I am trying to run BPNet on 1 T4 GPU on GCP using the bpnet.ipynb notebook provided. I followed the instructions to run tao on gcp and changed the ~/.tao_mounts.json file to the required paths. When I try to load the model for inference on the COCO validation dataset using the command
Single-scale inference
!tao bpnet evaluate --inference_spec $SPECS_DIR/infer_spec.yaml
–dataset_spec $DATA_POSE_SPECS_DIR/coco_spec.json
–results_dir $USER_EXPERIMENT_DIR/results/exp_m1_unpruned/eval_default
-k $KEY
it throws the following error:
2022-04-06 16:23:43,947 [INFO] root: Registry: [‘nvcr.io’]
2022-04-06 16:23:44,007 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.5-py3
2022-04-06 16:23:45.192092: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
Using TensorFlow backend.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-04-06 16:23:48,796 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-04-06 16:23:52,798 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
/usr/local/lib/python3.6/dist-packages/driveix/common/utilities/path_processing.py:74: YAMLLoadWarning: calling yaml.load() without Loader=… is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
/workspace/tao-experiments/bpnet/results/exp_m1_unpruned/eval_default
WARNING 2022-04-06 16:23:52,924 | main: No model provided! Using model_path from inference spec file.
INFO 2022-04-06 16:23:52,925 | main: Loading /workspace/tao-experiments/bpnet/models/model.etlt for evaluation
loading annotations into memory…
Done (t=9.93s)
creating index…
index created!
Done (t=0.25s)
creating index…
index created!
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/scripts/evaluate.py”, line 153, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/scripts/evaluate.py”, line 145, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/dataio/coco_dataset.py”, line 456, in infer
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/inferencer/bpnet_inferencer.py”, line 64, in init
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/utilities/tlt_utils.py”, line 185, in model_io
AssertionError: Model not found at /workspace/tao-experiments/bpnet/models/model.etlt
File “/usr/local/bin/bpnet”, line 8, in
sys.exit(main())
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/entrypoint/bpnet.py”, line 12, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/entrypoint/entrypoint.py”, line 300, in launch_job
AssertionError: Process run failed.
2022-04-06 16:24:06,802 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I started a tao-tf container to make sure the model path exists, but the error persists. How can I solve this error?
Thank you for your help!
