I want to read MIPI CSI Camera, The image can be read normally when connected to the screen, but the image cannot be read normally using SSH.
The error infor:
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 89)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:320 Failed to create FrameConsumer
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:241 (propagating)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, waitRunning:203 Invalid thread state 3
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:806 (propagating)
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (935) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
python code:
import cv2
import multiprocessing
import sys
def gstreamer_pipeline(
sensor_id=0,
capture_width=1280,
capture_height=720,
display_width=960,
display_height=540,
framerate=60,
flip_method=0,
return (
"nvarguscamerasrc sensor-id=%d !"
"video/x-raw(memory:NVMM), width=(int)%d, height=(int)%d, framerate=(fraction)%d/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
"videoconvert ! "
"video/x-raw, format=(string)BGR ! appsink"
sensor_id,
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
def main():
print(gstreamer_pipeline(flip_method=0))
cap = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER)
print(True)
frame = [None] * 1
if cap.isOpened():
try:
while True:
ret , frame[0] = cap.read()
if ret:
#cv2.imshow("video", frame)
print(True)
else:
print("Not read")
keyCode = cv2.waitKey(10) & 0xFF
if keyCode == 27 or keyCode == ord('q'):
break
except KeyboardInterrupt:
cap.release()
cv2.destroyAllWindows()
print("Bye")
sys.exit()
if __name__ == "__main__":
main()
What went wrong?
