I would like to build a c++ application that links against nvinfer_lean_static.a.
So far no problem, but when I try to add cuda files I get linker errors like:
undefined reference to `__aarch64_swp4_sync'
undefined reference to `__aarch64_cas4_sync'
Here is a small CMakeLists.txt to reprocudce the probelm:
cmake_minimum_required(VERSION 3.17)
project(TestNVInfer LANGUAGES CXX CUDA)
find_library(NVINFER_LIBRARY libnvinfer_lean_static.a REQUIRED)
find_library(NVINFERPLUGIN libnvinfer_plugin_static.a REQUIRED)
find_package(CUDAToolkit REQUIRED)
file(WRITE ${CMAKE_CURRENT_BINARY_DIR}/main.cpp "
#include <NvInfer.h>
#include <NvInferRuntime.h>
#include <iostream>
#include <memory>
#include <vector>
#include <string>
// Simple logger implementation for TensorRT
class Logger : public nvinfer1::ILogger
void log(Severity severity, const char* msg) noexcept override
// Only log messages with severity \>= kWARNING
if (severity <= Severity::kWARNING)
std::cout << msg << std::endl;
int main()
Logger logger;
std::vector<char> engineData;
auto infer = std::unique_ptr<nvinfer1::IRuntime>(nvinfer1::createInferRuntime(logger));
auto engine = std::unique_ptr<nvinfer1::ICudaEngine>(infer->deserializeCudaEngine(engineData.data(), engineData.size()));
auto context = std::unique_ptr<nvinfer1::IExecutionContext>(engine->createExecutionContext());
return 0;
file(WRITE ${CMAKE_CURRENT_BINARY_DIR}/test_kernel.cu "
#include <math.h>
#include <cuda_runtime.h>
__global__ void copyData(float* layerMemoryPtr, unsigned char* inputDataPtr, unsigned int dataSize) {
unsigned int i = blockIdx.x * blockDim.x + threadIdx.x;
if (i < dataSize) {
layerMemoryPtr[i] = static_cast<float>(inputDataPtr[i]);
void copyData(float* layerMemoryPtr, unsigned char* inputDataPtr, unsigned int dataSize, cudaStream_t stream) {
int blocks = (dataSize + 255) / 256;
copyData<<<blocks, 256, 0, stream>>>(layerMemoryPtr, inputDataPtr, dataSize);
add_executable(test_nv_infer ${CMAKE_CURRENT_BINARY_DIR}/test_kernel.cu ${CMAKE_CURRENT_BINARY_DIR}/main.cpp)
target_link_libraries(test_nv_infer
${NVINFER_LIBRARY}
${NVINFERPLUGIN}
CUDA::cudla)
The CMakeLists.txt will create the example files
Just build with:
cmake ..
make
