• Hardware Platform (Jetson / GPU): T4
• DeepStream Version: 6.0.1
• TensorRT Version: 8.2.3
• NVIDIA GPU Driver Version (valid for GPU only): 470
I have yolov4 .etlt model and generated trt.engine from nvinfer (deepstream-app) and I have generated libnvds_infercustomparser_tao.so
I wish to use same in triton inference server.
model-repository:
Then Written a deepstream-app for the same with nvinferserver plugin.
For one model with the same configuration, I am able to do inference.
But Unable to get any meta info & obj_count for other model with distinct classes.
All are working with nvinfer but not with nvinferserver.
here is config.pbtxt
platform: "tensorrt_plan"
max_batch_size: 16
default_model_filename: "trt.engine"
input [
data_type: TYPE_FP32
format: FORMAT_NCHW
dims: [ 3, 384, 1248 ]
output [
data_type: TYPE_INT32
dims: [ 1 ]
dims: [ 200, 4 ]
dims: [ 200 ]
dims: [ 200 ]
instance_group [
kind: KIND_GPU
count: 1
gpus: 0
Here is my config_infer.txt
infer_config {
unique_id: 1
gpu_ids: [0]
max_batch_size: 16
backend {
inputs: [ {
outputs: [
{name: "BatchedNMS"},
{name: "BatchedNMS_1"},
{name: "BatchedNMS_2"},
{name: "BatchedNMS_3"}
triton {
model_name: "Helmet"
version: 1
grpc {
url: "172.17.0.2:8001"
preprocess {
network_format: MEDIA_FORMAT_NONE
tensor_order: TENSOR_ORDER_NONE
tensor_name: "Input"
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 1
normalize {
scale_factor: 1.0
channel_offsets: [0, 0, 0]
postprocess {
labelfile_path: "../../model_repository/Helmet_model/labels.txt"
detection {
num_detected_classes: 2
custom_parse_bbox_func:"NvDsInferParseCustomBatchedNMSTLT"
per_class_params {
key: 0
value { pre_threshold: 0.4 }
nms {
confidence_threshold:0.2
topk:20
iou_threshold:0.5
custom_lib {
path:"../../.../customLib/libnvds_infercustomparser_tao.so"
