Unable to run most perception sample apps with Zed camera
When I try to run zed_camera, image_undistortion and some others, I get error stating that not all required modules can be loaded. The application terminates and a minidump gets written. I’m unable to read the minidump following instructions in the SDK wiki. I’m running 2019.2 SDK and Zed camera working fine independently. Just getting started with the SDK so any help is appreciated. See error log:
$ bazel run //apps/samples/zed_camera
WARNING: /home/m/Documents/nvidia/isaac_sdk/packages/perception/BUILD:34:12: in srcs attribute of cc_binary rule //packages/perception:libperception_module.so: please do not import '//packages_x86_64/perception:libperception_module.so' directly. You should either move the file to this package or depend on an appropriate rule there
INFO: Analysed target //apps/samples/zed_camera:zed_camera (0 packages loaded, 0 targets configured).
INFO: Found 1 target...
Target //apps/samples/zed_camera:zed_camera up-to-date:
  bazel-genfiles/apps/samples/zed_camera/run_zed_camera
  bazel-bin/apps/samples/zed_camera/zed_camera
INFO: Elapsed time: 0.759s, Critical Path: 0.00s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 0 processes.
INFO: Build completed successfully, 1 total action
2019-08-01 10:28:58.219 INFO    engine/alice/tools/websight.cpp@166: Loading websight...
2019-08-01 10:28:58.219 WARNING engine/alice/backend/application_json_loader.cpp@98: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2019-08-01 10:28:58.219 WARNING engine/alice/backend/backend.cpp@168: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2019-08-01 10:28:58.219 WARNING engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 16 remaining cores. This may be non optimal for the system and application.
2019-08-01 10:28:58.219 INFO    engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2019-08-01 10:28:58.219 INFO    engine/gems/scheduler/scheduler.cpp@299: __BlockerGroup__: Cores = [12, 13, 14, 15], Workers = No
2019-08-01 10:28:58.219 INFO    engine/gems/scheduler/scheduler.cpp@299: __WorkerGroup__: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11], Workers = Yes
2019-08-01 10:28:58.225 INFO    engine/alice/backend/modules.cpp@283: Loaded module 'packages/sight/libsight_module.so': Now has 41 components total
2019-08-01 10:28:58.234 INFO    engine/alice/backend/modules.cpp@283: Loaded module 'packages/zed/libzed_module.so': Now has 42 components total
2019-08-01 10:28:58.234 ERROR   engine/alice/backend/modules.cpp@307: perception: /home/m/.cache/bazel/_bazel_m/b2cb4d246ab2b5312d5def7a88f3fc76/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/samples/zed_camera/zed_camera.runfiles/com_nvidia_isaac//external/com_nvidia_isaac/packages/perception/libperception_module.so: cannot open shared object file: No such file or directory
2019-08-01 10:28:58.234 PANIC   engine/alice/backend/modules.cpp@309: Could not load all required modules for application
|                            Isaac application terminated unexpectedly                             |
#01 engine/alice/tools/main(+0x8046a) [0x55f010ae146a]
#02 engine/alice/tools/main(+0xe86d0) [0x55f010b496d0]
#03 engine/alice/tools/main(+0xe8a40) [0x55f010b49a40]
#04 /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f5156bf0890]
#05 /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f515628ae97]
#06 /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f515628c801]
#07 engine/alice/tools/main(+0x9d1f7) [0x55f010afe1f7]
#08 engine/alice/tools/main(+0x34bdc) [0x55f010a95bdc]
#09 engine/alice/tools/main(+0x350f3) [0x55f010a960f3]
#10 engine/alice/tools/main(+0x352e4) [0x55f010a962e4]
#11 engine/alice/tools/main(+0x15c23) [0x55f010a76c23]
#12 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f515626db97]
#13 engine/alice/tools/main(+0x1af7a) [0x55f010a7bf7a]
Minidump written to: /tmp/b8d9c88c-61b0-4237-90f51781-e3418466.dmp
Aborted (core dumped)
$ ./engine/build/scripts/process_minidump.sh /tmp/b8d9c88c-61b0-4237-90f51781-e3418466.dmp
./engine/build/scripts/process_minidump.sh: line 25: /tmp/minidump/minidump_stackwalk: No such file or directory
hi redbrick01,
have you already solved the problem and know the reason?
What more can you share about your set up?
Attachment / logs :
Stdout
Sight Output
dmesg
SW Configuration :
SDK package path
JETPACK version
[host or target] - Platform board with version
[OS]
[Fresh installation/setup] Yes or no.
GPU driver (for host-x86)Version
Provide the detailed step by step to repro the issue.
Sample used, commands executed and related parameters shall be listed here.
