     kworker/4:1-733   [004] ....   160.682024: rtcpu_vinotify_event: tstamp:5293962304 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:246 vi_tstamp:5293961977 data:0x08000000
 vi-output, ov56-7996  [004] ....   160.696866: tegra_channel_capture_frame: sof:160.586766080
     kworker/4:1-733   [004] ....   160.738087: rtcpu_vinotify_event: tstamp:5295102837 tag:CHANSEL_PXL_EOF channel:0x00 frame:246 vi_tstamp:5295102202 data:0x01df0002
     kworker/4:1-733   [004] ....   160.738091: rtcpu_vinotify_event: tstamp:5295102952 tag:ATOMP_FE channel:0x00 frame:246 vi_tstamp:5295102323 data:0x00000000
     kworker/4:1-733   [004] ....   160.738093: rtcpu_vinotify_event: tstamp:5295123868 tag:ATOMP_FS channel:0x00 frame:247 vi_tstamp:5295123373 data:0x00000000
     kworker/4:1-733   [004] ....   160.738094: rtcpu_vinotify_event: tstamp:5295123980 tag:CHANSEL_PXL_SOF channel:0x00 frame:247 vi_tstamp:5295123624 data:0x00000001
     kworker/4:1-733   [004] ....   160.738095: rtcpu_vinotify_event: tstamp:5296267415 tag:CHANSEL_PXL_EOF channel:0x00 frame:247 vi_tstamp:5296266790 data:0x01df0002
     kworker/4:1-733   [004] ....   160.738096: rtcpu_vinotify_event: tstamp:5296267532 tag:ATOMP_FE channel:0x00 frame:247 vi_tstamp:5296266912 data:0x00000000
 vi-output, ov56-7996  [004] ....   160.771316: tegra_channel_capture_frame: sof:160.661299520
     kworker/4:1-733   [004] ....   160.794046: rtos_queue_peek_from_isr_failed: tstamp:5297357346 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   160.794053: rtcpu_vinotify_event: tstamp:5297453048 tag:ATOMP_FS channel:0x00 frame:249 vi_tstamp:5297452543 data:0x00000000
     kworker/4:1-733   [004] ....   160.794055: rtcpu_vinotify_event: tstamp:5297453163 tag:CHANSEL_PXL_SOF channel:0x00 frame:249 vi_tstamp:5297452794 data:0x00000001
     kworker/4:1-733   [004] ....   160.794057: rtcpu_vinotify_event: tstamp:5297455488 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:249 vi_tstamp:5297455161 data:0x08000000
 vi-output, ov56-7996  [004] ....   160.808617: tegra_channel_capture_frame: sof:160.698566336
 vi-output, ov56-7996  [000] ....   160.845953: tegra_channel_capture_frame: sof:160.735833152
     kworker/4:1-733   [004] ....   160.850097: rtcpu_vinotify_event: tstamp:5298596594 tag:CHANSEL_PXL_EOF channel:0x00 frame:249 vi_tstamp:5298595960 data:0x01df0002
     kworker/4:1-733   [004] ....   160.850101: rtcpu_vinotify_event: tstamp:5298596710 tag:ATOMP_FE channel:0x00 frame:249 vi_tstamp:5298596082 data:0x00000000
     kworker/4:1-733   [004] ....   160.850102: rtcpu_vinotify_event: tstamp:5298617643 tag:ATOMP_FS channel:0x00 frame:250 vi_tstamp:5298617131 data:0x00000000
     kworker/4:1-733   [004] ....   160.850102: rtcpu_vinotify_event: tstamp:5298617756 tag:CHANSEL_PXL_SOF channel:0x00 frame:250 vi_tstamp:5298617382 data:0x00000001
     kworker/4:1-733   [004] ....   160.850103: rtcpu_vinotify_event: tstamp:5299700693 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:250 vi_tstamp:5299700352 data:0x08000000
     kworker/4:1-733   [004] ....   160.850104: rtcpu_vinotify_event: tstamp:5299761166 tag:CHANSEL_PXL_EOF channel:0x00 frame:250 vi_tstamp:5299760549 data:0x01df0002
     kworker/4:1-733   [004] ....   160.850105: rtcpu_vinotify_event: tstamp:5299761279 tag:ATOMP_FE channel:0x00 frame:250 vi_tstamp:5299760669 data:0x00000000
     kworker/4:1-733   [004] ....   160.850106: rtcpu_vinotify_event: tstamp:5299782215 tag:ATOMP_FS channel:0x00 frame:251 vi_tstamp:5299781720 data:0x00000000
     kworker/4:1-733   [004] ....   160.850107: rtcpu_vinotify_event: tstamp:5299782329 tag:CHANSEL_PXL_SOF channel:0x00 frame:251 vi_tstamp:5299781970 data:0x00000001
     kworker/4:1-733   [004] ....   160.850107: rtcpu_vinotify_event: tstamp:5299819167 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:251 vi_tstamp:5299818828 data:0x08000000
 vi-output, ov56-7996  [005] ....   160.883139: tegra_channel_capture_frame: sof:160.773099808
     kworker/4:1-733   [004] ....   160.905992: rtcpu_vinotify_event: tstamp:5300925751 tag:CHANSEL_PXL_EOF channel:0x00 frame:251 vi_tstamp:5300925130 data:0x01df0002
     kworker/4:1-733   [004] ....   160.905996: rtcpu_vinotify_event: tstamp:5300925867 tag:ATOMP_FE channel:0x00 frame:251 vi_tstamp:5300925251 data:0x00000000
     kworker/4:1-733   [004] ....   160.905997: rtcpu_vinotify_event: tstamp:5300946807 tag:ATOMP_FS channel:0x00 frame:252 vi_tstamp:5300946301 data:0x00000000
     kworker/4:1-733   [004] ....   160.905997: rtcpu_vinotify_event: tstamp:5300946922 tag:CHANSEL_PXL_SOF channel:0x00 frame:252 vi_tstamp:5300946553 data:0x00000001
     kworker/4:1-733   [004] ....   160.905998: rtcpu_vinotify_event: tstamp:5300949998 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:252 vi_tstamp:5300949668 data:0x08000000
 vi-output, ov56-7996  [004] ....   160.920390: tegra_channel_capture_frame: sof:160.810366592
 vi-output, ov56-7996  [004] ....   160.957710: tegra_channel_capture_frame: sof:160.847633408
     kworker/4:1-733   [004] ....   160.962066: rtcpu_vinotify_event: tstamp:5302090351 tag:CHANSEL_PXL_EOF channel:0x00 frame:252 vi_tstamp:5302089719 data:0x01df0002
     kworker/4:1-733   [004] ....   160.962071: rtcpu_vinotify_event: tstamp:5302090466 tag:ATOMP_FE channel:0x00 frame:252 vi_tstamp:5302089840 data:0x00000000
     kworker/4:1-733   [004] ....   160.962072: rtcpu_vinotify_event: tstamp:5302111395 tag:ATOMP_FS channel:0x00 frame:253 vi_tstamp:5302110890 data:0x00000000
     kworker/4:1-733   [004] ....   160.962074: rtcpu_vinotify_event: tstamp:5302111507 tag:CHANSEL_PXL_SOF channel:0x00 frame:253 vi_tstamp:5302111140 data:0x00000001
     kworker/4:1-733   [004] ....   160.962077: rtos_queue_peek_from_isr_failed: tstamp:5302357343 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   160.962078: rtcpu_vinotify_event: tstamp:5303169030 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:253 vi_tstamp:5303168696 data:0x08000000
     kworker/4:1-733   [004] ....   160.962080: rtcpu_vinotify_event: tstamp:5303254923 tag:CHANSEL_PXL_EOF channel:0x00 frame:253 vi_tstamp:5303254300 data:0x01df0002
     kworker/4:1-733   [004] ....   160.962081: rtcpu_vinotify_event: tstamp:5303255039 tag:ATOMP_FE channel:0x00 frame:253 vi_tstamp:5303254427 data:0x00000000
     kworker/4:1-733   [004] ....   160.962082: rtcpu_vinotify_event: tstamp:5303275983 tag:ATOMP_FS channel:0x00 frame:254 vi_tstamp:5303275478 data:0x00000000
     kworker/4:1-733   [004] ....   160.962083: rtcpu_vinotify_event: tstamp:5303276096 tag:CHANSEL_PXL_SOF channel:0x00 frame:254 vi_tstamp:5303275728 data:0x00000001
     kworker/4:1-733   [004] ....   160.962084: rtcpu_vinotify_event: tstamp:5303280378 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:254 vi_tstamp:5303280049 data:0x08000000
 vi-output, ov56-7996  [004] ....   160.994927: tegra_channel_capture_frame: sof:160.884900032
     kworker/4:1-733   [004] ....   161.018002: rtcpu_vinotify_event: tstamp:5304419517 tag:CHANSEL_PXL_EOF channel:0x00 frame:254 vi_tstamp:5304418889 data:0x01df0002
     kworker/4:1-733   [004] ....   161.018005: rtcpu_vinotify_event: tstamp:5304419633 tag:ATOMP_FE channel:0x00 frame:254 vi_tstamp:5304419010 data:0x00000000
     kworker/4:1-733   [004] ....   161.018006: rtcpu_vinotify_event: tstamp:5304440550 tag:ATOMP_FS channel:0x00 frame:255 vi_tstamp:5304440060 data:0x00000000
     kworker/4:1-733   [004] ....   161.018007: rtcpu_vinotify_event: tstamp:5304440664 tag:CHANSEL_PXL_SOF channel:0x00 frame:255 vi_tstamp:5304440310 data:0x00000001
 vi-output, ov56-7996  [005] ....   161.069465: tegra_channel_capture_frame: sof:160.959433504
     kworker/4:1-733   [004] ....   161.073997: rtcpu_vinotify_event: tstamp:5305584109 tag:CHANSEL_PXL_EOF channel:0x00 frame:255 vi_tstamp:5305583477 data:0x01df0002
     kworker/4:1-733   [004] ....   161.073999: rtcpu_vinotify_event: tstamp:5305584226 tag:ATOMP_FE channel:0x00 frame:255 vi_tstamp:5305583597 data:0x00000000
     kworker/4:1-733   [004] ....   161.073999: rtcpu_vinotify_event: tstamp:5306769745 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5306769230 data:0x00000000
     kworker/4:1-733   [004] ....   161.074000: rtcpu_vinotify_event: tstamp:5306769860 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:5306769481 data:0x00000001
     kworker/4:1-733   [004] ....   161.074000: rtcpu_vinotify_event: tstamp:5306772670 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:1 vi_tstamp:5306772341 data:0x08000000
 vi-output, ov56-7996  [005] ....   161.106727: tegra_channel_capture_frame: sof:160.996700288
     kworker/4:1-733   [004] ....   161.129982: rtos_queue_peek_from_isr_failed: tstamp:5307357347 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   161.129984: rtcpu_vinotify_event: tstamp:5307913270 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:5307912647 data:0x01df0002
     kworker/4:1-733   [004] ....   161.129985: rtcpu_vinotify_event: tstamp:5307913391 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5307912767 data:0x00000000
     kworker/4:1-733   [004] ....   161.129986: rtcpu_vinotify_event: tstamp:5307934312 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:5307933818 data:0x00000000
     kworker/4:1-733   [004] ....   161.129987: rtcpu_vinotify_event: tstamp:5307934425 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:5307934068 data:0x00000001
 vi-output, ov56-7996  [005] ....   161.181275: tegra_channel_capture_frame: sof:161.71233728
     kworker/4:1-733   [004] ....   161.186001: rtcpu_vinotify_event: tstamp:5309077861 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:5309077229 data:0x01df0002
     kworker/4:1-733   [004] ....   161.186003: rtcpu_vinotify_event: tstamp:5309077977 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:5309077355 data:0x00000000
     kworker/4:1-733   [004] ....   161.186004: rtcpu_vinotify_event: tstamp:5310263491 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:5310262988 data:0x00000000
     kworker/4:1-733   [004] ....   161.186005: rtcpu_vinotify_event: tstamp:5310263607 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:5310263238 data:0x00000001
     kworker/4:1-733   [004] ....   161.186006: rtcpu_vinotify_event: tstamp:5310266732 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:4 vi_tstamp:5310266406 data:0x08000000
 vi-output, ov56-7996  [004] ....   161.218531: tegra_channel_capture_frame: sof:161.108500576
     kworker/4:1-733   [004] ....   161.242056: rtcpu_vinotify_event: tstamp:5311407041 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:5311406405 data:0x01df0002
     kworker/4:1-733   [004] ....   161.242061: rtcpu_vinotify_event: tstamp:5311407156 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:5311406526 data:0x00000000
     kworker/4:1-733   [004] ....   161.242063: rtcpu_vinotify_event: tstamp:5311428081 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:5311427576 data:0x00000000
     kworker/4:1-733   [004] ....   161.242065: rtcpu_vinotify_event: tstamp:5311428194 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:5311427827 data:0x00000001
 vi-output, ov56-7996  [005] ....   161.293068: tegra_channel_capture_frame: sof:161.183034016
     kworker/4:1-733   [004] ....   161.298066: rtos_queue_peek_from_isr_failed: tstamp:5312357335 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   161.298071: rtcpu_vinotify_event: tstamp:5312571618 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:5312570987 data:0x01df0002
     kworker/4:1-733   [004] ....   161.298072: rtcpu_vinotify_event: tstamp:5312571735 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:5312571114 data:0x00000000
     kworker/4:1-733   [004] ....   161.298072: rtcpu_vinotify_event: tstamp:5313757254 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:5313756746 data:0x00000000
     kworker/4:1-733   [004] ....   161.298073: rtcpu_vinotify_event: tstamp:5313757373 tag:CHANSEL_PXL_SOF channel:0x00 frame:7 vi_tstamp:5313756997 data:0x00000001
     kworker/4:1-733   [004] ....   161.298074: rtcpu_vinotify_event: tstamp:5313760253 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:7 vi_tstamp:5313759916 data:0x08000000
 vi-output, ov56-7996  [000] ....   161.330338: tegra_channel_capture_frame: sof:161.220300832
     kworker/4:1-733   [004] ....   161.354055: rtcpu_vinotify_event: tstamp:5314900797 tag:CHANSEL_PXL_EOF channel:0x00 frame:7 vi_tstamp:5314900163 data:0x01df0002
     kworker/4:1-733   [004] ....   161.354060: rtcpu_vinotify_event: tstamp:5314900913 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:5314900284 data:0x00000000
     kworker/4:1-733   [004] ....   161.354062: rtcpu_vinotify_event: tstamp:5314921855 tag:ATOMP_FS channel:0x00 frame:8 vi_tstamp:5314921334 data:0x00000000
     kworker/4:1-733   [004] ....   161.354065: rtcpu_vinotify_event: tstamp:5314921981 tag:CHANSEL_PXL_SOF channel:0x00 frame:8 vi_tstamp:5314921585 data:0x00000001
 vi-output, ov56-7996  [000] ....   161.404877: tegra_channel_capture_frame: sof:161.294834272
     kworker/4:1-733   [004] ....   161.410018: rtcpu_vinotify_event: tstamp:5316065380 tag:CHANSEL_PXL_EOF channel:0x00 frame:8 vi_tstamp:5316064745 data:0x01df0002
     kworker/4:1-733   [004] ....   161.410022: rtcpu_vinotify_event: tstamp:5316065496 tag:ATOMP_FE channel:0x00 frame:8 vi_tstamp:5316064872 data:0x00000000
     kworker/4:1-733   [004] ....   161.410022: rtcpu_vinotify_event: tstamp:5317251011 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:5317250504 data:0x00000000
     kworker/4:1-733   [004] ....   161.410023: rtcpu_vinotify_event: tstamp:5317251128 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:5317250755 data:0x00000001
     kworker/4:1-733   [004] ....   161.410023: rtcpu_vinotify_event: tstamp:5317254267 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:10 vi_tstamp:5317253940 data:0x08000000
     kworker/4:1-733   [004] ....   161.410026: rtos_queue_peek_from_isr_failed: tstamp:5317357347 queue:0x0b4b6398
 vi-output, ov56-7996  [000] ....   161.442144: tegra_channel_capture_frame: sof:161.332101088
     kworker/4:1-733   [004] ....   161.466025: rtcpu_vinotify_event: tstamp:5318394556 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:5318393922 data:0x01df0002
     kworker/4:1-733   [004] ....   161.466034: rtcpu_vinotify_event: tstamp:5318394674 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:5318394042 data:0x00000000
     kworker/4:1-733   [004] ....   161.466036: rtcpu_vinotify_event: tstamp:5318415594 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:5318415093 data:0x00000000
     kworker/4:1-733   [004] ....   161.466038: rtcpu_vinotify_event: tstamp:5318415706 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:5318415343 data:0x00000001
 vi-output, ov56-7996  [000] ....   161.516676: tegra_channel_capture_frame: sof:161.406634528
     kworker/4:1-733   [004] ....   161.521996: rtcpu_vinotify_event: tstamp:5319559140 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:5319558503 data:0x01df0002
     kworker/4:1-733   [004] ....   161.521998: rtcpu_vinotify_event: tstamp:5319559257 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:5319558625 data:0x00000000
     kworker/4:1-733   [004] ....   161.521998: rtcpu_vinotify_event: tstamp:5320744778 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:5320744263 data:0x00000000
     kworker/4:1-733   [004] ....   161.521999: rtcpu_vinotify_event: tstamp:5320744893 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:5320744513 data:0x00000001
     kworker/4:1-733   [004] ....   161.521999: rtcpu_vinotify_event: tstamp:5320747977 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:13 vi_tstamp:5320747649 data:0x08000000
 vi-output, ov56-7996  [000] ....   161.553939: tegra_channel_capture_frame: sof:161.443901344
     kworker/4:1-733   [004] ....   161.578081: rtcpu_vinotify_event: tstamp:5321888321 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:5321887686 data:0x01df0002
     kworker/4:1-733   [004] ....   161.578087: rtcpu_vinotify_event: tstamp:5321888437 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:5321887807 data:0x00000000
     kworker/4:1-733   [004] ....   161.578089: rtcpu_vinotify_event: tstamp:5321909343 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:5321908851 data:0x00000000
     kworker/4:1-733   [004] ....   161.578091: rtcpu_vinotify_event: tstamp:5321909456 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:5321909101 data:0x00000001
     kworker/4:1-733   [004] ....   161.578096: rtos_queue_peek_from_isr_failed: tstamp:5322357306 queue:0x0b4b6398
 vi-output, ov56-7996  [000] ....   161.628470: tegra_channel_capture_frame: sof:161.518434784
     kworker/4:1-733   [004] ....   161.634002: rtcpu_vinotify_event: tstamp:5323052907 tag:CHANSEL_PXL_EOF channel:0x00 frame:14 vi_tstamp:5323052268 data:0x01df0002
     kworker/4:1-733   [004] ....   161.634004: rtcpu_vinotify_event: tstamp:5323053023 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:5323052395 data:0x00000000
     kworker/4:1-733   [004] ....   161.634005: rtcpu_vinotify_event: tstamp:5324238526 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:5324238021 data:0x00000000
     kworker/4:1-733   [004] ....   161.634005: rtcpu_vinotify_event: tstamp:5324238642 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:5324238271 data:0x00000001
     kworker/4:1-733   [004] ....   161.634006: rtcpu_vinotify_event: tstamp:5324241553 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:16 vi_tstamp:5324241225 data:0x08000000
 vi-output, ov56-7996  [004] ....   161.665737: tegra_channel_capture_frame: sof:161.555701632
     kworker/4:1-733   [004] ....   161.690106: rtcpu_vinotify_event: tstamp:5325382080 tag:CHANSEL_PXL_EOF channel:0x00 frame:16 vi_tstamp:5325381444 data:0x01df0002
     kworker/4:1-733   [004] ....   161.690110: rtcpu_vinotify_event: tstamp:5325382196 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:5325381565 data:0x00000000
     kworker/4:1-733   [004] ....   161.690112: rtcpu_vinotify_event: tstamp:5325403101 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:5325402609 data:0x00000000
     kworker/4:1-733   [004] ....   161.690114: rtcpu_vinotify_event: tstamp:5325403214 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:5325402860 data:0x00000001
 vi-output, ov56-7996  [005] ....   161.703045: tegra_channel_capture_frame: sof:161.592968448
 vi-output, ov56-7996  [003] ....   161.741502: tegra_channel_capture_frame: sof:161.630235072
     kworker/4:1-733   [004] ....   161.746020: rtcpu_vinotify_event: tstamp:5326526314 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:17 vi_tstamp:5326525975 data:0x08000000
     kworker/4:1-733   [004] ....   161.746023: rtcpu_vinotify_event: tstamp:5326546643 tag:CHANSEL_PXL_EOF channel:0x00 frame:17 vi_tstamp:5326546026 data:0x01df0002
     kworker/4:1-733   [004] ....   161.746024: rtcpu_vinotify_event: tstamp:5326546767 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:5326546153 data:0x00000000
     kworker/4:1-733   [004] ....   161.746024: rtcpu_vinotify_event: tstamp:5326567685 tag:ATOMP_FS channel:0x00 frame:18 vi_tstamp:5326567191 data:0x00000000
     kworker/4:1-733   [004] ....   161.746025: rtcpu_vinotify_event: tstamp:5326567800 tag:CHANSEL_PXL_SOF channel:0x00 frame:18 vi_tstamp:5326567448 data:0x00000001
     kworker/4:1-733   [004] ....   161.746025: rtcpu_vinotify_event: tstamp:5326631529 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:18 vi_tstamp:5326631188 data:0x08000000
     kworker/4:1-733   [004] ....   161.746028: rtos_queue_peek_from_isr_failed: tstamp:5327357304 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   161.746028: rtcpu_vinotify_event: tstamp:5327711235 tag:CHANSEL_PXL_EOF channel:0x00 frame:18 vi_tstamp:5327710615 data:0x01df0002
     kworker/4:1-733   [004] ....   161.746029: rtcpu_vinotify_event: tstamp:5327711350 tag:ATOMP_FE channel:0x00 frame:18 vi_tstamp:5327710735 data:0x00000000
     kworker/4:1-733   [004] ....   161.746029: rtcpu_vinotify_event: tstamp:5327732284 tag:ATOMP_FS channel:0x00 frame:19 vi_tstamp:5327731779 data:0x00000000
     kworker/4:1-733   [004] ....   161.746030: rtcpu_vinotify_event: tstamp:5327732399 tag:CHANSEL_PXL_SOF channel:0x00 frame:19 vi_tstamp:5327732030 data:0x00000001
     kworker/4:1-733   [004] ....   161.746030: rtcpu_vinotify_event: tstamp:5327773852 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:19 vi_tstamp:5327773516 data:0x08000000
 vi-output, ov56-7996  [004] ....   161.777527: tegra_channel_capture_frame: sof:161.667501888
     kworker/4:1-733   [004] ....   161.802092: rtcpu_vinotify_event: tstamp:5328875835 tag:CHANSEL_PXL_EOF channel:0x00 frame:19 vi_tstamp:5328875203 data:0x01df0002
     kworker/4:1-733   [004] ....   161.802096: rtcpu_vinotify_event: tstamp:5328875951 tag:ATOMP_FE channel:0x00 frame:19 vi_tstamp:5328875323 data:0x00000000
     kworker/4:1-733   [004] ....   161.802097: rtcpu_vinotify_event: tstamp:5328896879 tag:ATOMP_FS channel:0x00 frame:20 vi_tstamp:5328896367 data:0x00000000
     kworker/4:1-733   [004] ....   161.802098: rtcpu_vinotify_event: tstamp:5328896992 tag:CHANSEL_PXL_SOF channel:0x00 frame:20 vi_tstamp:5328896618 data:0x00000001
 vi-output, ov56-7996  [004] ....   161.814805: tegra_channel_capture_frame: sof:161.704768704
 vi-output, ov56-7996  [004] ....   161.852070: tegra_channel_capture_frame: sof:161.742035328
     kworker/4:1-733   [004] ....   161.858006: rtcpu_vinotify_event: tstamp:5329933374 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:20 vi_tstamp:5329933035 data:0x08000000
     kworker/4:1-733   [004] ....   161.858007: rtcpu_vinotify_event: tstamp:5330040409 tag:CHANSEL_PXL_EOF channel:0x00 frame:20 vi_tstamp:5330039785 data:0x01df0002
     kworker/4:1-733   [004] ....   161.858008: rtcpu_vinotify_event: tstamp:5330040525 tag:ATOMP_FE channel:0x00 frame:20 vi_tstamp:5330039911 data:0x00000000
     kworker/4:1-733   [004] ....   161.858009: rtcpu_vinotify_event: tstamp:5330061454 tag:ATOMP_FS channel:0x00 frame:21 vi_tstamp:5330060956 data:0x00000000
     kworker/4:1-733   [004] ....   161.858010: rtcpu_vinotify_event: tstamp:5330061573 tag:CHANSEL_PXL_SOF channel:0x00 frame:21 vi_tstamp:5330061206 data:0x00000001
     kworker/4:1-733   [004] ....   161.858010: rtcpu_vinotify_event: tstamp:5330064697 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:21 vi_tstamp:5330064369 data:0x08000000
     kworker/4:1-733   [004] ....   161.858011: rtcpu_vinotify_event: tstamp:5331205008 tag:CHANSEL_PXL_EOF channel:0x00 frame:21 vi_tstamp:5331204373 data:0x01df0002
     kworker/4:1-733   [004] ....   161.858012: rtcpu_vinotify_event: tstamp:5331205122 tag:ATOMP_FE channel:0x00 frame:21 vi_tstamp:5331204493 data:0x00000000
     kworker/4:1-733   [004] ....   161.858012: rtcpu_vinotify_event: tstamp:5331226049 tag:ATOMP_FS channel:0x00 frame:22 vi_tstamp:5331225537 data:0x00000000
     kworker/4:1-733   [004] ....   161.858013: rtcpu_vinotify_event: tstamp:5331226162 tag:CHANSEL_PXL_SOF channel:0x00 frame:22 vi_tstamp:5331225788 data:0x00000001
     kworker/4:1-733   [004] ....   161.914056: rtos_queue_peek_from_isr_failed: tstamp:5332357308 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   161.914061: rtcpu_vinotify_event: tstamp:5332369585 tag:CHANSEL_PXL_EOF channel:0x00 frame:22 vi_tstamp:5332368960 data:0x01df0002
     kworker/4:1-733   [004] ....   161.914063: rtcpu_vinotify_event: tstamp:5332369701 tag:ATOMP_FE channel:0x00 frame:22 vi_tstamp:5332369081 data:0x00000000
 vi-output, ov56-7996  [000] ....   161.926620: tegra_channel_capture_frame: sof:161.816568960
 vi-output, ov56-7996  [004] ....   161.963869: tegra_channel_capture_frame: sof:161.853835584
     kworker/4:1-733   [004] ....   161.970006: rtcpu_vinotify_event: tstamp:5333555221 tag:ATOMP_FS channel:0x00 frame:24 vi_tstamp:5333554714 data:0x00000000
     kworker/4:1-733   [004] ....   161.970009: rtcpu_vinotify_event: tstamp:5333555340 tag:CHANSEL_PXL_SOF channel:0x00 frame:24 vi_tstamp:5333554964 data:0x00000001
     kworker/4:1-733   [004] ....   161.970010: rtcpu_vinotify_event: tstamp:5333558831 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:24 vi_tstamp:5333558505 data:0x08000000
     kworker/4:1-733   [004] ....   161.970012: rtcpu_vinotify_event: tstamp:5334698766 tag:CHANSEL_PXL_EOF channel:0x00 frame:24 vi_tstamp:5334698131 data:0x01df0002
     kworker/4:1-733   [004] ....   161.970013: rtcpu_vinotify_event: tstamp:5334698880 tag:ATOMP_FE channel:0x00 frame:24 vi_tstamp:5334698251 data:0x00000000
     kworker/4:1-733   [004] ....   161.970015: rtcpu_vinotify_event: tstamp:5334719802 tag:ATOMP_FS channel:0x00 frame:25 vi_tstamp:5334719296 data:0x00000000
     kworker/4:1-733   [004] ....   161.970016: rtcpu_vinotify_event: tstamp:5334719916 tag:CHANSEL_PXL_SOF channel:0x00 frame:25 vi_tstamp:5334719546 data:0x00000001
     kworker/4:1-733   [004] ....   162.026068: rtcpu_vinotify_event: tstamp:5335863354 tag:CHANSEL_PXL_EOF channel:0x00 frame:25 vi_tstamp:5335862718 data:0x01df0002
     kworker/4:1-733   [004] ....   162.026072: rtcpu_vinotify_event: tstamp:5335863471 tag:ATOMP_FE channel:0x00 frame:25 vi_tstamp:5335862840 data:0x00000000
 vi-output, ov56-7996  [005] ....   162.038387: tegra_channel_capture_frame: sof:161.928369248
 vi-output, ov56-7996  [005] ....   162.075663: tegra_channel_capture_frame: sof:161.965635840
     kworker/4:1-733   [004] ....   162.082015: rtcpu_vinotify_event: tstamp:5337048978 tag:ATOMP_FS channel:0x00 frame:27 vi_tstamp:5337048472 data:0x00000000
     kworker/4:1-733   [004] ....   162.082017: rtcpu_vinotify_event: tstamp:5337049095 tag:CHANSEL_PXL_SOF channel:0x00 frame:27 vi_tstamp:5337048723 data:0x00000001
     kworker/4:1-733   [004] ....   162.082018: rtcpu_vinotify_event: tstamp:5337051503 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:27 vi_tstamp:5337051176 data:0x08000000
     kworker/4:1-733   [004] ....   162.082020: rtos_queue_peek_from_isr_failed: tstamp:5337357289 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   162.082022: rtcpu_vinotify_event: tstamp:5338192527 tag:CHANSEL_PXL_EOF channel:0x00 frame:27 vi_tstamp:5338191889 data:0x01df0002
     kworker/4:1-733   [004] ....   162.082022: rtcpu_vinotify_event: tstamp:5338192645 tag:ATOMP_FE channel:0x00 frame:27 vi_tstamp:5338192016 data:0x00000000
     kworker/4:1-733   [004] ....   162.082023: rtcpu_vinotify_event: tstamp:5338213567 tag:ATOMP_FS channel:0x00 frame:28 vi_tstamp:5338213054 data:0x00000000
     kworker/4:1-733   [004] ....   162.082024: rtcpu_vinotify_event: tstamp:5338213681 tag:CHANSEL_PXL_SOF channel:0x00 frame:28 vi_tstamp:5338213304 data:0x00000001
     kworker/4:1-733   [004] ....   162.138069: rtcpu_vinotify_event: tstamp:5339357111 tag:CHANSEL_PXL_EOF channel:0x00 frame:28 vi_tstamp:5339356477 data:0x01df0002
     kworker/4:1-733   [004] ....   162.138075: rtcpu_vinotify_event: tstamp:5339357228 tag:ATOMP_FE channel:0x00 frame:28 vi_tstamp:5339356598 data:0x00000000
 vi-output, ov56-7996  [005] ....   162.150195: tegra_channel_capture_frame: sof:162.40169504
 vi-output, ov56-7996  [004] ....   162.187463: tegra_channel_capture_frame: sof:162.77436320
     kworker/4:1-733   [004] ....   162.194024: rtcpu_vinotify_event: tstamp:5340542733 tag:ATOMP_FS channel:0x00 frame:30 vi_tstamp:5340542230 data:0x00000000
     kworker/4:1-733   [004] ....   162.194026: rtcpu_vinotify_event: tstamp:5340542850 tag:CHANSEL_PXL_SOF channel:0x00 frame:30 vi_tstamp:5340542481 data:0x00000001
     kworker/4:1-733   [004] ....   162.194027: rtcpu_vinotify_event: tstamp:5340545460 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:30 vi_tstamp:5340545129 data:0x08000000
     kworker/4:1-733   [004] ....   162.194027: rtcpu_vinotify_event: tstamp:5341686283 tag:CHANSEL_PXL_EOF channel:0x00 frame:30 vi_tstamp:5341685647 data:0x01df0002
     kworker/4:1-733   [004] ....   162.194028: rtcpu_vinotify_event: tstamp:5341686399 tag:ATOMP_FE channel:0x00 frame:30 vi_tstamp:5341685774 data:0x00000000
     kworker/4:1-733   [004] ....   162.194029: rtcpu_vinotify_event: tstamp:5341707322 tag:ATOMP_FS channel:0x00 frame:31 vi_tstamp:5341706819 data:0x00000000
     kworker/4:1-733   [004] ....   162.194030: rtcpu_vinotify_event: tstamp:5341707436 tag:CHANSEL_PXL_SOF channel:0x00 frame:31 vi_tstamp:5341707069 data:0x00000001
     kworker/4:1-733   [004] ....   162.250029: rtos_queue_peek_from_isr_failed: tstamp:5342357296 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   162.250033: rtcpu_vinotify_event: tstamp:5342850876 tag:CHANSEL_PXL_EOF channel:0x00 frame:31 vi_tstamp:5342850241 data:0x01df0002
     kworker/4:1-733   [004] ....   162.250034: rtcpu_vinotify_event: tstamp:5342850994 tag:ATOMP_FE channel:0x00 frame:31 vi_tstamp:5342850362 data:0x00000000
 vi-output, ov56-7996  [005] ....   162.262026: tegra_channel_capture_frame: sof:162.151969952
 vi-output, ov56-7996  [004] ....   162.299270: tegra_channel_capture_frame: sof:162.189236768
     kworker/4:1-733   [004] ....   162.305988: rtcpu_vinotify_event: tstamp:5344036500 tag:ATOMP_FS channel:0x00 frame:33 vi_tstamp:5344035994 data:0x00000000
     kworker/4:1-733   [004] ....   162.305991: rtcpu_vinotify_event: tstamp:5344036619 tag:CHANSEL_PXL_SOF channel:0x00 frame:33 vi_tstamp:5344036245 data:0x00000001
     kworker/4:1-733   [004] ....   162.305993: rtcpu_vinotify_event: tstamp:5344040181 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:33 vi_tstamp:5344039855 data:0x08000000
     kworker/4:1-733   [004] ....   162.305994: rtcpu_vinotify_event: tstamp:5345180045 tag:CHANSEL_PXL_EOF channel:0x00 frame:33 vi_tstamp:5345179411 data:0x01df0002
     kworker/4:1-733   [004] ....   162.305995: rtcpu_vinotify_event: tstamp:5345180160 tag:ATOMP_FE channel:0x00 frame:33 vi_tstamp:5345179538 data:0x00000000
     kworker/4:1-733   [004] ....   162.305996: rtcpu_vinotify_event: tstamp:5345201081 tag:ATOMP_FS channel:0x00 frame:34 vi_tstamp:5345200583 data:0x00000000
     kworker/4:1-733   [004] ....   162.305997: rtcpu_vinotify_event: tstamp:5345201194 tag:CHANSEL_PXL_SOF channel:0x00 frame:34 vi_tstamp:5345200833 data:0x00000001
     kworker/4:1-733   [004] ....   162.361990: rtcpu_vinotify_event: tstamp:5346344634 tag:CHANSEL_PXL_EOF channel:0x00 frame:34 vi_tstamp:5346344000 data:0x01df0002
     kworker/4:1-733   [004] ....   162.361995: rtcpu_vinotify_event: tstamp:5346344761 tag:ATOMP_FE channel:0x00 frame:34 vi_tstamp:5346344120 data:0x00000000
 vi-output, ov56-7996  [005] ....   162.373814: tegra_channel_capture_frame: sof:162.263770208
 vi-output, ov56-7996  [004] ....   162.411068: tegra_channel_capture_frame: sof:162.301037248
     kworker/4:1-733   [004] ....   162.418010: rtos_queue_peek_from_isr_failed: tstamp:5347357277 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   162.418014: rtcpu_vinotify_event: tstamp:5347530256 tag:ATOMP_FS channel:0x00 frame:36 vi_tstamp:5347529753 data:0x00000000
     kworker/4:1-733   [004] ....   162.418015: rtcpu_vinotify_event: tstamp:5347530373 tag:CHANSEL_PXL_SOF channel:0x00 frame:36 vi_tstamp:5347530003 data:0x00000001
     kworker/4:1-733   [004] ....   162.418016: rtcpu_vinotify_event: tstamp:5347533577 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:36 vi_tstamp:5347533249 data:0x08000000
     kworker/4:1-733   [004] ....   162.418017: rtcpu_vinotify_event: tstamp:5348673813 tag:CHANSEL_PXL_EOF channel:0x00 frame:36 vi_tstamp:5348673176 data:0x01df0002
     kworker/4:1-733   [004] ....   162.418018: rtcpu_vinotify_event: tstamp:5348673928 tag:ATOMP_FE channel:0x00 frame:36 vi_tstamp:5348673303 data:0x00000000
     kworker/4:1-733   [004] ....   162.418019: rtcpu_vinotify_event: tstamp:5348694840 tag:ATOMP_FS channel:0x00 frame:37 vi_tstamp:5348694341 data:0x00000000
     kworker/4:1-733   [004] ....   162.418020: rtcpu_vinotify_event: tstamp:5348694953 tag:CHANSEL_PXL_SOF channel:0x00 frame:37 vi_tstamp:5348694598 data:0x00000001
     kworker/4:1-733   [004] ....   162.474061: rtcpu_vinotify_event: tstamp:5349838385 tag:CHANSEL_PXL_EOF channel:0x00 frame:37 vi_tstamp:5349837764 data:0x01df0002
     kworker/4:1-733   [004] ....   162.474066: rtcpu_vinotify_event: tstamp:5349838502 tag:ATOMP_FE channel:0x00 frame:37 vi_tstamp:5349837891 data:0x00000000
 vi-output, ov56-7996  [000] ....   162.485586: tegra_channel_capture_frame: sof:162.375570688
 vi-output, ov56-7996  [004] ....   162.522945: tegra_channel_capture_frame: sof:162.412837504
     kworker/4:1-733   [004] ....   162.530051: rtcpu_vinotify_event: tstamp:5351024024 tag:ATOMP_FS channel:0x00 frame:39 vi_tstamp:5351023517 data:0x00000000
     kworker/4:1-733   [004] ....   162.530054: rtcpu_vinotify_event: tstamp:5351024142 tag:CHANSEL_PXL_SOF channel:0x00 frame:39 vi_tstamp:5351023768 data:0x00000001
     kworker/4:1-733   [004] ....   162.530056: rtcpu_vinotify_event: tstamp:5351026427 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:39 vi_tstamp:5351026099 data:0x08000000
     kworker/4:1-733   [004] ....   162.530057: rtcpu_vinotify_event: tstamp:5352167571 tag:CHANSEL_PXL_EOF channel:0x00 frame:39 vi_tstamp:5352166934 data:0x01df0002
     kworker/4:1-733   [004] ....   162.530059: rtcpu_vinotify_event: tstamp:5352167686 tag:ATOMP_FE channel:0x00 frame:39 vi_tstamp:5352167055 data:0x00000000
     kworker/4:1-733   [004] ....   162.530060: rtcpu_vinotify_event: tstamp:5352188612 tag:ATOMP_FS channel:0x00 frame:40 vi_tstamp:5352188106 data:0x00000000
     kworker/4:1-733   [004] ....   162.530061: rtcpu_vinotify_event: tstamp:5352188726 tag:CHANSEL_PXL_SOF channel:0x00 frame:40 vi_tstamp:5352188356 data:0x00000001
     kworker/4:1-733   [004] ....   162.530065: rtos_queue_peek_from_isr_failed: tstamp:5352357278 queue:0x0b4b6398
 vi-output, ov56-7996  [005] ....   162.560177: tegra_channel_capture_frame: sof:162.450104320
     kworker/4:1-733   [004] ....   162.586036: rtcpu_vinotify_event: tstamp:5353246215 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:40 vi_tstamp:5353245879 data:0x08000000
     kworker/4:1-733   [004] ....   162.586040: rtcpu_vinotify_event: tstamp:5353332145 tag:CHANSEL_PXL_EOF channel:0x00 frame:40 vi_tstamp:5353331522 data:0x01df0002
     kworker/4:1-733   [004] ....   162.586040: rtcpu_vinotify_event: tstamp:5353332263 tag:ATOMP_FE channel:0x00 frame:40 vi_tstamp:5353331643 data:0x00000000
     kworker/4:1-733   [004] ....   162.586041: rtcpu_vinotify_event: tstamp:5353353197 tag:ATOMP_FS channel:0x00 frame:41 vi_tstamp:5353352694 data:0x00000000
     kworker/4:1-733   [004] ....   162.586041: rtcpu_vinotify_event: tstamp:5353353312 tag:CHANSEL_PXL_SOF channel:0x00 frame:41 vi_tstamp:5353352944 data:0x00000001
     kworker/4:1-733   [004] ....   162.586042: rtcpu_vinotify_event: tstamp:5353357551 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:41 vi_tstamp:5353357226 data:0x08000000
 vi-output, ov56-7996  [004] ....   162.634655: tegra_channel_capture_frame: sof:162.524637760
     kworker/4:1-733   [004] ....   162.641997: rtcpu_vinotify_event: tstamp:5354496733 tag:CHANSEL_PXL_EOF channel:0x00 frame:41 vi_tstamp:5354496110 data:0x01df0002
     kworker/4:1-733   [004] ....   162.641998: rtcpu_vinotify_event: tstamp:5354496848 tag:ATOMP_FE channel:0x00 frame:41 vi_tstamp:5354496231 data:0x00000000
     kworker/4:1-733   [004] ....   162.641999: rtcpu_vinotify_event: tstamp:5354517783 tag:ATOMP_FS channel:0x00 frame:42 vi_tstamp:5354517281 data:0x00000000
     kworker/4:1-733   [004] ....   162.642000: rtcpu_vinotify_event: tstamp:5354517896 tag:CHANSEL_PXL_SOF channel:0x00 frame:42 vi_tstamp:5354517532 data:0x00000001
     kworker/4:1-733   [004] ....   162.642000: rtcpu_vinotify_event: tstamp:5354520781 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:42 vi_tstamp:5354520453 data:0x08000000
     kworker/4:1-733   [004] ....   162.642001: rtcpu_vinotify_event: tstamp:5355661328 tag:CHANSEL_PXL_EOF channel:0x00 frame:42 vi_tstamp:5355660692 data:0x01df0002
     kworker/4:1-733   [004] ....   162.642002: rtcpu_vinotify_event: tstamp:5355661444 tag:ATOMP_FE channel:0x00 frame:42 vi_tstamp:5355660813 data:0x00000000
     kworker/4:1-733   [004] ....   162.642002: rtcpu_vinotify_event: tstamp:5355682368 tag:ATOMP_FS channel:0x00 frame:43 vi_tstamp:5355681864 data:0x00000000
     kworker/4:1-733   [004] ....   162.642003: rtcpu_vinotify_event: tstamp:5355682481 tag:CHANSEL_PXL_SOF channel:0x00 frame:43 vi_tstamp:5355682114 data:0x00000001
 vi-output, ov56-7996  [000] ....   162.671946: tegra_channel_capture_frame: sof:162.561904608
     kworker/4:1-733   [004] ....   162.698013: rtcpu_vinotify_event: tstamp:5356647378 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:43 vi_tstamp:5356647038 data:0x08000000
     kworker/4:1-733   [004] ....   162.698017: rtcpu_vinotify_event: tstamp:5356825913 tag:CHANSEL_PXL_EOF channel:0x00 frame:43 vi_tstamp:5356825280 data:0x01df0002
     kworker/4:1-733   [004] ....   162.698017: rtcpu_vinotify_event: tstamp:5356826027 tag:ATOMP_FE channel:0x00 frame:43 vi_tstamp:5356825401 data:0x00000000
     kworker/4:1-733   [004] ....   162.698018: rtcpu_vinotify_event: tstamp:5356846945 tag:ATOMP_FS channel:0x00 frame:44 vi_tstamp:5356846452 data:0x00000000
     kworker/4:1-733   [004] ....   162.698019: rtcpu_vinotify_event: tstamp:5356847058 tag:CHANSEL_PXL_SOF channel:0x00 frame:44 vi_tstamp:5356846703 data:0x00000001
     kworker/4:1-733   [004] ....   162.698019: rtcpu_vinotify_event: tstamp:5356850209 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:44 vi_tstamp:5356849872 data:0x08000000
     kworker/4:1-733   [004] ....   162.698022: rtos_queue_peek_from_isr_failed: tstamp:5357357260 queue:0x0b4b6398
 vi-output, ov56-7996  [004] ....   162.709199: tegra_channel_capture_frame: sof:162.599171392
     kworker/4:1-733   [004] ....   162.754037: rtcpu_vinotify_event: tstamp:5357990506 tag:CHANSEL_PXL_EOF channel:0x00 frame:44 vi_tstamp:5357989868 data:0x01df0002
     kworker/4:1-733   [004] ....   162.754042: rtcpu_vinotify_event: tstamp:5357990624 tag:ATOMP_FE channel:0x00 frame:44 vi_tstamp:5357989989 data:0x00000000
     kworker/4:1-733   [004] ....   162.754044: rtcpu_vinotify_event: tstamp:5358011546 tag:ATOMP_FS channel:0x00 frame:45 vi_tstamp:5358011039 data:0x00000000
     kworker/4:1-733   [004] ....   162.754046: rtcpu_vinotify_event: tstamp:5358011660 tag:CHANSEL_PXL_SOF channel:0x00 frame:45 vi_tstamp:5358011290 data:0x00000001
     kworker/4:1-733   [004] ....   162.754048: rtcpu_vinotify_event: tstamp:5359155083 tag:CHANSEL_PXL_EOF channel:0x00 frame:45 vi_tstamp:5359154450 data:0x01df0002
     kworker/4:1-733   [004] ....   162.754050: rtcpu_vinotify_event: tstamp:5359155200 tag:ATOMP_FE channel:0x00 frame:45 vi_tstamp:5359154577 data:0x00000000
 vi-output, ov56-7996  [004] ....   162.783754: tegra_channel_capture_frame: sof:162.673704832
     kworker/4:1-733   [004] ....   162.809992: rtcpu_vinotify_event: tstamp:5360340713 tag:ATOMP_FS channel:0x00 frame:47 vi_tstamp:5360340209 data:0x00000000
     kworker/4:1-733   [004] ....   162.809996: rtcpu_vinotify_event: tstamp:5360340844 tag:CHANSEL_PXL_SOF channel:0x00 frame:47 vi_tstamp:5360340460 data:0x00000001
     kworker/4:1-733   [004] ....   162.809996: rtcpu_vinotify_event: tstamp:5360344239 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:47 vi_tstamp:5360343911 data:0x08000000
 vi-output, ov56-7996  [004] ....   162.821001: tegra_channel_capture_frame: sof:162.710971648
     kworker/4:1-733   [004] ....   162.866086: rtcpu_vinotify_event: tstamp:5361484261 tag:CHANSEL_PXL_EOF channel:0x00 frame:47 vi_tstamp:5361483627 data:0x01df0002
     kworker/4:1-733   [004] ....   162.866091: rtcpu_vinotify_event: tstamp:5361484376 tag:ATOMP_FE channel:0x00 frame:47 vi_tstamp:5361483748 data:0x00000000
     kworker/4:1-733   [004] ....   162.866093: rtcpu_vinotify_event: tstamp:5361505291 tag:ATOMP_FS channel:0x00 frame:48 vi_tstamp:5361504798 data:0x00000000
     kworker/4:1-733   [004] ....   162.866096: rtcpu_vinotify_event: tstamp:5361505403 tag:CHANSEL_PXL_SOF channel:0x00 frame:48 vi_tstamp:5361505048 data:0x00000001
     kworker/4:1-733   [004] ....   162.866101: rtos_queue_peek_from_isr_failed: tstamp:5362357266 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   162.866103: rtcpu_vinotify_event: tstamp:5362648846 tag:CHANSEL_PXL_EOF channel:0x00 frame:48 vi_tstamp:5362648215 data:0x01df0002
     kworker/4:1-733   [004] ....   162.866105: rtcpu_vinotify_event: tstamp:5362648961 tag:ATOMP_FE channel:0x00 frame:48 vi_tstamp:5362648335 data:0x00000000
 vi-output, ov56-7996  [004] ....   162.895547: tegra_channel_capture_frame: sof:162.785505312
     kworker/4:1-733   [004] ....   162.926013: rtcpu_vinotify_event: tstamp:5363834486 tag:ATOMP_FS channel:0x00 frame:50 vi_tstamp:5363833974 data:0x00000000
     kworker/4:1-733   [004] ....   162.926016: rtcpu_vinotify_event: tstamp:5363834606 tag:CHANSEL_PXL_SOF channel:0x00 frame:50 vi_tstamp:5363834225 data:0x00000001
     kworker/4:1-733   [004] ....   162.926017: rtcpu_vinotify_event: tstamp:5363837720 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:50 vi_tstamp:5363837394 data:0x08000000
 vi-output, ov56-7996  [004] ....   162.932800: tegra_channel_capture_frame: sof:162.822772128
     kworker/4:1-733   [004] ....   162.982134: rtcpu_vinotify_event: tstamp:5364978026 tag:CHANSEL_PXL_EOF channel:0x00 frame:50 vi_tstamp:5364977391 data:0x01df0002
     kworker/4:1-733   [004] ....   162.982139: rtcpu_vinotify_event: tstamp:5364978143 tag:ATOMP_FE channel:0x00 frame:50 vi_tstamp:5364977512 data:0x00000000
     kworker/4:1-733   [004] ....   162.982141: rtcpu_vinotify_event: tstamp:5364999055 tag:ATOMP_FS channel:0x00 frame:51 vi_tstamp:5364998562 data:0x00000000
     kworker/4:1-733   [004] ....   162.982143: rtcpu_vinotify_event: tstamp:5364999167 tag:CHANSEL_PXL_SOF channel:0x00 frame:51 vi_tstamp:5364998813 data:0x00000001
     kworker/4:1-733   [004] ....   162.982145: rtcpu_vinotify_event: tstamp:5366142618 tag:CHANSEL_PXL_EOF channel:0x00 frame:51 vi_tstamp:5366141980 data:0x01df0002
     kworker/4:1-733   [004] ....   162.982147: rtcpu_vinotify_event: tstamp:5366142734 tag:ATOMP_FE channel:0x00 frame:51 vi_tstamp:5366142100 data:0x00000000
 vi-output, ov56-7996  [005] ....   163.007335: tegra_channel_capture_frame: sof:162.897305792
     kworker/4:1-733   [004] ....   163.038026: rtcpu_vinotify_event: tstamp:5367328245 tag:ATOMP_FS channel:0x00 frame:53 vi_tstamp:5367327739 data:0x00000000
     kworker/4:1-733   [004] ....   163.038031: rtcpu_vinotify_event: tstamp:5367328365 tag:CHANSEL_PXL_SOF channel:0x00 frame:53 vi_tstamp:5367327990 data:0x00000001
     kworker/4:1-733   [004] ....   163.038032: rtcpu_vinotify_event: tstamp:5367331057 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:53 vi_tstamp:5367330732 data:0x08000000
     kworker/4:1-733   [004] ....   163.038035: rtos_queue_peek_from_isr_failed: tstamp:5367357256 queue:0x0b4b6398
 vi-output, ov56-7996  [004] ....   163.044616: tegra_channel_capture_frame: sof:162.934572384
     kworker/4:1-733   [004] ....   163.094100: rtcpu_vinotify_event: tstamp:5368471786 tag:CHANSEL_PXL_EOF channel:0x00 frame:53 vi_tstamp:5368471150 data:0x01df0002
     kworker/4:1-733   [004] ....   163.094106: rtcpu_vinotify_event: tstamp:5368471903 tag:ATOMP_FE channel:0x00 frame:53 vi_tstamp:5368471270 data:0x00000000
     kworker/4:1-733   [004] ....   163.094108: rtcpu_vinotify_event: tstamp:5368492821 tag:ATOMP_FS channel:0x00 frame:54 vi_tstamp:5368492321 data:0x00000000
     kworker/4:1-733   [004] ....   163.094110: rtcpu_vinotify_event: tstamp:5368492935 tag:CHANSEL_PXL_SOF channel:0x00 frame:54 vi_tstamp:5368492571 data:0x00000001
     kworker/4:1-733   [004] ....   163.094112: rtcpu_vinotify_event: tstamp:5369636370 tag:CHANSEL_PXL_EOF channel:0x00 frame:54 vi_tstamp:5369635737 data:0x01df0002
     kworker/4:1-733   [004] ....   163.094114: rtcpu_vinotify_event: tstamp:5369636487 tag:ATOMP_FE channel:0x00 frame:54 vi_tstamp:5369635858 data:0x00000000
 vi-output, ov56-7996  [005] ....   163.119126: tegra_channel_capture_frame: sof:163.9106016
     kworker/4:1-733   [004] ....   163.150034: rtcpu_vinotify_event: tstamp:5370822003 tag:ATOMP_FS channel:0x00 frame:56 vi_tstamp:5370821497 data:0x00000000
     kworker/4:1-733   [004] ....   163.150038: rtcpu_vinotify_event: tstamp:5370822122 tag:CHANSEL_PXL_SOF channel:0x00 frame:56 vi_tstamp:5370821747 data:0x00000001
     kworker/4:1-733   [004] ....   163.150039: rtcpu_vinotify_event: tstamp:5370824525 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:56 vi_tstamp:5370824195 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.156410: tegra_channel_capture_frame: sof:163.46372672
     kworker/4:1-733   [004] ....   163.206051: rtcpu_vinotify_event: tstamp:5371965543 tag:CHANSEL_PXL_EOF channel:0x00 frame:56 vi_tstamp:5371964908 data:0x01df0002
     kworker/4:1-733   [004] ....   163.206056: rtcpu_vinotify_event: tstamp:5371965670 tag:ATOMP_FE channel:0x00 frame:56 vi_tstamp:5371965034 data:0x00000000
     kworker/4:1-733   [004] ....   163.206057: rtcpu_vinotify_event: tstamp:5371986592 tag:ATOMP_FS channel:0x00 frame:57 vi_tstamp:5371986079 data:0x00000000
     kworker/4:1-733   [004] ....   163.206058: rtcpu_vinotify_event: tstamp:5371986706 tag:CHANSEL_PXL_SOF channel:0x00 frame:57 vi_tstamp:5371986330 data:0x00000001
     kworker/4:1-733   [004] ....   163.206061: rtos_queue_peek_from_isr_failed: tstamp:5372357251 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   163.206063: rtcpu_vinotify_event: tstamp:5373130128 tag:CHANSEL_PXL_EOF channel:0x00 frame:57 vi_tstamp:5373129496 data:0x01df0002
     kworker/4:1-733   [004] ....   163.206066: rtcpu_vinotify_event: tstamp:5373130246 tag:ATOMP_FE channel:0x00 frame:57 vi_tstamp:5373129617 data:0x00000000
 vi-output, ov56-7996  [000] ....   163.230939: tegra_channel_capture_frame: sof:163.120906272
     kworker/4:1-733   [004] ....   163.261992: rtcpu_vinotify_event: tstamp:5374315758 tag:ATOMP_FS channel:0x00 frame:59 vi_tstamp:5374315255 data:0x00000000
     kworker/4:1-733   [004] ....   163.261996: rtcpu_vinotify_event: tstamp:5374315875 tag:CHANSEL_PXL_SOF channel:0x00 frame:59 vi_tstamp:5374315505 data:0x00000001
     kworker/4:1-733   [004] ....   163.261997: rtcpu_vinotify_event: tstamp:5374318735 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:59 vi_tstamp:5374318396 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.268202: tegra_channel_capture_frame: sof:163.158173120
     kworker/4:1-733   [004] ....   163.318020: rtcpu_vinotify_event: tstamp:5375459298 tag:CHANSEL_PXL_EOF channel:0x00 frame:59 vi_tstamp:5375458666 data:0x01df0002
     kworker/4:1-733   [004] ....   163.318024: rtcpu_vinotify_event: tstamp:5375459413 tag:ATOMP_FE channel:0x00 frame:59 vi_tstamp:5375458793 data:0x00000000
     kworker/4:1-733   [004] ....   163.318025: rtcpu_vinotify_event: tstamp:5375480343 tag:ATOMP_FS channel:0x00 frame:60 vi_tstamp:5375479843 data:0x00000000
     kworker/4:1-733   [004] ....   163.318026: rtcpu_vinotify_event: tstamp:5375480456 tag:CHANSEL_PXL_SOF channel:0x00 frame:60 vi_tstamp:5375480094 data:0x00000001
     kworker/4:1-733   [004] ....   163.318026: rtcpu_vinotify_event: tstamp:5376623885 tag:CHANSEL_PXL_EOF channel:0x00 frame:60 vi_tstamp:5376623254 data:0x01df0002
     kworker/4:1-733   [004] ....   163.318027: rtcpu_vinotify_event: tstamp:5376624002 tag:ATOMP_FE channel:0x00 frame:60 vi_tstamp:5376623375 data:0x00000000
 vi-output, ov56-7996  [000] ....   163.342723: tegra_channel_capture_frame: sof:163.232706560
     kworker/4:1-733   [004] ....   163.373988: rtos_queue_peek_from_isr_failed: tstamp:5377357235 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   163.373993: rtcpu_vinotify_event: tstamp:5377809521 tag:ATOMP_FS channel:0x00 frame:62 vi_tstamp:5377809014 data:0x00000000
     kworker/4:1-733   [004] ....   163.373994: rtcpu_vinotify_event: tstamp:5377809639 tag:CHANSEL_PXL_SOF channel:0x00 frame:62 vi_tstamp:5377809264 data:0x00000001
     kworker/4:1-733   [004] ....   163.373995: rtcpu_vinotify_event: tstamp:5377811957 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:62 vi_tstamp:5377811629 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.380001: tegra_channel_capture_frame: sof:163.269973184
 vi-output, ov56-7996  [000] ....   163.417355: tegra_channel_capture_frame: sof:163.307240000
     kworker/4:1-733   [004] ....   163.430016: rtcpu_vinotify_event: tstamp:5378953067 tag:CHANSEL_PXL_EOF channel:0x00 frame:62 vi_tstamp:5378952430 data:0x01df0002
     kworker/4:1-733   [004] ....   163.430019: rtcpu_vinotify_event: tstamp:5378953181 tag:ATOMP_FE channel:0x00 frame:62 vi_tstamp:5378952551 data:0x00000000
     kworker/4:1-733   [004] ....   163.430020: rtcpu_vinotify_event: tstamp:5378974097 tag:ATOMP_FS channel:0x00 frame:63 vi_tstamp:5378973601 data:0x00000000
     kworker/4:1-733   [004] ....   163.430021: rtcpu_vinotify_event: tstamp:5378974208 tag:CHANSEL_PXL_SOF channel:0x00 frame:63 vi_tstamp:5378973846 data:0x00000001
     kworker/4:1-733   [004] ....   163.430022: rtcpu_vinotify_event: tstamp:5380030433 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:63 vi_tstamp:5380030096 data:0x08000000
     kworker/4:1-733   [004] ....   163.430022: rtcpu_vinotify_event: tstamp:5380117635 tag:CHANSEL_PXL_EOF channel:0x00 frame:63 vi_tstamp:5380117012 data:0x01df0002
     kworker/4:1-733   [004] ....   163.430023: rtcpu_vinotify_event: tstamp:5380117751 tag:ATOMP_FE channel:0x00 frame:63 vi_tstamp:5380117133 data:0x00000000
     kworker/4:1-733   [004] ....   163.430023: rtcpu_vinotify_event: tstamp:5380138687 tag:ATOMP_FS channel:0x00 frame:64 vi_tstamp:5380138183 data:0x00000000
     kworker/4:1-733   [004] ....   163.430024: rtcpu_vinotify_event: tstamp:5380138804 tag:CHANSEL_PXL_SOF channel:0x00 frame:64 vi_tstamp:5380138434 data:0x00000001
     kworker/4:1-733   [004] ....   163.430025: rtcpu_vinotify_event: tstamp:5380156349 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:64 vi_tstamp:5380156018 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.454547: tegra_channel_capture_frame: sof:163.344506816
     kworker/4:1-733   [004] ....   163.486053: rtcpu_vinotify_event: tstamp:5381282223 tag:CHANSEL_PXL_EOF channel:0x00 frame:64 vi_tstamp:5381281600 data:0x01df0002
     kworker/4:1-733   [004] ....   163.486059: rtcpu_vinotify_event: tstamp:5381282337 tag:ATOMP_FE channel:0x00 frame:64 vi_tstamp:5381281721 data:0x00000000
     kworker/4:1-733   [004] ....   163.486061: rtcpu_vinotify_event: tstamp:5381303272 tag:ATOMP_FS channel:0x00 frame:65 vi_tstamp:5381302771 data:0x00000000
     kworker/4:1-733   [004] ....   163.486062: rtcpu_vinotify_event: tstamp:5381303387 tag:CHANSEL_PXL_SOF channel:0x00 frame:65 vi_tstamp:5381303022 data:0x00000001
     kworker/4:1-733   [004] ....   163.486063: rtcpu_vinotify_event: tstamp:5381306493 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:65 vi_tstamp:5381306161 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.491792: tegra_channel_capture_frame: sof:163.381773632
 vi-output, ov56-7996  [005] ....   163.529067: tegra_channel_capture_frame: sof:163.419040448
     kworker/4:1-733   [004] ....   163.541991: rtos_queue_peek_from_isr_failed: tstamp:5382357238 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   163.541995: rtcpu_vinotify_event: tstamp:5382446825 tag:CHANSEL_PXL_EOF channel:0x00 frame:65 vi_tstamp:5382446188 data:0x01df0002
     kworker/4:1-733   [004] ....   163.541996: rtcpu_vinotify_event: tstamp:5382446940 tag:ATOMP_FE channel:0x00 frame:65 vi_tstamp:5382446315 data:0x00000000
     kworker/4:1-733   [004] ....   163.541997: rtcpu_vinotify_event: tstamp:5382467866 tag:ATOMP_FS channel:0x00 frame:66 vi_tstamp:5382467359 data:0x00000000
     kworker/4:1-733   [004] ....   163.541997: rtcpu_vinotify_event: tstamp:5382467979 tag:CHANSEL_PXL_SOF channel:0x00 frame:66 vi_tstamp:5382467610 data:0x00000001
     kworker/4:1-733   [004] ....   163.541998: rtcpu_vinotify_event: tstamp:5383496272 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:66 vi_tstamp:5383495931 data:0x08000000
     kworker/4:1-733   [004] ....   163.541998: rtcpu_vinotify_event: tstamp:5383611403 tag:CHANSEL_PXL_EOF channel:0x00 frame:66 vi_tstamp:5383610777 data:0x01df0002
     kworker/4:1-733   [004] ....   163.541999: rtcpu_vinotify_event: tstamp:5383611520 tag:ATOMP_FE channel:0x00 frame:66 vi_tstamp:5383610904 data:0x00000000
     kworker/4:1-733   [004] ....   163.541999: rtcpu_vinotify_event: tstamp:5383632453 tag:ATOMP_FS channel:0x00 frame:67 vi_tstamp:5383631948 data:0x00000000
     kworker/4:1-733   [004] ....   163.542000: rtcpu_vinotify_event: tstamp:5383632569 tag:CHANSEL_PXL_SOF channel:0x00 frame:67 vi_tstamp:5383632198 data:0x00000001
     kworker/4:1-733   [004] ....   163.542000: rtcpu_vinotify_event: tstamp:5383635318 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:67 vi_tstamp:5383634991 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.566337: tegra_channel_capture_frame: sof:163.456307072
     kworker/4:1-733   [004] ....   163.597994: rtcpu_vinotify_event: tstamp:5384776000 tag:CHANSEL_PXL_EOF channel:0x00 frame:67 vi_tstamp:5384775365 data:0x01df0002
     kworker/4:1-733   [004] ....   163.597996: rtcpu_vinotify_event: tstamp:5384776115 tag:ATOMP_FE channel:0x00 frame:67 vi_tstamp:5384775485 data:0x00000000
     kworker/4:1-733   [004] ....   163.597998: rtcpu_vinotify_event: tstamp:5384797045 tag:ATOMP_FS channel:0x00 frame:68 vi_tstamp:5384796530 data:0x00000000
     kworker/4:1-733   [004] ....   163.597999: rtcpu_vinotify_event: tstamp:5384797170 tag:CHANSEL_PXL_SOF channel:0x00 frame:68 vi_tstamp:5384796780 data:0x00000001
 vi-output, ov56-7996  [005] ....   163.640890: tegra_channel_capture_frame: sof:163.530840736
     kworker/4:1-733   [004] ....   163.654033: rtcpu_vinotify_event: tstamp:5385940589 tag:CHANSEL_PXL_EOF channel:0x00 frame:68 vi_tstamp:5385939953 data:0x01df0002
     kworker/4:1-733   [004] ....   163.654037: rtcpu_vinotify_event: tstamp:5385940704 tag:ATOMP_FE channel:0x00 frame:68 vi_tstamp:5385940074 data:0x00000000
     kworker/4:1-733   [004] ....   163.654037: rtcpu_vinotify_event: tstamp:5387126214 tag:ATOMP_FS channel:0x00 frame:70 vi_tstamp:5387125706 data:0x00000000
     kworker/4:1-733   [004] ....   163.654038: rtcpu_vinotify_event: tstamp:5387126332 tag:CHANSEL_PXL_SOF channel:0x00 frame:70 vi_tstamp:5387125957 data:0x00000001
     kworker/4:1-733   [004] ....   163.654038: rtcpu_vinotify_event: tstamp:5387129721 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:70 vi_tstamp:5387129394 data:0x08000000
     kworker/4:1-733   [004] ....   163.654041: rtos_queue_peek_from_isr_failed: tstamp:5387357227 queue:0x0b4b6398
 vi-output, ov56-7996  [004] ....   163.678128: tegra_channel_capture_frame: sof:163.568107552
     kworker/4:1-733   [004] ....   163.710006: rtcpu_vinotify_event: tstamp:5388269761 tag:CHANSEL_PXL_EOF channel:0x00 frame:70 vi_tstamp:5388269123 data:0x01df0002
     kworker/4:1-733   [004] ....   163.710009: rtcpu_vinotify_event: tstamp:5388269879 tag:ATOMP_FE channel:0x00 frame:70 vi_tstamp:5388269250 data:0x00000000
     kworker/4:1-733   [004] ....   163.710010: rtcpu_vinotify_event: tstamp:5388290799 tag:ATOMP_FS channel:0x00 frame:71 vi_tstamp:5388290294 data:0x00000000
     kworker/4:1-733   [004] ....   163.710011: rtcpu_vinotify_event: tstamp:5388290912 tag:CHANSEL_PXL_SOF channel:0x00 frame:71 vi_tstamp:5388290545 data:0x00000001
 vi-output, ov56-7996  [005] ....   163.752675: tegra_channel_capture_frame: sof:163.642640992
     kworker/4:1-733   [004] ....   163.766025: rtcpu_vinotify_event: tstamp:5389434346 tag:CHANSEL_PXL_EOF channel:0x00 frame:71 vi_tstamp:5389433711 data:0x01df0002
     kworker/4:1-733   [004] ....   163.766030: rtcpu_vinotify_event: tstamp:5389434463 tag:ATOMP_FE channel:0x00 frame:71 vi_tstamp:5389433831 data:0x00000000
     kworker/4:1-733   [004] ....   163.766030: rtcpu_vinotify_event: tstamp:5390619971 tag:ATOMP_FS channel:0x00 frame:73 vi_tstamp:5390619464 data:0x00000000
     kworker/4:1-733   [004] ....   163.766031: rtcpu_vinotify_event: tstamp:5390620091 tag:CHANSEL_PXL_SOF channel:0x00 frame:73 vi_tstamp:5390619715 data:0x00000001
     kworker/4:1-733   [004] ....   163.766032: rtcpu_vinotify_event: tstamp:5390622960 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:73 vi_tstamp:5390622633 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.789939: tegra_channel_capture_frame: sof:163.679907808
     kworker/4:1-733   [004] ....   163.822058: rtcpu_vinotify_event: tstamp:5391763516 tag:CHANSEL_PXL_EOF channel:0x00 frame:73 vi_tstamp:5391762881 data:0x01df0002
     kworker/4:1-733   [004] ....   163.822061: rtcpu_vinotify_event: tstamp:5391763632 tag:ATOMP_FE channel:0x00 frame:73 vi_tstamp:5391763002 data:0x00000000
     kworker/4:1-733   [004] ....   163.822063: rtcpu_vinotify_event: tstamp:5391784558 tag:ATOMP_FS channel:0x00 frame:74 vi_tstamp:5391784052 data:0x00000000
     kworker/4:1-733   [004] ....   163.822064: rtcpu_vinotify_event: tstamp:5391784670 tag:CHANSEL_PXL_SOF channel:0x00 frame:74 vi_tstamp:5391784303 data:0x00000001
     kworker/4:1-733   [004] ....   163.822067: rtos_queue_peek_from_isr_failed: tstamp:5392357226 queue:0x0b4b6398
 vi-output, ov56-7996  [004] ....   163.864468: tegra_channel_capture_frame: sof:163.754441248
     kworker/4:1-733   [004] ....   163.878001: rtcpu_vinotify_event: tstamp:5392928107 tag:CHANSEL_PXL_EOF channel:0x00 frame:74 vi_tstamp:5392927470 data:0x01df0002
     kworker/4:1-733   [004] ....   163.878004: rtcpu_vinotify_event: tstamp:5392928224 tag:ATOMP_FE channel:0x00 frame:74 vi_tstamp:5392927590 data:0x00000000
     kworker/4:1-733   [004] ....   163.878005: rtcpu_vinotify_event: tstamp:5394113730 tag:ATOMP_FS channel:0x00 frame:76 vi_tstamp:5394113222 data:0x00000000
     kworker/4:1-733   [004] ....   163.878005: rtcpu_vinotify_event: tstamp:5394113848 tag:CHANSEL_PXL_SOF channel:0x00 frame:76 vi_tstamp:5394113473 data:0x00000001
     kworker/4:1-733   [004] ....   163.878006: rtcpu_vinotify_event: tstamp:5394116479 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:76 vi_tstamp:5394116152 data:0x08000000
 vi-output, ov56-7996  [004] ....   163.901751: tegra_channel_capture_frame: sof:163.791708064
     kworker/4:1-733   [004] ....   163.934058: rtcpu_vinotify_event: tstamp:5395257275 tag:CHANSEL_PXL_EOF channel:0x00 frame:76 vi_tstamp:5395256640 data:0x01df0002
     kworker/4:1-733   [004] ....   163.934060: rtcpu_vinotify_event: tstamp:5395257391 tag:ATOMP_FE channel:0x00 frame:76 vi_tstamp:5395256767 data:0x00000000
     kworker/4:1-733   [004] ....   163.934062: rtcpu_vinotify_event: tstamp:5395278314 tag:ATOMP_FS channel:0x00 frame:77 vi_tstamp:5395277811 data:0x00000000
     kworker/4:1-733   [004] ....   163.934063: rtcpu_vinotify_event: tstamp:5395278427 tag:CHANSEL_PXL_SOF channel:0x00 frame:77 vi_tstamp:5395278061 data:0x00000001
 vi-output, ov56-7996  [005] ....   163.976256: tegra_channel_capture_frame: sof:163.866241504
     kworker/4:1-733   [004] ....   163.989996: rtcpu_vinotify_event: tstamp:5396421863 tag:CHANSEL_PXL_EOF channel:0x00 frame:77 vi_tstamp:5396421228 data:0x01df0002
     kworker/4:1-733   [004] ....   163.990000: rtcpu_vinotify_event: tstamp:5396421980 tag:ATOMP_FE channel:0x00 frame:77 vi_tstamp:5396421348 data:0x00000000
     kworker/4:1-733   [004] ....   163.990002: rtos_queue_peek_from_isr_failed: tstamp:5397357218 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   163.990002: rtcpu_vinotify_event: tstamp:5397607483 tag:ATOMP_FS channel:0x00 frame:79 vi_tstamp:5397606981 data:0x00000000
     kworker/4:1-733   [004] ....   163.990003: rtcpu_vinotify_event: tstamp:5397607597 tag:CHANSEL_PXL_SOF channel:0x00 frame:79 vi_tstamp:5397607231 data:0x00000001
     kworker/4:1-733   [004] ....   163.990003: rtcpu_vinotify_event: tstamp:5397609901 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:79 vi_tstamp:5397609573 data:0x08000000
 vi-output, ov56-7996  [004] ....   164.013538: tegra_channel_capture_frame: sof:163.903508352
     kworker/4:1-733   [004] ....   164.046091: rtcpu_vinotify_event: tstamp:5398751037 tag:CHANSEL_PXL_EOF channel:0x00 frame:79 vi_tstamp:5398750404 data:0x01df0002
     kworker/4:1-733   [004] ....   164.046095: rtcpu_vinotify_event: tstamp:5398751151 tag:ATOMP_FE channel:0x00 frame:79 vi_tstamp:5398750525 data:0x00000000
     kworker/4:1-733   [004] ....   164.046097: rtcpu_vinotify_event: tstamp:5398772073 tag:ATOMP_FS channel:0x00 frame:80 vi_tstamp:5398771569 data:0x00000000
     kworker/4:1-733   [004] ....   164.046099: rtcpu_vinotify_event: tstamp:5398772187 tag:CHANSEL_PXL_SOF channel:0x00 frame:80 vi_tstamp:5398771820 data:0x00000001
 vi-output, ov56-7996  [000] ....   164.088100: tegra_channel_capture_frame: sof:163.978041792
     kworker/4:1-733   [004] ....   164.102044: rtcpu_vinotify_event: tstamp:5399915620 tag:CHANSEL_PXL_EOF channel:0x00 frame:80 vi_tstamp:5399914986 data:0x01df0002
     kworker/4:1-733   [004] ....   164.102048: rtcpu_vinotify_event: tstamp:5399915737 tag:ATOMP_FE channel:0x00 frame:80 vi_tstamp:5399915107 data:0x00000000
     kworker/4:1-733   [004] ....   164.102050: rtcpu_vinotify_event: tstamp:5401101243 tag:ATOMP_FS channel:0x00 frame:82 vi_tstamp:5401100739 data:0x00000000
     kworker/4:1-733   [004] ....   164.102051: rtcpu_vinotify_event: tstamp:5401101359 tag:CHANSEL_PXL_SOF channel:0x00 frame:82 vi_tstamp:5401100990 data:0x00000001
     kworker/4:1-733   [004] ....   164.102052: rtcpu_vinotify_event: tstamp:5401105028 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:82 vi_tstamp:5401104701 data:0x08000000
 vi-output, ov56-7996  [000] ....   164.125403: tegra_channel_capture_frame: sof:164.15308608
     kworker/4:1-733   [004] ....   164.158114: rtcpu_vinotify_event: tstamp:5402244796 tag:CHANSEL_PXL_EOF channel:0x00 frame:82 vi_tstamp:5402244162 data:0x01df0002
     kworker/4:1-733   [004] ....   164.158120: rtcpu_vinotify_event: tstamp:5402244910 tag:ATOMP_FE channel:0x00 frame:82 vi_tstamp:5402244283 data:0x00000000
     kworker/4:1-733   [004] ....   164.158122: rtcpu_vinotify_event: tstamp:5402265832 tag:ATOMP_FS channel:0x00 frame:83 vi_tstamp:5402265327 data:0x00000000
     kworker/4:1-733   [004] ....   164.158124: rtcpu_vinotify_event: tstamp:5402265959 tag:CHANSEL_PXL_SOF channel:0x00 frame:83 vi_tstamp:5402265578 data:0x00000001
     kworker/4:1-733   [004] ....   164.158129: rtos_queue_peek_from_isr_failed: tstamp:5402357199 queue:0x0b4b6398
 vi-output, ov56-7996  [004] ....   164.199875: tegra_channel_capture_frame: sof:164.89842240
     kworker/4:1-733   [004] ....   164.213995: rtcpu_vinotify_event: tstamp:5403409374 tag:CHANSEL_PXL_EOF channel:0x00 frame:83 vi_tstamp:5403408750 data:0x01df0002
     kworker/4:1-733   [004] ....   164.213999: rtcpu_vinotify_event: tstamp:5403409491 tag:ATOMP_FE channel:0x00 frame:83 vi_tstamp:5403408871 data:0x00000000
     kworker/4:1-733   [004] ....   164.214000: rtcpu_vinotify_event: tstamp:5404595015 tag:ATOMP_FS channel:0x00 frame:85 vi_tstamp:5404594497 data:0x00000000
     kworker/4:1-733   [004] ....   164.214001: rtcpu_vinotify_event: tstamp:5404595131 tag:CHANSEL_PXL_SOF channel:0x00 frame:85 vi_tstamp:5404594754 data:0x00000001
     kworker/4:1-733   [004] ....   164.214001: rtcpu_vinotify_event: tstamp:5404597945 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:85 vi_tstamp:5404597619 data:0x08000000
 vi-output, ov56-7996  [004] ....   164.237133: tegra_channel_capture_frame: sof:164.127108864
     kworker/4:1-733   [004] ....   164.270106: rtcpu_vinotify_event: tstamp:5405738556 tag:CHANSEL_PXL_EOF channel:0x00 frame:85 vi_tstamp:5405737920 data:0x01df0002
     kworker/4:1-733   [004] ....   164.270113: rtcpu_vinotify_event: tstamp:5405738671 tag:ATOMP_FE channel:0x00 frame:85 vi_tstamp:5405738041 data:0x00000000
     kworker/4:1-733   [004] ....   164.270115: rtcpu_vinotify_event: tstamp:5405759597 tag:ATOMP_FS channel:0x00 frame:86 vi_tstamp:5405759085 data:0x00000000
     kworker/4:1-733   [004] ....   164.270117: rtcpu_vinotify_event: tstamp:5405759710 tag:CHANSEL_PXL_SOF channel:0x00 frame:86 vi_tstamp:5405759336 data:0x00000001
     kworker/4:1-733   [004] ....   164.270119: rtcpu_vinotify_event: tstamp:5406785760 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:86 vi_tstamp:5406785420 data:0x08000000
 vi-output, ov56-7996  [004] ....   164.274425: tegra_channel_capture_frame: sof:164.164375680
 vi-output, ov56-7996  [005] ....   164.311656: tegra_channel_capture_frame: sof:164.201642496
     kworker/4:1-733   [004] ....   164.326002: rtcpu_vinotify_event: tstamp:5406903129 tag:CHANSEL_PXL_EOF channel:0x00 frame:86 vi_tstamp:5406902508 data:0x01df0002
     kworker/4:1-733   [004] ....   164.326006: rtcpu_vinotify_event: tstamp:5406903245 tag:ATOMP_FE channel:0x00 frame:86 vi_tstamp:5406902629 data:0x00000000
     kworker/4:1-733   [004] ....   164.326007: rtcpu_vinotify_event: tstamp:5406924177 tag:ATOMP_FS channel:0x00 frame:87 vi_tstamp:5406923673 data:0x00000000
     kworker/4:1-733   [004] ....   164.326008: rtcpu_vinotify_event: tstamp:5406924292 tag:CHANSEL_PXL_SOF channel:0x00 frame:87 vi_tstamp:5406923924 data:0x00000001
     kworker/4:1-733   [004] ....   164.326008: rtcpu_vinotify_event: tstamp:5406927780 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:87 vi_tstamp:5406927445 data:0x08000000
     kworker/4:1-733   [004] ....   164.326011: rtos_queue_peek_from_isr_failed: tstamp:5407357194 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   164.326012: rtcpu_vinotify_event: tstamp:5408067735 tag:CHANSEL_PXL_EOF channel:0x00 frame:87 vi_tstamp:5408067097 data:0x01df0002
     kworker/4:1-733   [004] ....   164.326012: rtcpu_vinotify_event: tstamp:5408067853 tag:ATOMP_FE channel:0x00 frame:87 vi_tstamp:5408067217 data:0x00000000
     kworker/4:1-733   [004] ....   164.326013: rtcpu_vinotify_event: tstamp:5408088754 tag:ATOMP_FS channel:0x00 frame:88 vi_tstamp:5408088261 data:0x00000000
     kworker/4:1-733   [004] ....   164.326014: rtcpu_vinotify_event: tstamp:5408088867 tag:CHANSEL_PXL_SOF channel:0x00 frame:88 vi_tstamp:5408088512 data:0x00000001
     kworker/4:1-733   [004] ....   164.382061: rtcpu_vinotify_event: tstamp:5409232315 tag:CHANSEL_PXL_EOF channel:0x00 frame:88 vi_tstamp:5409231678 data:0x01df0002
     kworker/4:1-733   [004] ....   164.382066: rtcpu_vinotify_event: tstamp:5409232430 tag:ATOMP_FE channel:0x00 frame:88 vi_tstamp:5409231805 data:0x00000000
 vi-output, ov56-7996  [004] ....   164.386237: tegra_channel_capture_frame: sof:164.276175968
 vi-output, ov56-7996  [004] ....   164.423469: tegra_channel_capture_frame: sof:164.313442752
     kworker/4:1-733   [004] ....   164.438002: rtcpu_vinotify_event: tstamp:5410417938 tag:ATOMP_FS channel:0x00 frame:90 vi_tstamp:5410417432 data:0x00000000
     kworker/4:1-733   [004] ....   164.438005: rtcpu_vinotify_event: tstamp:5410418058 tag:CHANSEL_PXL_SOF channel:0x00 frame:90 vi_tstamp:5410417683 data:0x00000001
     kworker/4:1-733   [004] ....   164.438006: rtcpu_vinotify_event: tstamp:5410421884 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:90 vi_tstamp:5410421555 data:0x08000000
     kworker/4:1-733   [004] ....   164.438007: rtcpu_vinotify_event: tstamp:5411561490 tag:CHANSEL_PXL_EOF channel:0x00 frame:90 vi_tstamp:5411560855 data:0x01df0002
     kworker/4:1-733   [004] ....   164.438008: rtcpu_vinotify_event: tstamp:5411561605 tag:ATOMP_FE channel:0x00 frame:90 vi_tstamp:5411560975 data:0x00000000
     kworker/4:1-733   [004] ....   164.438009: rtcpu_vinotify_event: tstamp:5411582525 tag:ATOMP_FS channel:0x00 frame:91 vi_tstamp:5411582020 data:0x00000000
     kworker/4:1-733   [004] ....   164.438010: rtcpu_vinotify_event: tstamp:5411582638 tag:CHANSEL_PXL_SOF channel:0x00 frame:91 vi_tstamp:5411582270 data:0x00000001
     kworker/4:1-733   [004] ....   164.494072: rtos_queue_peek_from_isr_failed: tstamp:5412357188 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   164.494079: rtcpu_vinotify_event: tstamp:5412726065 tag:CHANSEL_PXL_EOF channel:0x00 frame:91 vi_tstamp:5412725430 data:0x01df0002
     kworker/4:1-733   [004] ....   164.494080: rtcpu_vinotify_event: tstamp:5412726180 tag:ATOMP_FE channel:0x00 frame:91 vi_tstamp:5412725557 data:0x00000000
 vi-output, ov56-7996  [000] ....   164.498060: tegra_channel_capture_frame: sof:164.387976192
 vi-output, ov56-7996  [004] ....   164.535272: tegra_channel_capture_frame: sof:164.425243008
     kworker/4:1-733   [004] ....   164.550015: rtcpu_vinotify_event: tstamp:5413911735 tag:ATOMP_FS channel:0x00 frame:93 vi_tstamp:5413911189 data:0x00000000
     kworker/4:1-733   [004] ....   164.550017: rtcpu_vinotify_event: tstamp:5413911853 tag:CHANSEL_PXL_SOF channel:0x00 frame:93 vi_tstamp:5413911440 data:0x00000001
     kworker/4:1-733   [004] ....   164.550018: rtcpu_vinotify_event: tstamp:5413916263 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:93 vi_tstamp:5413915935 data:0x08000000
     kworker/4:1-733   [004] ....   164.550019: rtcpu_vinotify_event: tstamp:5415055244 tag:CHANSEL_PXL_EOF channel:0x00 frame:93 vi_tstamp:5415054607 data:0x01df0002
     kworker/4:1-733   [004] ....   164.550020: rtcpu_vinotify_event: tstamp:5415055358 tag:ATOMP_FE channel:0x00 frame:93 vi_tstamp:5415054728 data:0x00000000
     kworker/4:1-733   [004] ....   164.550021: rtcpu_vinotify_event: tstamp:5415076290 tag:ATOMP_FS channel:0x00 frame:94 vi_tstamp:5415075778 data:0x00000000
     kworker/4:1-733   [004] ....   164.550022: rtcpu_vinotify_event: tstamp:5415076404 tag:CHANSEL_PXL_SOF channel:0x00 frame:94 vi_tstamp:5415076028 data:0x00000001
     kworker/4:1-733   [004] ....   164.606031: rtcpu_vinotify_event: tstamp:5416219816 tag:CHANSEL_PXL_EOF channel:0x00 frame:94 vi_tstamp:5416219195 data:0x01df0002
     kworker/4:1-733   [004] ....   164.606035: rtcpu_vinotify_event: tstamp:5416219932 tag:ATOMP_FE channel:0x00 frame:94 vi_tstamp:5416219315 data:0x00000000
 vi-output, ov56-7996  [005] ....   164.609803: tegra_channel_capture_frame: sof:164.499776448
 vi-output, ov56-7996  [005] ....   164.647070: tegra_channel_capture_frame: sof:164.537043296
     kworker/4:1-733   [004] ....   164.662003: rtos_queue_peek_from_isr_failed: tstamp:5417357190 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   164.662007: rtcpu_vinotify_event: tstamp:5417405448 tag:ATOMP_FS channel:0x00 frame:96 vi_tstamp:5417404948 data:0x00000000
     kworker/4:1-733   [004] ....   164.662008: rtcpu_vinotify_event: tstamp:5417405563 tag:CHANSEL_PXL_SOF channel:0x00 frame:96 vi_tstamp:5417405198 data:0x00000001
     kworker/4:1-733   [004] ....   164.662010: rtcpu_vinotify_event: tstamp:5417408194 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:96 vi_tstamp:5417407866 data:0x08000000
     kworker/4:1-733   [004] ....   164.662011: rtcpu_vinotify_event: tstamp:5418549000 tag:CHANSEL_PXL_EOF channel:0x00 frame:96 vi_tstamp:5418548365 data:0x01df0002
     kworker/4:1-733   [004] ....   164.662012: rtcpu_vinotify_event: tstamp:5418549128 tag:ATOMP_FE channel:0x00 frame:96 vi_tstamp:5418548485 data:0x00000000
     kworker/4:1-733   [004] ....   164.662013: rtcpu_vinotify_event: tstamp:5418570041 tag:ATOMP_FS channel:0x00 frame:97 vi_tstamp:5418569536 data:0x00000000
     kworker/4:1-733   [004] ....   164.662015: rtcpu_vinotify_event: tstamp:5418570155 tag:CHANSEL_PXL_SOF channel:0x00 frame:97 vi_tstamp:5418569787 data:0x00000001
     kworker/4:1-733   [004] ....   164.717992: rtcpu_vinotify_event: tstamp:5419713591 tag:CHANSEL_PXL_EOF channel:0x00 frame:97 vi_tstamp:5419712953 data:0x01df0002
     kworker/4:1-733   [004] ....   164.717996: rtcpu_vinotify_event: tstamp:5419713708 tag:ATOMP_FE channel:0x00 frame:97 vi_tstamp:5419713074 data:0x00000000
 vi-output, ov56-7996  [000] ....   164.724611: tegra_channel_capture_frame: sof:164.611576928
 vi-output, ov56-7996  [005] ....   164.758864: tegra_channel_capture_frame: sof:164.648843552
     kworker/4:1-733   [004] ....   164.774002: rtcpu_vinotify_event: tstamp:5420899220 tag:ATOMP_FS channel:0x00 frame:99 vi_tstamp:5420898712 data:0x00000000
     kworker/4:1-733   [004] ....   164.774005: rtcpu_vinotify_event: tstamp:5420899337 tag:CHANSEL_PXL_SOF channel:0x00 frame:99 vi_tstamp:5420898963 data:0x00000001
     kworker/4:1-733   [004] ....   164.774006: rtcpu_vinotify_event: tstamp:5420995970 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:99 vi_tstamp:5420995635 data:0x08000000
     kworker/4:1-733   [004] ....   164.774006: rtcpu_vinotify_event: tstamp:5422042747 tag:CHANSEL_PXL_EOF channel:0x00 frame:99 vi_tstamp:5422042123 data:0x01df0002
     kworker/4:1-733   [004] ....   164.774007: rtcpu_vinotify_event: tstamp:5422042864 tag:ATOMP_FE channel:0x00 frame:99 vi_tstamp:5422042244 data:0x00000000
     kworker/4:1-733   [004] ....   164.774007: rtcpu_vinotify_event: tstamp:5422063794 tag:ATOMP_FS channel:0x00 frame:100 vi_tstamp:5422063301 data:0x00000000
     kworker/4:1-733   [004] ....   164.774008: rtcpu_vinotify_event: tstamp:5422063906 tag:CHANSEL_PXL_SOF channel:0x00 frame:100 vi_tstamp:5422063545 data:0x00000001
     kworker/4:1-733   [004] ....   164.774010: rtos_queue_peek_from_isr_failed: tstamp:5422357173 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   164.830007: rtcpu_vinotify_event: tstamp:5423207339 tag:CHANSEL_PXL_EOF channel:0x00 frame:100 vi_tstamp:5423206711 data:0x01df0002
     kworker/4:1-733   [004] ....   164.830010: rtcpu_vinotify_event: tstamp:5423207458 tag:ATOMP_FE channel:0x00 frame:100 vi_tstamp:5423206832 data:0x00000000
 vi-output, ov56-7996  [005] ....   164.833427: tegra_channel_capture_frame: sof:164.723377184
 vi-output, ov56-7996  [005] ....   164.870670: tegra_channel_capture_frame: sof:164.760644032
     kworker/4:1-733   [004] ....   164.885986: rtcpu_vinotify_event: tstamp:5424392975 tag:ATOMP_FS channel:0x00 frame:102 vi_tstamp:5424392471 data:0x00000000
     kworker/4:1-733   [004] ....   164.885988: rtcpu_vinotify_event: tstamp:5424393093 tag:CHANSEL_PXL_SOF channel:0x00 frame:102 vi_tstamp:5424392721 data:0x00000001
     kworker/4:1-733   [004] ....   164.885989: rtcpu_vinotify_event: tstamp:5424396445 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:102 vi_tstamp:5424396116 data:0x08000000
     kworker/4:1-733   [004] ....   164.885989: rtcpu_vinotify_event: tstamp:5425536509 tag:CHANSEL_PXL_EOF channel:0x00 frame:102 vi_tstamp:5425535881 data:0x01df0002
     kworker/4:1-733   [004] ....   164.885990: rtcpu_vinotify_event: tstamp:5425536628 tag:ATOMP_FE channel:0x00 frame:102 vi_tstamp:5425536008 data:0x00000000
     kworker/4:1-733   [004] ....   164.885991: rtcpu_vinotify_event: tstamp:5425557550 tag:ATOMP_FS channel:0x00 frame:103 vi_tstamp:5425557059 data:0x00000000
     kworker/4:1-733   [004] ....   164.885992: rtcpu_vinotify_event: tstamp:5425557663 tag:CHANSEL_PXL_SOF channel:0x00 frame:103 vi_tstamp:5425557310 data:0x00000001
 vi-output, ov56-7996  [000] ....   164.907938: tegra_channel_capture_frame: sof:164.797910624
     kworker/4:1-733   [004] ....   164.942026: rtcpu_vinotify_event: tstamp:5426701101 tag:CHANSEL_PXL_EOF channel:0x00 frame:103 vi_tstamp:5426700470 data:0x01df0002
     kworker/4:1-733   [004] ....   164.942029: rtcpu_vinotify_event: tstamp:5426701218 tag:ATOMP_FE channel:0x00 frame:103 vi_tstamp:5426700590 data:0x00000000
     kworker/4:1-733   [004] ....   164.942030: rtcpu_vinotify_event: tstamp:5426722140 tag:ATOMP_FS channel:0x00 frame:104 vi_tstamp:5426721647 data:0x00000000
     kworker/4:1-733   [004] ....   164.942030: rtcpu_vinotify_event: tstamp:5426722258 tag:CHANSEL_PXL_SOF channel:0x00 frame:104 vi_tstamp:5426721891 data:0x00000001
     kworker/4:1-733   [004] ....   164.942031: rtcpu_vinotify_event: tstamp:5426792029 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:104 vi_tstamp:5426791692 data:0x08000000
     kworker/4:1-733   [004] ....   164.942033: rtos_queue_peek_from_isr_failed: tstamp:5427357166 queue:0x0b4b6398
 vi-output, ov56-7996  [004] ....   164.945207: tegra_channel_capture_frame: sof:164.835177472
 vi-output, ov56-7996  [004] ....   164.982466: tegra_channel_capture_frame: sof:164.872444288
     kworker/4:1-733   [004] ....   164.998004: rtcpu_vinotify_event: tstamp:5427865683 tag:CHANSEL_PXL_EOF channel:0x00 frame:104 vi_tstamp:5427865058 data:0x01df0002
     kworker/4:1-733   [004] ....   164.998006: rtcpu_vinotify_event: tstamp:5427865819 tag:ATOMP_FE channel:0x00 frame:104 vi_tstamp:5427865178 data:0x00000000
     kworker/4:1-733   [004] ....   164.998007: rtcpu_vinotify_event: tstamp:5427886728 tag:ATOMP_FS channel:0x00 frame:105 vi_tstamp:5427886229 data:0x00000000
     kworker/4:1-733   [004] ....   164.998008: rtcpu_vinotify_event: tstamp:5427886841 tag:CHANSEL_PXL_SOF channel:0x00 frame:105 vi_tstamp:5427886480 data:0x00000001
     kworker/4:1-733   [004] ....   164.998008: rtcpu_vinotify_event: tstamp:5427889600 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:105 vi_tstamp:5427889248 data:0x08000000
     kworker/4:1-733   [004] ....   164.998011: rtcpu_vinotify_event: tstamp:5429030279 tag:CHANSEL_PXL_EOF channel:0x00 frame:105 vi_tstamp:5429029646 data:0x01df0002
     kworker/4:1-733   [004] ....   164.998011: rtcpu_vinotify_event: tstamp:5429030395 tag:ATOMP_FE channel:0x00 frame:105 vi_tstamp:5429029767 data:0x00000000
     kworker/4:1-733   [004] ....   164.998012: rtcpu_vinotify_event: tstamp:5429051323 tag:ATOMP_FS channel:0x00 frame:106 vi_tstamp:5429050817 data:0x00000000
     kworker/4:1-733   [004] ....   164.998013: rtcpu_vinotify_event: tstamp:5429051436 tag:CHANSEL_PXL_SOF channel:0x00 frame:106 vi_tstamp:5429051068 data:0x00000001
 vi-output, ov56-7996  [005] ....   165.019743: tegra_channel_capture_frame: sof:164.909711072
     kworker/4:1-733   [004] ....   165.054021: rtcpu_vinotify_event: tstamp:5430103134 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:106 vi_tstamp:5430102791 data:0x08000000
     kworker/4:1-733   [004] ....   165.054025: rtcpu_vinotify_event: tstamp:5430194850 tag:CHANSEL_PXL_EOF channel:0x00 frame:106 vi_tstamp:5430194228 data:0x01df0002
     kworker/4:1-733   [004] ....   165.054026: rtcpu_vinotify_event: tstamp:5430194965 tag:ATOMP_FE channel:0x00 frame:106 vi_tstamp:5430194355 data:0x00000000
     kworker/4:1-733   [004] ....   165.054026: rtcpu_vinotify_event: tstamp:5430215902 tag:ATOMP_FS channel:0x00 frame:107 vi_tstamp:5430215405 data:0x00000000
     kworker/4:1-733   [004] ....   165.054027: rtcpu_vinotify_event: tstamp:5430216017 tag:CHANSEL_PXL_SOF channel:0x00 frame:107 vi_tstamp:5430215655 data:0x00000001
     kworker/4:1-733   [004] ....   165.054028: rtcpu_vinotify_event: tstamp:5430218933 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:107 vi_tstamp:5430218608 data:0x08000000
 vi-output, ov56-7996  [005] ....   165.057005: tegra_channel_capture_frame: sof:164.946977728
     kworker/4:1-733   [004] ....   165.110177: rtcpu_vinotify_event: tstamp:5431359440 tag:CHANSEL_PXL_EOF channel:0x00 frame:107 vi_tstamp:5431358816 data:0x01df0002
     kworker/4:1-733   [004] ....   165.110187: rtcpu_vinotify_event: tstamp:5431359556 tag:ATOMP_FE channel:0x00 frame:107 vi_tstamp:5431358937 data:0x00000000
     kworker/4:1-733   [004] ....   165.110189: rtcpu_vinotify_event: tstamp:5431380524 tag:ATOMP_FS channel:0x00 frame:108 vi_tstamp:5431379993 data:0x00000000
     kworker/4:1-733   [004] ....   165.110191: rtcpu_vinotify_event: tstamp:5431380638 tag:CHANSEL_PXL_SOF channel:0x00 frame:108 vi_tstamp:5431380238 data:0x00000001
     kworker/4:1-733   [004] ....   165.110203: rtos_queue_peek_from_isr_failed: tstamp:5432357173 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   165.110205: rtcpu_vinotify_event: tstamp:5432524032 tag:CHANSEL_PXL_EOF channel:0x00 frame:108 vi_tstamp:5432523404 data:0x01df0002
     kworker/4:1-733   [004] ....   165.110207: rtcpu_vinotify_event: tstamp:5432524151 tag:ATOMP_FE channel:0x00 frame:108 vi_tstamp:5432523525 data:0x00000000
 vi-output, ov56-7996  [004] ....   165.131546: tegra_channel_capture_frame: sof:165.21511328
     kworker/4:1-733   [004] ....   165.166047: rtcpu_vinotify_event: tstamp:5433709668 tag:ATOMP_FS channel:0x00 frame:110 vi_tstamp:5433709163 data:0x00000000
     kworker/4:1-733   [004] ....   165.166051: rtcpu_vinotify_event: tstamp:5433709785 tag:CHANSEL_PXL_SOF channel:0x00 frame:110 vi_tstamp:5433709413 data:0x00000001
     kworker/4:1-733   [004] ....   165.166052: rtcpu_vinotify_event: tstamp:5433712743 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:110 vi_tstamp:5433712414 data:0x08000000
 vi-output, ov56-7996  [004] ....   165.168802: tegra_channel_capture_frame: sof:165.58778176
     kworker/4:1-733   [004] ....   165.221983: rtcpu_vinotify_event: tstamp:5434853199 tag:CHANSEL_PXL_EOF channel:0x00 frame:110 vi_tstamp:5434852574 data:0x01df0002
     kworker/4:1-733   [004] ....   165.221987: rtcpu_vinotify_event: tstamp:5434853314 tag:ATOMP_FE channel:0x00 frame:110 vi_tstamp:5434852701 data:0x00000000
     kworker/4:1-733   [004] ....   165.221988: rtcpu_vinotify_event: tstamp:5434874247 tag:ATOMP_FS channel:0x00 frame:111 vi_tstamp:5434873751 data:0x00000000
     kworker/4:1-733   [004] ....   165.221988: rtcpu_vinotify_event: tstamp:5434874362 tag:CHANSEL_PXL_SOF channel:0x00 frame:111 vi_tstamp:5434874002 data:0x00000001
     kworker/4:1-733   [004] ....   165.221989: rtcpu_vinotify_event: tstamp:5436017783 tag:CHANSEL_PXL_EOF channel:0x00 frame:111 vi_tstamp:5436017163 data:0x01df0002
     kworker/4:1-733   [004] ....   165.221990: rtcpu_vinotify_event: tstamp:5436017898 tag:ATOMP_FE channel:0x00 frame:111 vi_tstamp:5436017283 data:0x00000000
 vi-output, ov56-7996  [005] ....   165.243328: tegra_channel_capture_frame: sof:165.133311648
     kworker/4:1-733   [004] ....   165.278003: rtcpu_vinotify_event: tstamp:5437203423 tag:ATOMP_FS channel:0x00 frame:113 vi_tstamp:5437202922 data:0x00000000
     kworker/4:1-733   [004] ....   165.278007: rtcpu_vinotify_event: tstamp:5437203540 tag:CHANSEL_PXL_SOF channel:0x00 frame:113 vi_tstamp:5437203173 data:0x00000001
     kworker/4:1-733   [004] ....   165.278008: rtcpu_vinotify_event: tstamp:5437205881 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:113 vi_tstamp:5437205552 data:0x08000000
     kworker/4:1-733   [004] ....   165.278011: rtos_queue_peek_from_isr_failed: tstamp:5437357153 queue:0x0b4b6398
 vi-output, ov56-7996  [005] ....   165.280603: tegra_channel_capture_frame: sof:165.170578432
     kworker/4:1-733   [004] ....   165.334038: rtcpu_vinotify_event: tstamp:5438346977 tag:CHANSEL_PXL_EOF channel:0x00 frame:113 vi_tstamp:5438346338 data:0x01df0002
     kworker/4:1-733   [004] ....   165.334042: rtcpu_vinotify_event: tstamp:5438347097 tag:ATOMP_FE channel:0x00 frame:113 vi_tstamp:5438346460 data:0x00000000
     kworker/4:1-733   [004] ....   165.334044: rtcpu_vinotify_event: tstamp:5438368010 tag:ATOMP_FS channel:0x00 frame:114 vi_tstamp:5438367509 data:0x00000000
     kworker/4:1-733   [004] ....   165.334045: rtcpu_vinotify_event: tstamp:5438368122 tag:CHANSEL_PXL_SOF channel:0x00 frame:114 vi_tstamp:5438367760 data:0x00000001
     kworker/4:1-733   [004] ....   165.334046: rtcpu_vinotify_event: tstamp:5439511552 tag:CHANSEL_PXL_EOF channel:0x00 frame:114 vi_tstamp:5439510927 data:0x01df0002
     kworker/4:1-733   [004] ....   165.334047: rtcpu_vinotify_event: tstamp:5439511675 tag:ATOMP_FE channel:0x00 frame:114 vi_tstamp:5439511047 data:0x00000000
 vi-output, ov56-7996  [000] ....   165.355228: tegra_channel_capture_frame: sof:165.245112096
     kworker/4:1-733   [004] ....   165.390114: rtcpu_vinotify_event: tstamp:5440697190 tag:ATOMP_FS channel:0x00 frame:116 vi_tstamp:5440696686 data:0x00000000
     kworker/4:1-733   [004] ....   165.390134: rtcpu_vinotify_event: tstamp:5440697308 tag:CHANSEL_PXL_SOF channel:0x00 frame:116 vi_tstamp:5440696937 data:0x00000001
     kworker/4:1-733   [004] ....   165.390138: rtcpu_vinotify_event: tstamp:5440702781 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:116 vi_tstamp:5440702454 data:0x08000000
 vi-output, ov56-7996  [000] ....   165.392511: tegra_channel_capture_frame: sof:165.282378688
     kworker/4:1-733   [004] ....   165.446053: rtcpu_vinotify_event: tstamp:5441840831 tag:CHANSEL_PXL_EOF channel:0x00 frame:116 vi_tstamp:5441840097 data:0x01df0002
     kworker/4:1-733   [004] ....   165.446058: rtcpu_vinotify_event: tstamp:5441841120 tag:ATOMP_FE channel:0x00 frame:116 vi_tstamp:5441840217 data:0x00000000
     kworker/4:1-733   [004] ....   165.446059: rtcpu_vinotify_event: tstamp:5441861858 tag:ATOMP_FS channel:0x00 frame:117 vi_tstamp:5441861268 data:0x00000000
     kworker/4:1-733   [004] ....   165.446060: rtcpu_vinotify_event: tstamp:5441862137 tag:CHANSEL_PXL_SOF channel:0x00 frame:117 vi_tstamp:5441861518 data:0x00000001
     kworker/4:1-733   [004] ....   165.446064: rtos_queue_peek_from_isr_failed: tstamp:5442357147 queue:0x0b4b6398
     kworker/4:1-733   [004] ....   165.446066: rtcpu_vinotify_event: tstamp:5443005315 tag:CHANSEL_PXL_EOF channel:0x00 frame:117 vi_tstamp:5443004691 data:0x01df0002
     kworker/4:1-733   [004] ....   165.446067: rtcpu_vinotify_event: tstamp:5443005468 tag:ATOMP_FE channel:0x00 frame:117 vi_tstamp:5443004812 data:0x00000000
 vi-output, ov56-7996  [000] ....   165.466955: tegra_channel_capture_frame: sof:165.356912352
Wow, that’s weird!! Maybe modify the sensor driver to report less pixel one by one to check if any different in the trace.
Hi @ShaneCCC,
Currently, the resolution is 1280*480, should i modify the pixels or lines?
Modify the driver report less width like 1200480, 1100480 …
And monitor the trace log to check until short line become long line to narrow if there’s a right size there.
