Unable to link CUDA libraries with dw_ros
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
We have been trying to integrate the sample Object Detection with dw_ros framework. The sample_object_detector_tracker sample works fine when run from the /usr/local/driveworks-3.5/samples/bin folder and CUDA libraries are linked to the executable
The problem arises when we try to cross-compile a custom executable using dw_ros tutorial. In the attached CMakeLists.txt, we try to find the cuda-libs package. In the cuda-libs config file, cudart library cant be found even though the path for cudart library is given in HINTS. This the error we get when building the custom executable.
-- catkin 0.7.29
-- BUILD_SHARED_LIBS is on
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
CMake Warning at /usr/local/driveworks-3.5/samples/3rdparty/shared/cuda-libs/cuda-libs-config.cmake:15 (message):
  Could not find cudart library.  Looked in
  /../lib;/../lib/stubs;/../lib64;/../lib64/stubs
Call Stack (most recent call first):
  CMakeLists.txt:23 (find_package)
CMake Error at CMakeLists.txt:23 (find_package):
  Found package configuration file:
  but it set cuda-libs_FOUND to FALSE so package "cuda-libs" is considered to
  be NOT FOUND.
-- Configuring incomplete, errors occurred!
See also "/home/agx-pegasus/ros_radar_driver_agx/build_isolated/nv_camera_multiple_new/CMakeFiles/CMakeOutput.log".
See also "/home/agx-pegasus/ros_radar_driver_agx/build_isolated/nv_camera_multiple_new/CMakeFiles/CMakeError.log".
Makefile:820: recipe for target 'cmake_check_build_system' failed
make: *** [cmake_check_build_system] Error 1
<== Failed to process package 'nv_camera_multiple_new':
  Command '['/home/agx-pegasus/ros_radar_driver_agx/install_isolated/env.sh', 'make', 'cmake_check_build_system']' returned non-zero exit status 2
Reproduce this error by running:
==> cd /home/agx-pegasus/ros_radar_driver_agx/build_isolated/nv_camera_multiple_new && /home/agx-pegasus/ros_radar_driver_agx/install_isolated/env.sh make cmake_check_build_system
Command failed, exiting.
The cuda-libs-config.cmake file is attached for reference. We get Unable to find cudart library linkage error. The issue is similar with cublas and other CUDA related libraries.
cuda-libs-config.cmake (1.0 KB)
CMakeLists.txt (1.8 KB)
Hi
Are you in NVIDIA DRIVE™ Developer Program for DRIVE AGX?
If yes, please help to change your DevZone account to use corporate or university email address by following below links.
My Profile | NVIDIA Developer → “Edit Profile” → “Change email” → “CHANGE”
The option to change email address was not available. I also tried to do in few ways but could not. And the email that is linked to NVIDIA account is not a corporate or university account so I can’t be a part of NVIDIA DRIVE developer program for DRIVE AGX. Would really like some help on the issue I am facing.
I can see your new post - Unable to link CUDA libraries with dw_ros - DRIVE AGX / DRIVE AGX General - NVIDIA Developer Forums
We can start from there. Thanks
