I tried using this method of flashing and it appears to get stuck “waiting for target to boot-up…” Is this function supported on the xavier rouge base?
I’ve already disabled udisks2.service and tried using different cables and ports on my flash computer, dependencies are also already installed as per attached instructions. I verified I can flash the Xavier normally after installing the latest CTI BSP.
I am running: JetPack 4.6.1 - L4T r32.6.1 & AGX L4T r32.6.1 BSP, attached are logs from the host machine and the Xavier serial console.
initrd_bootlog.txt (71.8 KB)
initrd_host.txt (9.5 KB)
