Unable to install pytorch and torchvision on jetson orin
Hello @vai95.kavathekar
Yes, it seems that the link is broken. However, from How to get Pytorch to work on jetson Orin Nano - #5 by AastaLLL they mentioned that they moved the packages for JetPack 6.2 to that link.
@AastaLLL could you please help with the broken link?
For JetPack 5.1, I used the link that you posted, PyTorch for Jetson. So, I would use the packages from there if I needed.
Regards!
