Unable to join Panda arm and Robotiq-2f-140 gripper, parallel gripper
Hi Guys @philipp.reist, @rthaker, @hijimasa @AlesBorovicka ,
I am facing one issue from last 2 days, I made a Robot by joining 2 robots from isaac sim assets, so no urdfs only usd’s.
After seeing some similar questions in forum, I tried all the things but nothing is working.
  1. first I added both by removing last 3 links of panda and attaching the gripper, it is working first, can able to control with articulation inspector. but when I am trying to control the gripper with code, I cannot able to use parallel gripper.
There it shows,
(i) my_world.reset() tells its not homogenous, yes bcoz it is made of 2 robots and 2 articulations. if I remove that line
(ii) parallel gripper( end_effector_prim_path) it shows did not match rigid bodies with the prim_path, and after chaning the prim_path to different links
(iii) Then it cannot able to call gripper_positions = my_denso.gripper.get_joint_positions()
shows NoneType Object has no attributes.
when doing it 4.0.0, 4.1.0, and 4.2.0 I found that one side of gripper is breaking.
Then I thought initialization of parallel gripper is not good, tried to make the robot again
  1. I saw some tutorials and tried to add the robots using robot assembler in 4.1.0 and 4.2.0, but after assemble they are not assembling gripper is going your direction. :)
  2. I thought, i am removing 3 links of robot and attaching the different robot in between, so i tried to load the panda arm from urdf only till pada_link8, then tried to attach the robotiq gripper but somehow, the gripper is touching the panda robot when gripper closes, I tried scale it to 0.8, it is not touching now, I tried to used for controlling gripper from code, same 1st process.
    link for code and one usd, i made multiple:-
    Please please Help me outhttps://drive.google.com/drive/folders/1WKY1olbEylcBE_9sxeRPRgIapAzXKNA_?usp=drive_link
Hey,
I have a similar problem with the parallel gripper. As you did, i followed the tutorial but i am getting similar errors.
Did you find a solution to this?
no dude, I didn’t get any response nor any solution. I had to change my simulation environment because of multiple issues. If u find solution, let me know.
I managed to use the parallel gripper and a robot using the SingleManipulator class. And i am using the RobotAssembler class to create a FixedJoint between the robot’s flange and the gripper base.
If you take a look at the code of the SingleManipulator class, the initialize method is handling both the surface and parallel grippers cases.
Hi @JeanLesur
I didn’t get it completely. Can you explain a bit more how did u solve the issue
