Unable to get parent for NvDsObjectMeta object
Jetson Orin
• DeepStream Version
6.1.1
5.0.2
• TensorRT Version
8.4.1-1+cuda11.4
Hello I am unable to get the parent object of my secondary detector:
print(obj_meta.parent.object_id)
AttributeError: 'NoneType' object has no attribute 'object_id'
This is my pipeline:
# linking elements
  queue.link(nvvidconv1)
  nvvidconv1.link(filter1)
  filter1.link(nvvidconv)
  nvvidconv.link(nvosd)
  nvosd.link(tee)
  queue1.link(msgconv)
  msgconv.link(msgbroker)
  queue2.link(nvvidconv_postosd)
  nvvidconv_postosd.link(caps)
  caps.link(encoder)
  encoder.link(rtppay)
  rtppay.link(sink)
How can I fix this?
Which plugin do you add probe function to? You can try to change the position of the probe function.
@yuweiw I use :
nvosd_sink_pad = nvosd.get_static_pad("src")
nvosd_sink_pad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
@yuweiw
If I use sgie2.get_static_pad("src") it works and I get the right values for the NvDsObjectMeta object but I am cropping the detections using opencv therefore I can’t use that because I get the following message:
get_nvds_buf_Surface: Currently we only support RGBA color Format
I am already using nvvidconv1 and filter1 to convert the frames to RGBA
@yuweiw
Refering to this post:
The solution was that nvvidconv element has the parent objects. But using nvvidconv.get_static_pad("sink") Still gives me :
Here is my main:
def main(uri_inputs,codec,bitrate ):
    # Check input arguments
    number_sources = len(uri_inputs)
    global perf_data
    perf_data = PERF_DATA(number_sources)
    global folder_name
    folder_name = "out_crops"
    # if path.exists(folder_name):
    #     sys.stderr.write("The output folder %s already exists. Please remove it first.\n" % folder_name)
    #     sys.exit(1)
    # os.mkdir(folder_name)
    # print("Frames will be saved in ", folder_name)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        #os.mkdir(folder_name + "/stream_" + str(i))
        frame_count["stream_" + str(i)] = 0
        saved_count["stream_" + str(i)] = 0
        print("Creating source_bin ", i, " \n ")
        uri_name = uri_inputs[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    q = Gst.ElementFactory.make("queue", "queue1")
    # Primary detector
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    # creating tracker
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    # Secondary detector
    sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie1 \n")
    # Third Detector
    sgie2 = Gst.ElementFactory.make("nvinfer", "secondary2-nvinference-engine")
    if not sgie2:
        sys.stderr.write(" Unable to make sgie2 \n")
    print("Creating nvstreamdemux \n ")
    nvstreamdemux = Gst.ElementFactory.make("nvstreamdemux", "nvstreamdemux")
    if not nvstreamdemux:
        sys.stderr.write(" Unable to create nvstreamdemux \n")
    if is_live:
        print("Atleast one of the sources is live")
        streammux.set_property("live-source", 1)
    #print("Creating tiler \n ")
    # tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    # if not tiler:
    #     sys.stderr.write(" Unable to create tiler \n")
    # fake sink
    # sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
    # if not sink:
    #    sys.stderr.write("ERROR: Unable to create FAKE sink\n")
    #    sys.exit(1)
    # sink.set_property("sync", 0)
    print("Playing file {} ".format(uri_inputs))
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', "config_infer_primary.txt")
    sgie1.set_property('config-file-path', "config_infer_secondary.txt")
    sgie2.set_property('config-file-path', "config_infer_third.txt")
    pgie_batch_size = pgie.get_property("batch-size")
    if (pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size", pgie_batch_size, " with number of sources ",
              number_sources, " \n")
        pgie.set_property("batch-size", number_sources)
    # tiler_rows = int(math.sqrt(number_sources))
    # tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
    # tiler.set_property("rows", tiler_rows)
    # tiler.set_property("columns", tiler_columns)
    # tiler.set_property("width", TILED_OUTPUT_WIDTH)
    # tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    #Set properties of tracker
    config = configparser.ConfigParser()
    config.read('dstest_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config.getint('tracker', key)
            tracker.set_property('enable_batch_process', tracker_enable_batch_process)
        if key == 'enable-past-frame' :
            tracker_enable_past_frame = config.getint('tracker', key)
            tracker.set_property('enable_past_frame', tracker_enable_past_frame)
    if not is_aarch64():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        # nvvidconv.set_property("nvbuf-memory-type", mem_type)
        # nvvidconv1.set_property("nvbuf-memory-type", mem_type)
        #tiler.set_property("nvbuf-memory-type", mem_type)
    print("Adding elements to Pipeline \n")
    pipeline.add(q)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(nvstreamdemux)
    # #pipeline.add(tiler)
    #streammux.link(pgie)
    streammux.link(q)
    q.link(pgie)
    # pgie.link(nvvidconv1)
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(nvstreamdemux)
            # Make the UDP sink
        port = "540"+str(i)
        updsink_port_num = int(port)
        #sink = Gst.ElementFactory.make("udpsink", "udpsink")
        sink = make_element("udpsink", i)
        if not sink:
            sys.stderr.write(" Unable to create udpsink")
        sink.set_property('host', '224.224.255.255')
        sink.set_property('port', updsink_port_num)
        sink.set_property('async', False)
        sink.set_property('sync', 0)
        #pipeline.add(sink)
        # creating queue
        queue = make_element("queue", i)
        pipeline.add(queue)
        # Add nvvidconv1 and filter1 to convert the frames to RGBA
        # which is easier to work with in Python.
        print("Creating nvvidconv1 \n ")
        #nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
        nvvidconv1 = make_element("nvvideoconvert", "nvvideoconvert"+str(i))
        if not nvvidconv1:
            sys.stderr.write(" Unable to create nvvidconv1 \n")
        print("Creating nvvidconv \n ")
        #nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
        nvvidconv = make_element("nvvideoconvert", "nvvidconv"+str(i))
        if not nvvidconv:
            sys.stderr.write(" Unable to create nvvidconv \n")
        #nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
        nvvidconv_postosd = make_element("nvvideoconvert", "nvvidconv_postosd"+str(i))
        if not nvvidconv_postosd:
            sys.stderr.write(" Unable to create nvvidconv_postosd \n")
        print("Creating nvosd \n ")
        #nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
        nvosd = make_element("nvdsosd", i)
        if not nvosd:
            sys.stderr.write(" Unable to create nvosd \n")
        nvosd.set_property("process-mode", OSD_PROCESS_MODE)
        nvosd.set_property("display-text", OSD_DISPLAY_TEXT)
        # connect nvstreamdemux -> queue
        padname = "src_%u" % i
        demuxsrcpad = nvstreamdemux.get_request_pad(padname)
        if not demuxsrcpad:
            sys.stderr.write("Unable to create demux src pad \n")
        queuesinkpad = queue.get_static_pad("sink")
        if not queuesinkpad:
            sys.stderr.write("Unable to create queue sink pad \n")
        demuxsrcpad.link(queuesinkpad)
        print("Creating filter1 \n ")
        caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
        #filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
        filter1 = make_element("capsfilter", "filter1"+str(i))
        if not filter1:
            sys.stderr.write(" Unable to get the caps filter1 \n")
        filter1.set_property("caps", caps1)
        #msgconv = Gst.ElementFactory.make("nvmsgconv", "nvmsg-converter")
        msgconv = make_element("nvmsgconv", i)
        if not msgconv:
            sys.stderr.write(" Unable to create msgconv \n")
        msgbroker = Gst.ElementFactory.make("nvmsgbroker", "nvmsg-broker")
        msgbroker = make_element("nvmsgbroker", i)
        if not msgbroker:
            sys.stderr.write(" Unable to create msgbroker \n")
        msgconv.set_property('config', MSCONV_CONFIG_FILE)
        msgconv.set_property('payload-type', schema_type)
        msgbroker.set_property('proto-lib', proto_lib)
        msgbroker.set_property('conn-str', conn_str)
        # if cfg_file is not None:
        #     msgbroker.set_property('config', cfg_file)
        # if topic is not None:
        #     msgbroker.set_property('topic', topic)
        msgbroker.set_property('sync', False)
        #tee = Gst.ElementFactory.make("tee", "nvsink-tee")
        tee = make_element("tee", i)
        if not tee:
            sys.stderr.write(" Unable to create tee \n")
        #queue1 = Gst.ElementFactory.make("queue", "nvtee-que1")
        queue1 = make_element("queue", "queue1"+str(i))
        if not queue1:
            sys.stderr.write(" Unable to create queue1 \n")
        #queue2 = Gst.ElementFactory.make("queue", "nvtee-que2")
        queue2 = make_element("queue", "queue2"+str(i))
        if not queue2:
            sys.stderr.write(" Unable to create queue2 \n")
        # Create a caps filter
        #caps = Gst.ElementFactory.make("capsfilter", "filter")
        caps = make_element("capsfilter", "caps"+str(i))
        caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
        # Make the encoder
        if codec == "H264":
            #encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
            encoder = make_element("nvv4l2h264enc", i)
            print("Creating H264 Encoder")
        elif codec == "H265":
            #encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
            encoder = make_element("nvv4l2h265enc", i)
            print("Creating H265 Encoder")
        if not encoder:
            sys.stderr.write(" Unable to create encoder")
        encoder.set_property('bitrate', bitrate)
        if is_aarch64():
            encoder.set_property('preset-level', 1)
            encoder.set_property('insert-sps-pps', 1)
            #encoder.set_property('bufapi-version', 1)
        # Make the payload-encode video into RTP packets
        if codec == "H264":
            #rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
            rtppay = make_element("rtph264pay", i)
            print("Creating H264 rtppay")
            #rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
            rtppay = make_element("rtph265pay", i)
            print("Creating H265 rtppay")
        if not rtppay:
            sys.stderr.write(" Unable to create rtppay")
        pipeline.add(nvvidconv)
        pipeline.add(filter1)
        pipeline.add(nvvidconv1)
        pipeline.add(nvosd)
        pipeline.add(tee)
        pipeline.add(queue1)
        pipeline.add(queue2)
        pipeline.add(msgconv)
        pipeline.add(msgbroker)
        pipeline.add(nvvidconv_postosd)
        pipeline.add(caps)
        pipeline.add(encoder)
        pipeline.add(rtppay)
        pipeline.add(sink)
        # linking elements
        nvosd.link(tee)
        caps.link(encoder)
        rtppay.link(sink)
        sink_pad = queue1.get_static_pad("sink")
        tee_msg_pad = tee.get_request_pad('src_%u')
        tee_render_pad = tee.get_request_pad("src_%u")
        if not tee_msg_pad or not tee_render_pad:
            sys.stderr.write("Unable to get request pads\n")
        tee_msg_pad.link(sink_pad)
        sink_pad = queue2.get_static_pad("sink")
        tee_render_pad.link(sink_pad)
        sink.set_property("qos", 0)
        # Start streaming
        rtsp_port = "855"+str(i)
        rtsp_port_num = int(rtsp_port)
        server = GstRtspServer.RTSPServer.new()
        server.props.service = "%d" % rtsp_port_num
        server.attach(None)
        factory = GstRtspServer.RTSPMediaFactory.new()
        factory.set_launch( "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (updsink_port_num, codec))
        factory.set_shared(True)
        fac = "/ds-test" + str(i)
        server.get_mount_points().add_factory(fac, factory)
        print("\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/%s ***\n\n" % (rtsp_port_num,str(fac)))
        # nvosd_sink_pad = nvosd.get_static_pad("src")
        nvosd_sink_pad = nvvidconv.get_static_pad("sink")
        if not nvosd_sink_pad:
            sys.stderr.write(" Unable to get sink pad \n")
        else:
            # perf callback function to print fps every 5 sec
            GLib.timeout_add(4000, perf_data.perf_print_callback)
    print("Linking elements in the Pipeline \n")
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pyds.unset_callback_funcs()
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
    parser.add_argument("-i","--uri_inputs", metavar='N', type=str, nargs='+',
                    help='Path to inputs URI e.g. rtsp:// ...  or file:// seperated by space')
    parser.add_argument("-c", "--codec", default="H264",
                  help="RTSP Streaming Codec H264/H265 , default=H264", choices=['H264','H265'])
    parser.add_argument("-b", "--bitrate", default=4000000,
                  help="Set the encoding bitrate ", type=int)
    if len(sys.argv)==1:
        parser.print_help(sys.stderr)
        sys.exit(1)
    args = parser.parse_args()
    print("URI Inputs: " + str(args.uri_inputs ))
    return args.uri_inputs , args.codec, args.bitrate
if __name__ == '__main__':
    uri_inputs , out_codec, out_bitrate = parse_args()
    sys.exit(main(uri_inputs, out_codec, out_bitrate ))
Could you try to use our demo code first and add probe function to get the parent para?
1.You can find a similar demo below:
https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/apps
2.Run the demo code and find if it still has the problem.
3.Modify your own code by refering our demo code.
@yuweiw my code is based on deepstream-imagedata-multistream-redaction.py there tiler_sink_pad = tiler.get_static_pad("sink") is being used.
I removed the tiler to use nvstreamdemux instead. I got the example from:
deepstream_demux_multi_in_multi_out.py, there pgie_src_pad = pgie.get_static_pad("src") is being used but I can’t use that because I am cropping images using opencv.
I also modified it with deepstream-test4.py to be able to send JSON payloads through Kafka, there osdsinkpad = nvosd.get_static_pad("sink") is being used and using nvosd gives me null values for the obj_meta object parent.
I already tested the examples and the examples work fine.
My code is basically a combination of those three demos. I can see the Rtsp stream outputs with bboxes for all input streams and The messages are being send through Kafka. Could you please help me look into it?
@yuweiw Since using sgie2.get_static_pad("src") seems to give me the right output for obj_meta.parent.object_id but giving me the error: get_nvds_buf_Surface: Currently we only support RGBA color Format.
I am converting the numpy array detection to base 64, so that is why I need opencv but,
Is there any other way that I can crop the detections and convert them to base64 string other than using opencv?
Edit:
Refering to this, very similar to my case. There is no way to get the parent object after nvstreamdemux. Makes sense I can only utilize sgie2.get_static_pad("src") to get the parent. How can I pass the detection images and the object parent using nvstreamdemux?
@user133662 , We sugget you add nvvideoconvert plugin before SGIE to change the video format to RGBA. The parent para is NULL after the streammux, demux, tiler and videoconvert.
