I haven’t been able to run the object detection program on the Orin dev kit available on the below link. I have run the same program the jetson nano but not able to do it on the new device. I run into an issue when i use the cmake command.
Also, on other forums where similar issues were reported, I observed that flashing the device through the sdk manager solved the issue, but I tried doing that, I am getting the errors seen in the image. Can anyone help me with this please? I’m not able to make sense of this issue(PS. I’m an absolute novice with this stuff and would appreciate it if the jargon was kept simple and if steps were provided in a clear manner)
