Was trying out the live mode. I created a session in Machinima, but in Create I couldn’t find the session created. Am using localhost and same user, is this still experimental?
Hello @qazs! This isn’t experimental, it should be working!
- Is the stage your are live syncing to located on your nucleus server / localhost?
- Do you have the same stage open in Machinima and Create?
Hi, when I opened the same file (Scene.usd) on both apps, I can see the same session. However when I open a layer file within Scene.usd, I don’t see the session. This seems to work a bit differently from before, where I can edit a layer file and see the changes synced on the main file. Is my observation correct?
