Unable to load archived SDK Manager version
I am unable to install SDK Manager on a new machine running Ubuntu 18.04. I successfully download the SDK Manager to my machine and run the following command to install JetPack version 4.4.1 support tools out of the archive. I get an error saying I am missing parts. Does this have to do with the system’s use of “sdkmanager” rather than sdkmanager_1.5.0-7774_amd64.deb? ubuntu@ubuntu:~/Downloads$ sudo apt install ./sdkmanager_1.5.0-7774_amd64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘sdkmanager’ instead of ‘./sdkmanager_1.5.0-7774_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager : Depends: libgconf-2-4 but it is not installable
Depends: libcanberra-gtk-module but it is not installable
E: Unable to correct problems, you have held broken packages.
Hello @rsheffield
Can you try this command:
sudo apt-get install -f
source: https://stackoverflow.com/a/26594352
Hope it works
Thanks,
I Googled and found this thread where folks were getting the identical error messages as I am on an earlier release.
Followed the instructions and it now works properly.
https://forums.developer.nvidia.com/t/unable-to-load-archived-sdk-manager-version/177729
Rod Sheffield
