I am trying to install deepstream using the apt repository.
Here is my output:
vscode ➜ /workspaces/ds (master ✗) $ sudo apt install deepstream-5.0
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
deepstream-5.0:arm64 : Depends: libvisionworks-dev:arm64 (>= 1.6.0) but it is not installable
E: Unable to correct problems, you have held broken packages.
vscode ➜ /workspaces/ds (master ✗) $ sudo apt install libvisionworks-dev
libvisionworks-dev : Depends: libvisionworks (= 1.6.0.501) but it is not installable
Recommends: cuda-cudart-dev-10-2 but it is not installable or
nvidia-cuda-dev (>= 10.2) but 9.2.148-7+deb10u1 is to be installed
Recommends: libopencv-dev (>= 4.1.1) but it is not going to be installed
vscode ➜ /workspaces/ds (master ✗) $ dpkg -l | grep libvisionworks
ii libvisionworks:arm64 1.6.0.501 arm64 NVIDIA's VisionWorks Library and supplemental data
It seems like the libvisionworks-dev
package depends on the libvisionworks
package, but it is alreay installed.
Any suggestions?
