Hello all,
We just recently bought licenses, and in my test environment the NVIDIA-control panel gives us the error that it can’t retrieve licences (see attachment).
We bought 275 Grid virtual apps licences, as we were told these are the right ones for our purpose. They are imported in the NVIDIA License Manager and they show them as correct.
In our VMware environment I’ve used the grid_m10-4q profile, which has always worked with the trial license.
Our environment:
Citrix XenApp 7.14
VMWare vSphere 6.5
NVIDIA Grid Tesla M10
The VDI is based on Windows Server 2012 R2
Hi Dennis,
that won’t work. vApps licenses are A profiles. You are attempting to use a Q profile. You need to change the vGPU profile to M10-8A for example. You bought the correct licenses but you use the wrong profile.
Regards
Simon
Hi Simon,
Thank you for your reply. I tried to edit one of our test servers (while the rest is still running on the Q profile) and I get the following error: "The amount of graphics resource available in the parent resource pool is insufficient for the operation."
If I check nvidia-smi:
| NVIDIA-SMI 384.111 Driver Version: 384.111 |
| 0 Tesla M10 On | 00000000:88:00.0 Off | N/A |
| N/A 41C P8 10W / 53W | 8141MiB / 8191MiB | 0% Default |
| 1 Tesla M10 On | 00000000:89:00.0 Off | N/A |
| N/A 41C P8 10W / 53W | 4077MiB / 8191MiB | 0% Default |
| 2 Tesla M10 On | 00000000:8A:00.0 Off | N/A |
| N/A 36C P0 20W / 53W | 4077MiB / 8191MiB | 4% Default |
| 3 Tesla M10 On | 00000000:8B:00.0 Off | N/A |
| N/A 33C P8 10W / 53W | 4077MiB / 8191MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 3548404 M+C+G CTX25 4064MiB |
| 0 8201833 M+C+G CTX22 4064MiB |
| 1 78719 M+C+G CTX24 4064MiB |
| 2 2745611 M+C+G CTX23 4064MiB |
| 3 3548420 M+C+G CTX26 4064MiB |
I was under the impression that the number 4 of the profile meant how many GB of the card is used, so why can’t I start it?
You cannot mixup Q and A profiles. Therefore you get the message that there are no ressources available.
Thanks! That did the trick, after resetting all the profiles to A profiles it works including the licensing.
