Unable to login through SDK Manager
I have the same problem on the SDK manager. It looks like my IP was blocked and I did “unblock” the IP from the link provided in email. However after many hours, it looks like it still is giving me a response of Incorrect email or password.
Same issue on the SDK manager. It should be caused by IP problem cause I am using VPN. Any help?
Please see this post: Reporting SDK Manager Issues
Same issue on the SDK manager.I keep getting a “Incorrect email or password”, despite having earlier reset my password.
Can you please verify that you have the “Devzone” tab selected on the login page, and not the “NVONLINE” tab?
Fred
Yes, I have the Devzone tab selected now.
Looks like your account got locked. We’ve unlocked it now. Can you please try again?
Yes! working now. Thank you Fred!
I had same issue. please check
Hi @ohshinwoo, you should now have access.
Hi @TomK, I have the same issue. Could you check?
@sahin, I just checked your account, there is nothing blocking you. Make sure you are not using a social login.
Hi @Tomk I have the same issue.
@sscsmatrix You should be good to go now.
Thank you!
Hi,@TomK,I have the same issue. please check.Thank you.
Hi @iyouju,
We checked on your account and all is in good standing. Please try logging in again.
Thanks,
Tom
It’s ok now.Thank you!
Hi im getting error of:
The email address for this account is invalid.
When trying to log-in to join the NVIDIA Developer Program Membership Required to download CuDNN
Hi @arturovidal2011 rturovidal2011
I can see that you logged into Devzone 17 hours ago. Are you still having issues?
