kit_20220411_123718.log (287.7 KB)
I’ve been trying to make Audio2Face work in AWS on multiple configurations. I’ve tried Windows Server 2019, 2022, with either Tesla T4 & A10G GPUs with appropriate Nvidia drivers for each.
While on Windows server 2019 I wasn’t able to launch Audio2Face at all since it kept requiring to update to a newer Windows build even though I was on the latest build for Windows server 2019, I did manage to launch it on Windows Server 2022.
The first error that pops up is:
2022-04-11 12:37:24 [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
- The driver is not installed properly and requires a clean re-install.
- Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
- The driver cannot enumerate any GPU: driver, display or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
I got a bunch of other errors following this on. You can check them out in the attached log file.
Can anyone confirm that Tesla T4 & A10G GPUs are supported? According to what I’ve read online, both of them should support RTX.
Please let me know if I’m missing something.
nvidia-smi output:
| NVIDIA-SMI 511.65 Driver Version: 511.65 CUDA Version: 11.6 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A10G TCC | 00000000:00:1E.0 Off | 0 |
| 0% 32C P0 59W / 300W | 246MiB / 23028MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 9028 C …face-2021.3.3\kit\kit.exe 245MiB |
Appreciate the help,
Roman.
