Unable to get stream ids correctly , stream id is always 0
Hardware Platform (Jetson / GPU): GPU
DeepStream Version: 7.0
TensorRT Version: 8.6.1.6
NVIDIA GPU Driver Version (valid for GPU only): 535.183.01
Issue Type: Question / Debugging assistance
Description:
I am running deepstream-app with a multistream setup (8 streams) and attempting to print the source_id of each frame inside the process_meta function in deepstream_app.c. My main goal is to separate detections for each stream by checking the stream_id.
I am currently using the following code snippet:
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) l_frame->data;
stream_id = frame_meta->source_id;
printf("Processing detections for Stream ID: %d\n", stream_id);
However, the output always shows Stream ID as 0 for all frames:
Processing detections for Stream ID: 0
I have attached the relevant deepstream_app.c file.
deepstream_app.txt (72.8 KB)
nvmultistreamtiler will compose a batch to one frame. you need to add probe before tiler plugin. you can add the printing code in analytics_done_buf_prob function.
thank you for helping me, I just started to learn deepstream, could you provide more detailed explanation or can you share any useful link for this ?
Sorry for the late reply! please refer to nvmultistreamtiler. after nvmultistreamtiler, there is only frame in batch.
