Unable to run apt update
I have the same issue as this forum Unable to run apt update, file has unexpected size, but seems that this one is solved almost one year ago. However, I just met this error from the first time just last week, and until now, I’m still not be able to run apt update properly and got the following error log message
Get:1 file:/var/cuda-repo-ubuntu2204-12-2-local  InRelease [1,572 B]
Hit:2 https://download.docker.com/linux/ubuntu jammy InRelease
Hit:3 https://apt.foxglove.dev/studio stable InRelease
Get:4 https://isaac.download.nvidia.com/isaac-ros/release-3 jammy InRelease [13.6 kB]
Hit:5 https://dl.google.com/linux/chrome/deb stable InRelease
Get:6 https://isaac.download.nvidia.com/isaac-ros/release-3 jammy/release-3.0 amd64 Packages [25.8 kB]
Hit:7 http://packages.osrfoundation.org/gazebo/ubuntu-stable jammy InRelease
Hit:8 http://packages.ros.org/ros2/ubuntu jammy InRelease
Hit:9 http://jp.archive.ubuntu.com/ubuntu jammy InRelease
Hit:10 http://jp.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:11 http://security.ubuntu.com/ubuntu jammy-security InRelease
Ign:12 http://robotpkg.openrobots.org/packages/debian/pub jammy InRelease
Hit:13 http://jp.archive.ubuntu.com/ubuntu jammy-backports InRelease
Ign:14 https://isaac.download.nvidia.com/isaac-ros/release-3 jammy/main amd64 Packages
Get:14 https://isaac.download.nvidia.com/isaac-ros/release-3 jammy/main amd64 Packages [27.7 kB]
Err:14 https://isaac.download.nvidia.com/isaac-ros/release-3 jammy/main amd64 Packages
  File has unexpected size (14 != 27666). Mirror sync in progress? [IP: 23.62.20.57 443]
  Hashes of expected file:
   - Filesize:27666 [weak]
   - SHA256:11ff80cd12a3fdccdb463d2ca68a5cc6d8b709f8f67d5141461439bc6f310f4f
   - SHA1:71f7956fa65173506732a2c8bd7db8c94e1f3b07 [weak]
   - MD5Sum:a56929479ae5977d2cac84d35f464cc4 [weak]
  Release file created at: Mon, 12 May 2025 18:10:47 +0000
Hit:15 http://robotpkg.openrobots.org/packages/debian/pub jammy Release
Fetched 13.6 kB in 1s (15.2 kB/s)
Reading package lists... Done
E: Failed to fetch https://isaac.download.nvidia.com/isaac-ros/release-3/dists/jammy/main/binary-amd64/Packages.bz2  File has unexpected size (14 != 27666). Mirror sync in progress? [IP: 23.62.20.57 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Im using Ubuntu 22.04 with ros2 humble installation
Hi @TharitSinsunthorn
I just tried it on my machine and didn’t encounter this bug.
Can you please try to clean the apt cache?
sudo rm -rf /var/lib/apt/lists/*
sudo apt update
Hi @Raffaello Thank you for your support, I’m not sure if I did something wrong or not, so previously I have a waring related to keyrings of the isaacros
W: https://isaac.download.nvidia.com/isaac-ros/release-3/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
So I follow someone who also had the same issue like this
So I ran the command sudo apt-key export <key> | sudo gpg --dearmour -o /usr/share/keyrings/isaac-ros.gpg
Then put this line
deb [arch=amd64 signed-by=/usr/share/keyrings/isaac-ros.gpg] https://isaac.download.nvidia.com/isaac-ros/release-3 jammy main
inside the etc/apt/source.list.d/nvidia-isaac-ros.list.
I did this long time ago before, and has no problem until the last week.
I tried to follow your suggestion, but it’s still generate the same error. So once I tried comment out the line in nvidia-isaac-ros.list, I can run the apt update
