I have started course on jetson nano from nvidia deep learning institute. For that I have to connect to Nano via browser in headless mode and connect to it via remote JupyterLab interface. I try to login to jupyter server running in nano using Mozilla firefox but it is repeatedly asking for login password. Similar thing I tried with chrome, in that it entered into the notebook but continues to send ‘Server Connection Error’ with following message.
‘A connection to the Jupyter server could not be established. JupyterLab will continue trying to reconnect. Check your network connection or Jupyter server configuration.’
Please let me know the solution for it.
Please try the troubleshooting steps found here: [url]https://jupyter-notebook.readthedocs.io/en/stable/troubleshooting.html[/url]
Let us know how it goes.
Best,
Tom
I tried following the link but could not find solution. I have attached log of console output in chrome browser. Can you look into it and let me know what is causing that and how to fix it. Thanks.
vendors~main.4184bdce490c13d11f74.js:144505 Download the React DevTools for a better development experience: https://fb.me/react-devtools
vendors~main.4184bdce490c13d11f74.js:164508 Starting application in workspace: /lab
:8888/lab/api/workspaces/lab?1563387693000:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/metrics?1563387692942:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563387692023:1 Failed to load resource: net::ERR_NETWORK_CHANGED
vendors~main.4184bdce490c13d11f74.js:168401 Uncaught (in promise) TypeError: Failed to fetch
vendors~main.4184bdce490c13d11f74.js:168016 Uncaught (in promise) TypeError: Cannot read property 'reject' of null
at Object.<anonymous> (vendors~main.4184bdce490c13d11f74.js:168016)
at Generator.next (<anonymous>)
at fulfilled (vendors~main.4184bdce490c13d11f74.js:167716)
vendors~main.4184bdce490c13d11f74.js:228347 Terminal websocket closed: 1006
socket.onclose @ vendors~main.4184bdce490c13d11f74.js:228347
vendors~main.4184bdce490c13d11f74.js:228363 Terminal will attempt to reconnect in 1s
:8888/api/sessions?1563387717828:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563387717832:1 Failed to load resource: net::ERR_NETWORK_CHANGED
lab:1 Uncaught (in promise) TypeError: Failed to fetch
default.js:165 WebSocket connection to 'ws://192.168.55.1:8888/terminals/websocket/1' failed: Error in connection establishment: net::ERR_CONNECTION_TIMED_OUT
(anonymous) @ default.js:165
vendors~main.4184bdce490c13d11f74.js:228375 Terminal reconnect failed Event
(anonymous) @ vendors~main.4184bdce490c13d11f74.js:228375
vendors~main.4184bdce490c13d11f74.js:228363 Terminal will attempt to reconnect in 2s
:8888/api/sessions?1563387737829:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563387737833:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/lab/api/workspaces/lab?1563387734525:1 Failed to load resource: net::ERR_NETWORK_CHANGED
vendors~main.4184bdce490c13d11f74.js:228363 Terminal will attempt to reconnect in 4s
:8888/api/terminals?1563387757845:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/sessions?1563387757830:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/contents/?content=1&1563387763199:1 Failed to load resource: net::ERR_NETWORK_CHANGED
vendors~main.4184bdce490c13d11f74.js:45867 Showing error: TypeError: Failed to fetch
showErrorMessage @ vendors~main.4184bdce490c13d11f74.js:45867
vendors~main.4184bdce490c13d11f74.js:228372 Terminal reconnected
:8888/api/sessions?1563387847816:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563387847820:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/contents/?content=1&1563387864177:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/sessions?1563387867805:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563387867807:1 Failed to load resource: net::ERR_NETWORK_CHANGED
vendors~main.4184bdce490c13d11f74.js:228264 Uncaught (in promise) DOMException: Failed to execute 'send' on 'WebSocket': Still in CONNECTING state.
at http://192.168.55.1:8888/lab/static/vendors~main.4184bdce490c13d11f74.js:228264:24
:8888/api/sessions?1563388047775:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563388047780:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/contents/?content=1&1563388052148:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/kernelspecs?1563388053775:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/sessions?1563388077778:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563388077788:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/sessions?1563388367726:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/terminals?1563388367730:1 Failed to load resource: net::ERR_NETWORK_CHANGED
:8888/api/contents/?content=1&1563388370099:1 Failed to load resource: net::ERR_NETWORK_CHANGED
manager.js:36 [Violation] 'setInterval' handler took 68ms
default.js:195 Terminal websocket closed: 1006
socket.onclose @ default.js:195
default.js:211 Terminal will attempt to reconnect in 1s
manager.js:43 [Violation] 'setInterval' handler took 71ms
serverconnection.js:192 GET http://192.168.55.1:8888/api/contents/?content=1&1563388601068 net::ERR_NETWORK_CHANGED
handleRequest @ serverconnection.js:192
makeRequest @ serverconnection.js:75
get @ index.js:457
get @ index.js:153
(anonymous) @ model.js:231
fulfilled @ model.js:6
Promise.then (async)
step @ model.js:8
(anonymous) @ model.js:9
push.MM3R.__awaiter @ model.js:5
cd @ model.js:208
refresh @ model.js:198
(anonymous) @ model.js:545
dialog.js:32 Showing error: TypeError: Failed to fetch
showErrorMessage @ dialog.js:32
_onConnectionFailure @ browser.js:206
invokeSlot @ index.js:475
emit @ index.js:433
push.qUp9.Signal.emit @ index.js:106
(anonymous) @ model.js:263
Promise.catch (async)
(anonymous) @ model.js:253
step @ model.js:8
cd @ model.js:208
serverconnection.js:192 GET http://192.168.55.1:8888/api/kernelspecs?1563388602694 net::ERR_NETWORK_CHANGED
getSpecs @ default.js:1206
getSpecs @ default.js:1074
getSpecs @ kernel.js:41
_refreshSpecs @ manager.js:284
(anonymous) @ manager.js:48
serverconnection.js:102 Uncaught (in promise) TypeError: Failed to fetch
NetworkError @ serverconnection.js:102
(anonymous) @ serverconnection.js:194
default.js:165 WebSocket connection to 'ws://192.168.55.1:8888/terminals/websocket/2' failed: Error in connection establishment: net::ERR_CONNECTION_TIMED_OUT
_initializeSocket @ default.js:156
(anonymous) @ default.js:218
default.js:223 Terminal reconnect failed Event {isTrusted: true, type: "error", target: WebSocket, currentTarget: WebSocket, eventPhase: 2, …}
(anonymous) @ default.js:223
(anonymous) @ default.js:222
setTimeout (async)
_reconnectSocket @ default.js:214
socket.onclose @ default.js:196
default.js:211 Terminal will attempt to reconnect in 2s
setTimeout (async)
default.js:220 Terminal reconnected
From what I can see, this is not an Nvidia issue. I would try posting your issue here: [url]https://stackoverflow.com/questions/tagged/jupyter-notebook[/url]
