• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0
• TensorRT Version 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only) 440.33.01
**• Steps to reproduce the issue **
- Create a container from the image : ‘nvcr.io/nvidia/deepstream:6.0-triton’ using the below command sudo docker run -it --gpus all -p 8554:8554 -w /opt/nvidia/deepstream/deepstream-6.0
- Unzip the attached folder in the current working directory (deepstream-6.0).
- Go to efficientdet folder.
- Run the following command python3 main.py file:///opt/nvidia/deepstream/deepstream-6.0/efficientdet/data/sample_720p.h264
- The screenshot of the error is attached.
- Note : We are facing this problem with tensorflow models that do not support batching, whereas with models that support dynamic batching this problem disappears.
efficientdet.zip (45.2 MB)
