I’d be happy to help you troubleshoot the issue with mounting a CD and provide guidance on modifying the kernel config option.
Understanding the issue
The error you’re encountering when running sudo modprobe sr_mod suggests that the kernel module for the CD/DVD drive (sr_mod) is not loading correctly. The sr_mod module is responsible for providing support for SCSI CD-ROM devices.
Kernel config option: CONFIG_BLK_DEV_SR
The solution you found in other forum posts involves modifying the kernel config option CONFIG_BLK_DEV_SR. This option is used to enable or disable support for SCSI CD-ROM devices in the kernel.
Checking the current kernel config
Before making any changes, you can check the current kernel config to see if CONFIG_BLK_DEV_SR is enabled or disabled. You can do this by running the following command:
zcat /proc/config.gz | grep CONFIG_BLK_DEV_SR
This will show you the current value of the CONFIG_BLK_DEV_SR option.
Modifying the kernel config
To modify the kernel config, you’ll need to rebuild the kernel. The process for doing this varies depending on your Linux distribution and kernel version. Since you didn’t specify your kernel version, I’ll provide general guidance.
For Linux kernel versions 3.12 and later (including Linux 5.14 and Linux 6.2)
You can use the make menuconfig command to modify the kernel config. Here are the steps:
- Change to the kernel source directory:
cd /path/to/kernel/source
- Run
make menuconfig to open the kernel configuration menu.
- Navigate to the “Device Drivers” menu and select " SCSI device support".
- Select " SCSI CD-ROM support" and enable the
- Save the changes and exit the menu.
- Rebuild the kernel using the
make command.
For Linux kernel versions 3.5 and earlier
You can use the make oldconfig command to modify the kernel config. Here are the steps:
- Run
make oldconfig to open the kernel configuration menu.
- Answer the prompts to configure the kernel.
- When prompted for the
CONFIG_BLK_DEV_SR option, select “y” to enable it.
make command.
Rebuilding the kernel
Once you’ve modified the kernel config, you’ll need to rebuild the kernel. The process for doing this varies depending on your Linux distribution and kernel version.
Using the provided context
Based on the provided context, it appears that you’re using a Linux for Tegra system. To rebuild the kernel, you can use the make command in the kernel source directory. You may also need to use the mksparse command to create a sparse version of the kernel image.
Additional steps
After rebuilding the kernel, you’ll need to install the new kernel image and modules. You can do this by running the make install command.
Additionally, you may need to update the kernel modules on your system. You can do this by running the depmod command.
Conclusion
Modifying the kernel config option CONFIG_BLK_DEV_SR and rebuilding the kernel should resolve the issue with mounting a CD. If you’re still encountering issues, you may want to try loading the sr_mod module manually using the modprobe command or checking the system logs for errors.
