I’ve been following multiple tutorials and have a version of the “omniverse code extension” tutorial. I’ve modified it to use my own custom Writer, where the only modification is to also write out pose. I’m getting the following error that the pose node could not be found, but I literally copied the code from an isaac sim offline data generation tutorial and parts of the YCBVideoWriter.
Here’s the error:
[omni.replicator.core.scripts.annotators] Attaching pose to render product(s) ['/Render/RenderProduct_Replicator']
2023-06-29 16:40:32 [219,201ms] [Warning] [omni.graph.core.plugin] Could not find node type interface for 'omni.replicator.isaac.Pose'
2023-06-29 16:40:32 [219,202ms] [Error] [omni.graph] Invalid NodeObj object in Py_Node in getAttributeExists
2023-06-29 16:40:32 [219,202ms] [Error] [omni.syntheticdata.scripts.SyntheticData] SyntheticData failed to set node /Render/PostProcess/SDGPipeline/RenderProduct_Replicator_pose static attribute inputs:imageWidth
Here’s my custom writer, which works fine until I call the line AnnotatorRegistry.get_annotator("pose", ...)
class CustomWriter(BasicWriter):
def __init__(self, intrinsic_matrix, class_to_index, *args, semantic_types=None, **kwargs):
super().__init__(*args, **kwargs, semantic_types=semantic_types)
self.intrinsic_matrix = intrinsic_matrix
self.class_to_index = class_to_index
# Pose Data
self.annotators.append(
AnnotatorRegistry.get_annotator("pose", init_params={"semanticTypes": semantic_types})
def initialize(self, *args, **kwargs):
super().initialize(*args, **kwargs)
def write(self, data):
import ipdb
ipdb.set_trace()
super().write(data)
for annotator in data.keys():
if annotator.startswith("pose"):
self._write_pose(data, "pose", annotator)
def _write_pose(self, data: dict, render_product_path: str, annotator: str):
"""Saves a metadata ".mat" file for the YCB Video Dataset, containing:
- Class indexes (from a pre-defined mapping) corresponding to each semantically-labeled object in view.
- A depth image scaling factor.
- The intrinsic matrix of the camera.
- Poses from the frame of each semantically-labeled object in view to the world frame, represented as a
rotation matrix and a translation.
- The center (in pixel coordinates) of each semantically-labeled object in view. Pixel coordinates are
expressed relative to the top-left corner of the image, with +x to the right and +y down.
Args:
data (dict): A dictionary containing the annotator data for the current frame.
render_product_path (str): Directory name to save data to, corresponding to a specific render product.
annotator (str): Annotator name used as a key in the data dictionary, which can also be used to retrieve the
annotator from the annotator registry.
pose_data = data[annotator]["data"]
n = len(pose_data)
if n > 0:
transform_matrices = np.zeros((n, 4, 4))
else:
transform_matrices = np.array([[[]]])
id_to_labels = data[annotator]["info"]["idToLabels"]
cls_indexes = []
centers = []
for i, (semantic_id, pose, center) in enumerate(pose_data):
# Class indexes
semantic_labels = id_to_labels[str(semantic_id)]["class"]
semantic_label = semantic_labels.split(",")[0]
semantic_index = self.class_to_index[semantic_label]
cls_indexes.append(semantic_index)
# Poses
transform_matrices[i, ...] = pose
# Centers
centers.append([center[0], center[1]])
if n > 0:
# Make poses have a shape of (3, 4, n)
poses = np.moveaxis(transform_matrices[:, :-1, :], 0, -1)
else:
# Make empty poses have a shape of (1, 1, 0)
poses = transform_matrices
meta_dict = {
"cls_indexes": np.asarray(cls_indexes, dtype=np.uint8),
"intrinsic_matrix": self.intrinsic_matrix,
"poses": poses,
"center": np.array(centers, dtype=np.float64),
buf = io.BytesIO()
savemat(buf, meta_dict)
image_id = "{:06d}".format(self._frame_id)
file_path = f"{self._output_dir}/{render_product_path}{image_id}-meta.mat"
self._backend.write_blob(file_path, buf.getvalue())
WriterRegistry.register(CustomWriter)
Here’s the code for registering a pose annotator:
def register_pose_annotator():
"""Register custom pose annotator, specifying its upstream inputs required for computation and its output data
type.
NodeConnectionTemplate = SyntheticData.NodeConnectionTemplate
rep.AnnotatorRegistry.register_annotator_from_node(
name="PoseSync",
input_rendervars=[
NodeConnectionTemplate(
"PostProcessDispatch", attributes_mapping={"outputs:swhFrameNumber": "inputs:syncValue"}
"SemanticBoundingBox2DExtentTightSDExportRawArray",
attributes_mapping={"outputs:exec": "inputs:execIn"},
"InstanceMappingWithTransforms", attributes_mapping={"outputs:exec": "inputs:execIn"}
NodeConnectionTemplate("CameraParams", attributes_mapping={"outputs:exec": "inputs:execIn"}),
node_type_id="omni.graph.action.SyncGate",
name="pose",
input_rendervars=[
NodeConnectionTemplate("PoseSync", attributes_mapping={"outputs:execOut": "inputs:exec"}),
attributes_mapping={"outputs:data": "inputs:data", "outputs:bufferSize": "inputs:bufferSize"},
"CameraParams",
node_type_id="omni.replicator.isaac.Pose",
init_params={
"imageWidth": 1024,
"imageHeight": 1024,
"cameraRotation": np.array([0,0,0]),
"getCenters": True,
# TODO: if we need this True, need to fix weird bug with OgnPose.py that doesn't consider this flag (/home/armstrong/isaac_sim/exts/omni.replicator.isaac/omni/replicator/isaac/ogn/python/nodes/OgnPose.py)
"includeOccludedPrims": False,
output_data_type=np.dtype(
("semanticId", "<u4"),
("prims_to_desired_camera", "<f4", (4, 4)),
("center_coords_image_space", "<f4", (2,)),
output_is_2d=False,
And finally, here’s the part where the writer is created:
# Initialize and attach writer
writer = rep.WriterRegistry.get("CustomWriter")
writer.initialize(output_dir=OUTPUT_FOLDER,
rgb=True, bounding_box_2d_tight=False, semantic_segmentation=False, bounding_box_3d=True, intrinsic_matrix=None, class_to_index=None)
writer.attach([render_product, render_product2])
I believe there must be some issue with running code as an extension vs calling the isaac sim python bash script. I’ve encountered other issues where I tried importing core libraries like “from omni.isaac.core import World” and get an error that this couldn’t be found. Maybe I just need to include the python path?
