I have an Asus ROG G16 laptop with an RTX 3070 card (in addition to onboard Intel Graphics). I dual-boot windows 11 and Ubuntu 22.10 (Kubuntu) with kernel version 5.19.0-26-generic.
I am experiencing major issues with getting my graphics card to function properly.
The nvidia-smi
command claims that no devices were found:
$ sudo nvidia-smi
No devices were found
The lspci
command can however detect that my card exists:
$ lspci | grep -i nvidia
0000:01:00.0 VGA compatible controller: **NVIDIA** Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q] (rev a1)
0000:01:00.1 Audio device: **NVIDIA** Corporation GA104 High Definition Audio Controller (rev a1)
Summary of things I have tried:
Uninstalled and reinstalled multiple different driver versions from Kubuntu system settings → driver manager → additional drivers.
Uninstalled and reinstalled multiple different driver versions from terminal using
sudo apt install nvidia-driver-<VERSION>
, with version ranging from 370 to the latest 525. -
Tried to install drivers using downloaded .run file.
Disabled secure boot in bios.
I am not very knowledgeable about Linux so its hard for me to say what kind of terminal diagnostics are relevant to include here. I saw in a similar post that the output of dmesg | grep NVRM
was requested, so here is mine:
$ sudo dmesg | grep NVRM
[ 5.001889] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 520.56.06 Thu Oct 6 21:38:55 UTC 2022
[ 5.083514] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 5.149043] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 5.149260] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 5.149286] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 15.140655] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 15.164991] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 15.165123] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 15.165195] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 15.281011] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 15.306521] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 15.306624] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 15.306717] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 15.422611] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 15.446260] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 15.446327] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 15.446416] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 15.562224] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 15.585241] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 15.585307] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 15.585376] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 21.299021] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 21.332227] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 21.332438] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 21.332487] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 21.448460] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 21.511453] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 21.511746] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 21.511790] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 21.627935] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 21.668575] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 21.669042] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 21.669084] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 21.784873] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 21.825147] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 21.825409] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 21.825510] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 44.397522] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 44.424461] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 44.424571] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 44.424642] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 44.540457] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 44.563659] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 44.563780] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 44.563855] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 48.385694] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 48.410188] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 48.410330] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 48.410406] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 48.526223] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 48.549633] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 48.549781] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 48.549844] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 50.460879] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 50.496846] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 50.497103] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 50.497152] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 50.612943] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 50.654096] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 50.654419] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 50.654469] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 50.770607] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 50.856642] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 50.856961] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 50.857007] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 50.972789] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 51.013607] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 51.013959] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 51.014007] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 51.139951] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 51.182697] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 51.182956] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 51.182998] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 51.298932] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 51.347209] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 51.347487] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 51.347592] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 51.464950] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 51.498892] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 51.499130] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 51.499280] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 51.615206] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 51.647347] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 51.647522] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 51.647560] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 51.766161] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 51.802039] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 51.802340] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 51.802384] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 51.918138] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 51.961706] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 51.962033] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 51.962074] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 52.077914] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 52.114779] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 52.115000] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 52.115041] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 52.230943] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 52.265464] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 52.265674] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 52.265705] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 52.389522] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 52.417144] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 52.417337] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 52.417432] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 52.533390] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 52.557218] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 52.557424] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 52.557457] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 52.673371] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 52.697794] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 52.697937] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 52.697994] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 52.813808] NVRM: GPU 0000:01:00.0: Failed to enable MSI; falling back to PCIe virtual-wire interrupts.
[ 52.846066] NVRM: GPU 0000:01:00.0: Failed to copy vbios to system memory.
[ 52.846262] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x30:0xffff:931)
[ 52.846370] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
I am also attaching my nvidia-bug-report.log.gz
file.
Would be greatful for any help.
nvidia-bug-report.log.gz (278.9 KB)
