Unable to install pymavlink on Jetson Nano
Hi im unable to install pymavlink on my jetson nano 2gb with jetpack 4.6
I’m getting error:-
ERROR: Failed building wheel for pymavlink
Running setup.py clean for pymavlink
Failed to build pymavlink
Installing collected packages: pymavlink
Running setup.py install for pymavlink … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/setup.py’"’"’; file=’"’"’/tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/setup.py’"’"’;f = getattr(tokenize, ‘"’"‘open’"’"’, open)(file) if os.path.exists(file) else io.StringIO(’"’"‘from setuptools import setup; setup()’"’"’);code = f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /tmp/pip-record-ohf9t1s_/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/enord/.local/include/python3.6m/pymavlink
cwd: /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/
Complete output (142 lines):
running install
running build
running build_py
Using message definitions from /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/ASLUAV.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/matrixpilot.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/uAvionix.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/python_array_test.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/test.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/storm32.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/AVSSUAS.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/common.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/paparazzi.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/standard.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/ualberta.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/development.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/icarous.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/ardupilotmega.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/minimal.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/all.xml for protocol 1.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/ASLUAV.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/matrixpilot.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/uAvionix.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/python_array_test.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/test.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/storm32.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/AVSSUAS.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/common.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/paparazzi.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/standard.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/ualberta.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/development.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/icarous.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/ardupilotmega.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/minimal.xml for protocol 2.0
Building /tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/message_definitions/v1.0/all.xml for protocol 2.0
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/pymavlink
copying ./DFReader.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./mavexpression.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./quaternion.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./rotmat.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./mavutil.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./CSVReader.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./mavparm.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./init.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./fgFDM.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./mavtestgen.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./mavwp.py → build/lib.linux-aarch64-3.6/pymavlink
copying ./mavextra.py → build/lib.linux-aarch64-3.6/pymavlink
creating build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_javascript_stable.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_cs.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_python.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavparse.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavtemplate.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavcrc.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_swift.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_java.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_cpp11.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_wlua.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_c.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_objc.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/init.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_typescript.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_lua.py → build/lib.linux-aarch64-3.6/pymavlink/generator
copying ./generator/mavgen_javascript.py → build/lib.linux-aarch64-3.6/pymavlink/generator
creating build/lib.linux-aarch64-3.6/pymavlink/dialects
copying ./dialects/init.py → build/lib.linux-aarch64-3.6/pymavlink/dialects
creating build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/development.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/test.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/python_array_test.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/ASLUAV.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/matrixpilot.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/standard.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/all.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/AVSSUAS.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/uAvionix.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/storm32.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/minimal.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/ardupilotmega.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/ualberta.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/init.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/icarous.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/paparazzi.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
copying ./dialects/v10/common.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v10
creating build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/development.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/test.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/python_array_test.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/ASLUAV.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/matrixpilot.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/standard.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/all.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/AVSSUAS.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/uAvionix.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/storm32.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/minimal.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/ardupilotmega.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/ualberta.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/init.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/icarous.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/paparazzi.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
copying ./dialects/v20/common.py → build/lib.linux-aarch64-3.6/pymavlink/dialects/v20
creating build/lib.linux-aarch64-3.6/pymavlink/mavnative
copying ./mavnative/mavlink_defaults.h → build/lib.linux-aarch64-3.6/pymavlink/mavnative
File “”, line 1, in
File “/tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/setup.py”, line 181, in
ext_modules = extensions
File “/usr/local/lib/python3.6/dist-packages/setuptools/init.py”, line 163, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py”, line 61, in run
return orig.install.run(self)
File “/usr/lib/python3.6/distutils/command/install.py”, line 589, in run
self.run_command(‘build’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/usr/lib/python3.6/distutils/command/build.py”, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File “/tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/setup.py”, line 106, in run
build_py.run(self)
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/build_py.py”, line 58, in run
self.build_package_data()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/build_py.py”, line 132, in build_package_data
srcfile in self.distribution.convert_2to3_doctests):
AttributeError: ‘Distribution’ object has no attribute ‘convert_2to3_doctests’
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/setup.py’"’"’; file=’"’"’/tmp/pip-install-8xnz4zi7/pymavlink_dff49ee600b148aaab83e0b39a624d86/setup.py’"’"’;f = getattr(tokenize, ‘"’"‘open’"’"’, open)(file) if os.path.exists(file) else io.StringIO(’"’"‘from setuptools import setup; setup()’"’"’);code = f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /tmp/pip-record-ohf9t1s_/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/enord/.local/include/python3.6m/pymavlink Check the logs for full command output.
Please help regarding the issue!!
I don’t have answer for the pymavlink installation, may other developers help to share experiences. Thanks
