Pulled docker container, running in PopOS (Ubuntu 20.04).
ue Aug 18 18:13:34 2020
| NVIDIA-SMI 440.100 Driver Version: 440.100 CUDA Version: 10.2 |
| 0 GeForce RTX 207... Off | 00000000:01:00.0 Off | N/A |
| N/A 44C P8 1W / N/A | 75MiB / 7982MiB | 0% Default |
This is my current setup:
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1249 G /usr/lib/xorg/Xorg 36MiB |
| 0 1944 G /usr/lib/xorg/Xorg 36MiB |
WARNING: infoROM is corrupted at gpu 0000:01:00.0
2020-08-19 00:10:56 [1,617ms] [Error] [carb.scenerenderer-rtx.plugin] Raytracing is not supported on GPU: 0. Hardware, driver or Operating system upgrade is required.
2020-08-19 00:10:56 [1,617ms] [Error] [carb.renderer.plugin] No carb::scenerenderer::SceneRenderer was found.
2020-08-19 00:10:56 [1,617ms] [Warning] [carb.renderer.plugin] Failed to create context for scene renderer ‘rtx’.
2020-08-19 00:10:57 [2,328ms] [Error] [omni.kit.plugin] Startup Error
2020-08-19 00:10:57 [2,328ms] [Error] [omni.kit.plugin] Unable to create renderer. Make sure you are running with an NVIDIA GPU supporting RTX Ray Tracing with a minimum of 6GB GPU memory, and a recent driver.
2020-08-19 00:10:57 [2,328ms] [Error] [omni.kit.plugin] carb::renderer::createContext failed.
/isaac-sim/_build/linux-x86_64/release/isaac-sim-headless.sh: line 4: 10 Segmentation fault (core dumped) “$SCRIPT_DIR/…/…/target-deps/kit_sdk_release/_build/linux-x86_64/release/omniverse-kit” --config-path “$SCRIPT_DIR//experiences/isaac-sim-headless.json” --no-window $@
