Unable to run jetson_multimedia_api 03_video_cuda_enc example inside jetpack:r35.3.1 container: No protocol specified
I am trying to run the jetson_multimedia_api sample 03_video_cuda_enc, /usr/src/jetson_multimedia_api/samples/03_video_cuda_enc/, but i am getting the following error:
No EGL Display
nvbufsurftransform: Could not get EGL display connection
I am running this inside a nvcr.io/nvidia/l4t-jetpack:r35.3.1 container on an Orin (not through ssh). My full docker run command is:
docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-jetpack:r35.3.1 bash. Once inside the container i run the following:
apt install libdrm-dev libvulkan-dev
cd /usr/src/jetson_multimedia_api/samples/03_video_cuda_enc
make
./video_cuda_enc
Any idea how to resolve this? Thanks!
This is configured in the docker run command:
-e DISPLAY=$DISPLAY
Please check if you configure DISPLAY before docker run
confirmed that DISPLAY is set to the following both inside and outside the container:
# echo $DISPLAY
:0
Please try the commands:
$ export DISPLAY=:0
$ xrandr
$ xhost +
$ sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-jetpack:r35.3.1
If it fails in xrandr, please set DISPLAY=:1 and try again.
export DISPLAY=:1 resolves the No protocol specified error i was getting. Now i get:
root@EAC-5000:/home/ubuntu/workspace/gmsl-camera-manager# xrandr
Can't open display :1
which is expected since im remoted into the container.
However, i am still getting the following errors (warnings?)
No EGL Display
nvbuf_utils: Could not get EGL display connection
Do you use AGX Orin developer kit or your custom board? We don’t see the issue on developer kit.
