Unable to run Nemotron AGX Thor Dev Kit
Platform: Nvidia Thor Developer Kit
JetPack Version: 7.1
Summary: Attempted to run Nemotron 30B via vLLM container and it failed.
I used this reference command…
#!/bin/bash
# Run Command
docker run -it --rm --pull always \
  --runtime=nvidia --network host \
  -e HF_TOKEN=$HF_TOKEN \
  -e VLLM_USE_FLASHINFER_MOE_FP4=1 \
  -e VLLM_FLASHINFER_MOE_BACKEND=throughput \
  -v $HOME/.cache/huggingface:/root/.cache/huggingface \
  nvcr.io/nvidia/vllm:25.12.post1-py3 \
  bash -c "wget -q -O /tmp/nano_v3_reasoning_parser.py \
  --header=\"Authorization: Bearer \$HF_TOKEN\" \
  https://huggingface.co/nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4/resolve/main/nano_v3_reasoning_parser.py \
  && vllm serve nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4 \
  --gpu-memory-utilization 0.5 \
  --trust-remote-code \
  --enable-auto-tool-choice \
  --tool-call-parser qwen3_coder \
  --reasoning-parser-plugin /tmp/nano_v3_reasoning_parser.py \
  --reasoning-parser nano_v3 \
  --kv-cache-dtype fp8"
This takes about 30 minutes to compile flashinfer. I would also recommend mounting another volume: -v $HOME/.cache/flashinfer:/root/.cache/flashinfer to save on loading / compilation time (but only after a successful launch).
The command seemed to work, but did present with hundreds of errors like this:
EngineCore_DP0 pid=194) Unsupported tile (128, 256, 256) and cluster (2, 2, 1) shape combination for arch 100.
(EngineCore_DP0 pid=194) Config was Cutlass GEMM Tactic
(EngineCore_DP0 pid=194) 	style=TMA Warp Specialized
(EngineCore_DP0 pid=194) 	sm: 100
(EngineCore_DP0 pid=194) 	tile shape ID: 128x256x128
(EngineCore_DP0 pid=194) 	cluster shape ID: 2x2x1
(EngineCore_DP0 pid=194) 	dynamic cluster shape ID: undefined
(EngineCore_DP0 pid=194) 	fallback cluster shape ID: undefined
(EngineCore_DP0 pid=194) 	mainloop sched: 0
(EngineCore_DP0 pid=194) 	epi sched: 2
(EngineCore_DP0 pid=194) 	enable cuda kernel: false
(EngineCore_DP0 pid=194) 	epilogue fusion type: 0
(EngineCore_DP0 pid=194) 	swap_ab: true
(EngineCore_DP0 pid=194) 2026-03-06 12:50:32,202 - WARNING - autotuner.py:490 - flashinfer.jit: [Autotuner]: Skipping tactic <flashinfer.fused_moe.core.get_cutlass_fused_moe_module.<locals>.MoERunner object at 0xfffbf77fdfa0> 117, due to failure while profiling: void tensorrt_llm::kernels::cutlass_kernels_oss::dispatchMoeGemmSelectClusterShapeTmaWarpSpecialized(tensorrt_llm::kernels::cutlass_kernels::TmaWarpSpecializedGroupedGemmInput, int, tensorrt_llm::cutlass_extensions::CutlassGemmConfig, int, cudaStream_t, int*, size_t*) [with Arch = cutlass::arch::Sm100; T = __nv_fp4_e2m1; WeightType = __nv_fp4_e2m1; OutputType = __nv_bfloat16; EpilogueTag = tensorrt_llm::cutlass_extensions::EpilogueOpDefault; tensorrt_llm::kernels::cutlass_kernels::TmaWarpSpecializedGroupedGemmInput::EpilogueFusion FUSION = tensorrt_llm::kernels::cutlass_kernels::TmaWarpSpecializedGroupedGemmInput::EpilogueFusion::FINALIZE; TileShape = cute::tuple<cute::C<128>, cute::C<32>, cute::C<256> >; cudaStream_t = CUstream_st*; size_t = long unsigned int]
Later it finished loading, appearing to work:
(APIServer pid=1) INFO:     Started server process [1]
(APIServer pid=1) INFO:     Waiting for application startup.
(APIServer pid=1) INFO:     Application startup complete.
(APIServer pid=1) INFO:     127.0.0.1:39846 - "GET /v1/models HTTP/1.1" 200 OK
(APIServer pid=1) INFO 03-06 12:54:25 [chat_utils.py:574] Detected the chat template content format to be 'string'. You can set `--chat-template-content-format` to override this.
(APIServer pid=1) INFO:     127.0.0.1:42852 - "POST /v1/chat/completions HTTP/1.1" 200 OK
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [dump_input.py:72] Dumping input data for V1 LLM engine (v0.12.0+35a9f223.nv25.12.post1) with config: model='nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4', speculative_config=None, tokenizer='nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4', skip_tokenizer_init=False, tokenizer_mode=auto, revision=None, tokenizer_revision=None, trust_remote_code=True, dtype=torch.bfloat16, max_seq_len=262144, download_dir=None, load_format=auto, tensor_parallel_size=1, pipeline_parallel_size=1, data_parallel_size=1, disable_custom_all_reduce=False, quantization=modelopt_fp4, enforce_eager=False, kv_cache_dtype=fp8, device_config=cuda, structured_outputs_config=StructuredOutputsConfig(backend='auto', disable_fallback=False, disable_any_whitespace=False, disable_additional_properties=False, reasoning_parser='nano_v3', reasoning_parser_plugin='/tmp/nano_v3_reasoning_parser.py', enable_in_reasoning=False), observability_config=ObservabilityConfig(show_hidden_metrics_for_version=None, otlp_traces_endpoint=None, collect_detailed_traces=None, kv_cache_metrics=False, kv_cache_metrics_sample=0.01), seed=0, served_model_name=nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4, enable_prefix_caching=False, enable_chunked_prefill=True, pooler_config=None, compilation_config={'level': None, 'mode': <CompilationMode.VLLM_COMPILE: 3>, 'debug_dump_path': None, 'cache_dir': '/root/.cache/vllm/torch_compile_cache/12d1aea5f2', 'compile_cache_save_format': 'binary', 'backend': 'inductor', 'custom_ops': ['none'], 'splitting_ops': ['vllm::unified_attention', 'vllm::unified_attention_with_output', 'vllm::unified_mla_attention', 'vllm::unified_mla_attention_with_output', 'vllm::mamba_mixer2', 'vllm::mamba_mixer', 'vllm::short_conv', 'vllm::linear_attention', 'vllm::plamo2_mamba_mixer', 'vllm::gdn_attention_core', 'vllm::kda_attention', 'vllm::sparse_attn_indexer'], 'compile_mm_encoder': False, 'compile_sizes': [], 'inductor_compile_config': {'enable_auto_functionalized_v2': False, 'combo_kernels': True, 'benchmark_combo_kernel': True}, 'inductor_passes': {}, 'cudagraph_mode': <CUDAGraphMode.FULL_AND_PIECEWISE: (2, 1)>, 'cudagraph_num_of_warmups': 1, 'cudagraph_capture_sizes': [1, 2, 4, 8, 16, 24, 32, 40, 48, 56, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256, 272, 288, 304, 320, 336, 352, 368, 384, 400, 416, 432, 448, 464, 480, 496, 512], 'cudagraph_copy_inputs': False, 'cudagraph_specialize_lora': True, 'use_inductor_graph_partition': False, 'pass_config': {'fuse_norm_quant': False, 'fuse_act_quant': False, 'fuse_attn_quant': False, 'eliminate_noops': True, 'enable_sp': False, 'fuse_gemm_comms': False, 'fuse_allreduce_rms': False}, 'max_cudagraph_capture_size': 512, 'dynamic_shapes_config': {'type': <DynamicShapesType.BACKED: 'backed'>}, 'local_cache_dir': '/root/.cache/vllm/torch_compile_cache/12d1aea5f2/rank_0_0/backbone'},
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [dump_input.py:79] Dumping scheduler output for model execution: SchedulerOutput(scheduled_new_reqs=[], scheduled_cached_reqs=CachedRequestData(req_ids=['chatcmpl-989ec1ccffc77bb2'], resumed_req_ids=[], new_token_ids=[], all_token_ids={}, new_block_ids=[null], num_computed_tokens=[62], num_output_tokens=[15]), num_scheduled_tokens={chatcmpl-989ec1ccffc77bb2: 1}, total_num_scheduled_tokens=1, scheduled_spec_decode_tokens={}, scheduled_encoder_inputs={}, num_common_prefix_blocks=[0, 0, 0, 0, 0], finished_req_ids=[], free_encoder_mm_hashes=[], preempted_req_ids=[], pending_structured_output_tokens=false, kv_connector_metadata=null, ec_connector_metadata=null)
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [dump_input.py:81] Dumping scheduler stats: SchedulerStats(num_running_reqs=1, num_waiting_reqs=0, step_counter=0, current_wave=0, kv_cache_usage=0.0009861932938856066, prefix_cache_stats=PrefixCacheStats(reset=False, requests=0, queries=0, hits=0, preempted_requests=0, preempted_queries=0, preempted_hits=0), connector_prefix_cache_stats=None, kv_cache_eviction_events=[], spec_decoding_stats=None, kv_connector_stats=None, waiting_lora_adapters={}, running_lora_adapters={})
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845] EngineCore encountered a fatal error.
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845] Traceback (most recent call last):
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 836, in run_engine_core
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     engine_core.run_busy_loop()
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 863, in run_busy_loop
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     self._process_engine_step()
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 892, in _process_engine_step
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     outputs, model_executed = self.step_fn()
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]                               ^^^^^^^^^^^^^^
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 348, in step
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     model_output = self.model_executor.sample_tokens(grammar_output)
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/uniproc_executor.py", line 107, in sample_tokens
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     return self.collective_rpc(
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/uniproc_executor.py", line 75, in collective_rpc
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     result = run_method(self.driver_worker, method, args, kwargs)
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/serial_utils.py", line 479, in run_method
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     return func(*args, **kwargs)
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/torch/utils/_contextlib.py", line 124, in decorate_context
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_worker.py", line 540, in sample_tokens
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     return self.model_runner.sample_tokens(grammar_output)
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 3187, in sample_tokens
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     ) = self._bookkeeping_sync(
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 2611, in _bookkeeping_sync
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     valid_sampled_token_ids = self._to_list(sampled_token_ids)
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 5359, in _to_list
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845]     self.transfer_event.synchronize()
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845] torch.AcceleratorError: CUDA error: an illegal instruction was encountered
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845] Search for `cudaErrorIllegalInstruction' in https://docs.nvidia.com/cuda/cuda-runtime-api/group__CUDART__TYPES.html for more information.
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845] CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845] For debugging consider passing CUDA_LAUNCH_BLOCKING=1
(EngineCore_DP0 pid=194) ERROR 03-06 12:54:55 [core.py:845] Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
I launched a chat window:
docker exec -ti docker exec -ti naughty_bhaskara bash
root@localhost:/workspace# vllm chat
/usr/local/lib/python3.12/dist-packages/torchvision/io/image.py:14: UserWarning: Failed to load image Python extension: 'Could not load this library: /usr/local/lib/python3.12/dist-packages/torchvision/image.so'If you don't plan on using image functionality from `torchvision.io`, you can ignore this warning. Otherwise, there might be something wrong with your environment. Did you have `libjpeg` or `libpng` installed before building `torchvision` from source?
  warn(
[2026-03-06 12:53:26] INFO _client.py:1025: HTTP Request: GET http://localhost:8000/v1/models "HTTP/1.1 200 OK"
Using model: nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4
Please enter a message for the chat model:
> Tell me about SOC2 compliance needs in enterprise applications. Give me a list of common questions during an audit of compliance, and system requirements for our software application.
[2026-03-06 12:54:25] INFO _client.py:1025: HTTP Request: POST http://localhost:8000/v1/chat/completions "HTTP/1.1 200 OK"
  File "/usr/local/bin/vllm", line 7, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/cli/main.py", line 73, in main
    args.dispatch_function(args)
  File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/cli/openai.py", line 152, in cmd
    output = _print_chat_stream(stream)
  File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/cli/openai.py", line 49, in _print_chat_stream
    for chunk in stream:
  File "/usr/local/lib/python3.12/dist-packages/openai/_streaming.py", line 46, in __iter__
    for item in self._iterator:
  File "/usr/local/lib/python3.12/dist-packages/openai/_streaming.py", line 92, in __stream__
    raise APIError(
openai.APIError: EngineCore encountered an issue. See stack trace (above) for the root cause.
I opened the vllm serve window to find this error:
Seems like the root cause is this error message:
Any thoughts on how to resolve this issue?
Slightly edited your command; mainly updated the vllm docker image. Following may work for you too. That compilation time is a pain, but hopefully ~/.cache will make next run of container reasonable and will look to optimize parameters tomorrow. nano_v3_reasoning_parser.py is pulled with the model from huggingface.co.
docker run -it --rm --gpus all --runtime=nvidia \
  --network host --ipc=host --ulimit memlock=-1 --ulimit stack=67108864 \
  -v $HOME/.cache:/root/.cache \
  nvcr.io/nvidia/vllm:26.02-py3 bash
python3 -m vllm.entrypoints.openai.api_server --model nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4 \
  --trust-remote-code --tensor-parallel-size 1 --max-model-len 1024 --gpu-memory-utilization 0.25 \
  --reasoning-parser-plugin $HOME/.cache/huggingface/hub/models--nvidia--NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4/snapshots/480425dab15f8f0a87ebaefb7f9e4e007a70440c/nano_v3_reasoning_parser.py \
  --kv-cache-dtype fp4
curl -X 'POST' \
'http://0.0.0.0:8000/v1/chat/completions' \
-H 'accept: application/json' \
-H 'Content-Type: application/json' \
-d '{
"model": "nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-NVFP4",
"messages": [{"role":"user", "content": "What are Chihuahuas famous for?"}]
I haven’t run nemotron myself. But I have also found, like whitescott, that using a recent vllm container is crucial for newer models.
I’ve been using ghcr.io/nvidia-ai-iot/vllm:0.16.0-g15d76f74e-r38.2-arm64-sbsa-cu130-24.04
I myself have recently been using ghcr.io/nvidia-ai-iot/vllm instead of nvcr.io/nvidia/vllm
But if both will work I’m not sure when to choose the iot image and when the nvcr.io image.
Do you @whitesscott ?
Interesting. Thanks for the help…
I did manage to get the vLLM server running with the nvcr.io/nvidia/vllm:26.02-py3 image. It did crash with an invalid CUDA command still after one of my prompts.
The Nvidia team has been trying hard to move away from “special” builds for Thor and Spark (Blackwell) GPUs. So, the nvidia-ai-iot repositories won’t have things like vllm anymore.
The huggingface downloads folder didn’t include the custom parser script (nano_v3_reasoning_parser.py), hence why on the Jetson AI Labs site, they have that wget command.
As for the compilation- I think from what I’ve read, I need to also volume mount the /root/.cache/vllm/ folder as well. It is recompiling again, but I hope the next launch will be a bit more snappy. I’ll report back and update if that works.
Thanks for reporting this.
Not sure if any recent dependency updates cause this issue.
We need to check it further and update more info with you.
@AastaLLL the most recent ngc sglang image is missing some python modules. I posted here, but looking at that forum I don’t think it is often responded to.
https://forums.developer.nvidia.com/t/sglang-26-02-py3-requires-installation-of-3-python-modules/362739
Hi @whitesscott
Is the error reproduced on Thor?
If so, you can file the topic on Jetson Thor board. We can find someone to check.
We test the same command with nvcr.io/nvidia/vllm:26.02-py3:
$ sudo docker run -it --rm --pull always \
  nvcr.io/nvidia/vllm:26.02-py3 \
  --gpu-memory-utilization 0.8 \
Although flashinfer warning still occur, the chat can work as expected without error.
Could you also give the container a try?
nvidia@tegra-ubuntu:~$ docker exec -it intelligent_curie bash
root@tegra-ubuntu:/workspace# vllm chat
  warn(
## 1️⃣  What “SOC 2 compliance” really means for an enterprise‑grade application
| **What it is** | **Why it matters to an enterprise** | **How it is enforced** |
| **SOC 2 (System and Organization Controls)** is a voluntary attestation framework created by the AICPA that evaluates how a service‑provider handles **customer data** based on the **Trust Services Criteria (TSC)**. | • Customers (and regulators) demand proof that you protect confidentiality, privacy, and availability of their data.  <br>• It is often a contractual requirement for SaaS, PaaS, and other cloud‑ based services.  <br>• Demonstrates maturity of governance, risk, and compliance (GRC) processes. | • An independent **CPA** (or CPA‑firm) performs an audit. <br>• The result is a **SOC 2 Type I** (design of controls at a point in time) or **SOC 2 Type II** (operating effectiveness over a 6‑12‑month period). <br>• The audit report is shared with current and prospective clients, partners, and sometimes regulators. |
It seems to run, and reponds, but if you keep prompting it, the vllm server crashes with an invalid CUDA command error at some point.
How many times have you entered the prompt?
We test the model more than 10 times prompt and the vllm server can work without issue.
