• Hardware (T4/V100/Xavier/Nano/etc)
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Any idea how to set the $PATH for within the container?
Could you open a new terminal instead to check further?
# tao model classification_tf2 run /bin/bash
Then inside the docker,
#classification_tf2 train
It works with 2.11.0 thanks
I have also created an updated docker image from that for myself, where I have changed some of the nvidia_tf2_backend code, and for that it gives the same error, any idea?
Could you share what did you change and how to generate the new docker?
Can you login the docker and modify files , then docker commit to generate a new docker?
