please help me on this, I’ve changed a mellanox switch Username admin password 7 “********” from the default username password: admin admin. And I saved it using “write memory”.
After this, I tried to login with new password. But login failed and account locked.
Do i need to reboot the switch. It’s in production now. please help me.??
To reset the system, the CPU of its management board and the “admin” password, perform the following:
Push the Reset button and keep it pressed for at least 15 seconds. You will then be able to enter without a password and set a new password for the user “admin”.
The reset button is located on the rear side of the system next to the fan status LEDs. This reset button requires a tool to be pressed.
