Unable to launch Omniverse Launcher for AODT
I have created and launched a VM with the following specifications on vSphere. I installed AODT version 1.1.1 from the installation page and extracted it using unzip -o aodt_bundle.zip. After obtaining an API key, I executed:
./aodt_bundle/install.sh localhost $NGC_CLI_API_KEY, replacing $NGC_CLI_API_KEY with the obtained API key. After the first installation, I was able to launch the Omniverse Launcher, but after a reboot, clicking on the Omniverse Launcher does not start it anymore.
Operating System: LINUX
Driver version: 535.216.01
OS: Ubuntu 22.04
Deployment:
Colocated
Ubuntu 22.04-server
CPU: 24 cores
PCIe Gen4
2x NVIDIA RTX A6000 -48 q GPUs
Memory: 128GB
Storage: 500GB
After rebooting, I executed ./aodt_bundle/install.sh localhost $NGC_CLI_API_KEY again, but clicking on the Omniverse Launcher still does not start it. The following error occurs during the execution of ./aodt_bundle/install.sh localhost $NGC_CLI_API_KEY:
./aodt_bundle/install.sh: line 249: 18386 Aborted (core dumped)
nohup ./omniverse-launcher-linux.APPImage omniverse-launcher://install?path=”$(realpath $HOME/aodt_bundle/$AODT_UI_ZIP)” > OV_GUI_install.log 2>&1
I have already tried switching from SM89 to SM86, but the issue persists.
Could anyone help me understand the cause of this problem and how to resolve it?
@takanori.yatsunami02
The installation does not need to be run again after a reboot. You will need to launch backend and frontend. SM89 is correct.
  1. On command line
cd aodt_bundle/backend_bundle
docker compose -f docker-compose.yml up
This should launch three dockr processes:
clickhouse, aodt_sim, aodt_gis
  1. On another terminal, launch AODT from command line via:
    nohup ./omniverse-launcher-linux.AppImage omniverse-launcher://launch?slug=aodt > /dev/null 2>&1 &
Thank you for your response.
When I ran the command:
docker-compose -f ./backend_bundle/docker-compose.yml up
it displayed the following, and it looks like it started up correctly:
[+] Running 3/0
Container backend_bundle-clickhouse-1 Running 0.0s
Container backend_bundle-gis-1 Running 0.0s
Container backend_bundle-connector-1 Running 0.0s
Attaching to clickhouse-1, connector-1, gis-1
However, even when running the following command in a different terminal,
AODT did not start. Could you help me understand why it might not be launching?
Here is the error log. If you need additional information, please let me know.
$ nohup ./omniverse-launcher-linux.AppImage omniverse-launcher://launch?slug=aodt > /dev/null 2>&1 &
[1] 122490
$ jupyter server list
Currently running servers:
[1]+ Exit 127 nohup ./omniverse-launcher-linux.AppImage omniverse-launcher://launch?slug=aodt > /dev/null 2>&1
$ ./aodt_bundle/omniverse-launcher-linux.AppImage omniverse-launcher://launch?slug=aodt
[122573:1115/170249.715205:ERROR:ozone_platform_x11.cc(240)] Missing X server or $DISPLAY
[122573:1115/170249.715287:ERROR:env.cc(255)] The platform failed to initialize. Exiting.
The futex facility returned an unexpected error code.
@takanori.yatsunami021 I see that on another thread you have are able to launch AODT. Is the issue on this thread resolved?
I was able to start AODT successfully.
Thank you very much.
